Home » Eclipse Projects » Remote Application Platform (RAP) » Coolbar cuts off text
Coolbar cuts off text [message #10599] Wed, 21 March 2007 08:33 Go to next message
if I have actions with text in the cool bar added as ActionContributionItem
with the property ActionContributionItem.MODE_FORCE_TEXT then the text of
the last action is cutted a little bit so that the text does not display
correctly. You can reproduce it, if You change the method createToolBar in
the action bar advisor of Your Demo to the code below. It seems that it cuts
more for every action that is added with text.
private void createToolBar( ICoolBarManager coolBar, final String name ) {
IToolBarManager toolbar = new ToolBarManager( RWT.FLAT | RWT.RIGHT );
coolBar.add( new ToolBarContributionItem( toolbar, name ) );
toolbar.add( exitAction );
int aboutActionAdded = 5;
for(int i = 0; i < aboutActionAdded; i++) {
ActionContributionItem contributionItem =
new ActionContributionItem(aboutAction);
contributionItem.setMode(ActionContributionItem.MODE_FORCE_T EXT);
toolbar.add(contributionItem);
Markus
Re: Coolbar cuts off text [message #11538 is a reply to message #10599] Thu, 22 March 2007 15:29 Go to previous message
Hi Markus,
that looks sad. I added a two extra pixels in the size caluclation of
ToolItem when image and text are display together.
But don't expect this to work under all circumstances. The current text
size calculation (rather an estimation to be true) might add to this. We
will replace this with a proper calculation in the future. Some more
information on this can be found here:
http://wiki.eclipse.org/index.php/18_Fonts#Font_Size_Measure ments
Rüdiger
Markus Krüger wrote:
> Hello,
> Best regards,
> Markus
Previous Topic:Icons in menue
Next Topic:Header and Items table set visible
Current Time: Fri Jul 25 14:05:23 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
