Home » Archived » Visual Editor (VE) » Error opening Visual Class in Visual Editor
Error opening Visual Class in Visual Editor [message #116190] Sat, 28 January 2006 07:07 Go to next message
Originally posted by: nospamplease_enrictordera.vodafone.es
I was working fine with some Visual Classes generated with VE, but now I
always get an error when trying to open one of that files in the Visual
Editor. Eclipse opens an error window telling me: "Visual Editor for Java
Error - Error trying to set new file into editor - Reason:
java.lang.NullPointerException". I've tried to do a "Project - Clean..." as
seen on other posts but the problem is still there.
I'm running Eclipse 3.1.1 with Visual Editor 1.1.0.1 on a Windows PC. Below
is a copy of the .log file generated when such an error happens.
Any help would be greatly appreciated. Thanks in advance
- Enric
======== Extract from the .log file - START ============
!SESSION 2006-01-28
12:53:07.504 -----------------------------------------------
eclipse.buildId=M20050929-0840
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ve.java.core 4 0 2006-01-28 12:55:20.465
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.setup Control(CompositeGraphicalEditPart.java:98)
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.creat eChild(CompositeGraphicalEditPart.java:84)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:733)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:684)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:232)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:734)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:505)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:986)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$13.run(JavaVisualEditorPart.java:2001)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui 4 4 2006-01-28 12:55:20.555
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-01-28 12:55:20.555
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
Caused by: java.lang.NullPointerException
... 18 more
!ENTRY org.eclipse.jem.proxy 2 0 2006-01-28 12:55:20.936
!MESSAGE
+++ Warning +++: Sat Jan 28 12:55:20 CET 2006 Project (PhotoEvent)-VM for
PhotoEvent:err>
org.eclipse.jem.internal.proxy.common.remote.CommandErrorExc eption--
Error code:7 Value data:"java.lang.NullPointerException:null"
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1254)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:454)
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.cal lbackWithParms(CallbackHandler.java:150)
org.eclipse.ve.internal.swt.targetvm.ControlManager$6.run(Co ntrolManager.java:681)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:541)
org.eclipse.ve.internal.swt.targetvm.ControlManager$ControlM anagerFeedbackController.run(ControlManager.java:678)
org.eclipse.jem.internal.proxy.common.GenericEventQueue$Even tThread.run(GenericEventQueue.java:81)
======== Extract from the .log file - END ============
Re: Error opening Visual Class in Visual Editor [message #116253 is a reply to message #116190] Mon, 30 January 2006 11:33 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Can you attach or send me a copy of the class that fails? Other classes
still work, is that correct?
Rich Kulp
Re: Error opening Visual Class in Visual Editor [message #611897 is a reply to message #116190] Mon, 30 January 2006 11:33 Go to previous message
Rich Kulp
Previous Topic:I drop a shell and just appear a litle black square in the editor
Next Topic:MDI Project
Current Time: Fri Jul 18 22:43:43 EDT 2025
Powered by FUDForum. Page generated in 0.04041 seconds
