Home » Archived » Visual Editor (VE) » SWT Menubar
SWT Menubar [message #116017] Fri, 27 January 2006 07:26 Go to next message
Originally posted by: uli.spielviel.de
Hi Group,
I want to get a SWT menubar into my SWT shell widget. In the palette I
selected "MenuBar" under SWT Menus and clicked on the shell widget in the
Java Beans view which created an entry titled "menuBar" beneath the shell
widget. I then selected "MenuItem.SubMenu" and wanted to place it beneath
the menuBar widget I just created but the mouse cursor doesn't change to
the "insert here" symbol but stays in "not allowed" mode.
I'm using Eclipse 3.1.1, GEF 3.1.0, EMF 2.1.0 and VE 1.1.0.1. I also tried
replacing GEF with version 3.1.1 and EMF with version 2.1.2 to no avail.
Thanks for helping me
Uli
Re: SWT Menubar [message #116046 is a reply to message #116017] Fri, 27 January 2006 09:29 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Did you try dropping it right on the MenuBar in the JavaBeans Viewer? If
there are no children to the MenuBar then you need to drop right on it.
Rich Kulp
Re: SWT Menubar [message #116057 is a reply to message #116046] Fri, 27 January 2006 10:15 Go to previous messageGo to next message
I tried to drop a "MenuItem.SubMenu"-item right on top of an empty
menuBar-item in the Java Beans view. Exactly how you described it...
Uli
Re: SWT Menubar [message #116177 is a reply to message #116057] Fri, 27 January 2006 14:43 Go to previous messageGo to next message
That should of worked. Is there any errors in the .log file?
> Uli
Rich Kulp
Re: SWT Menubar [message #116404 is a reply to message #116177] Tue, 31 January 2006 08:29 Go to previous messageGo to next message
Originally posted by: alexandre.gzsistemas.com.br
Rich Kulp escreveu:
>> Uli
Rich,
I have exactly the same problem. My configuration is Eclipse SDK 3.1.1,
GEF 3.1.1, EMF 2.1.1 and Visual Editor 1.1.0.1.
I'm running Eclipse on Windows XP Professional.
What can be wrong ?
Thanks.
Re: SWT Menubar [message #116417 is a reply to message #116404] Tue, 31 January 2006 11:07 Go to previous messageGo to next message
Are there any errors in the .log file? Did you try a clean cache?
Alexandre Boaventura wrote:
> Rich Kulp escreveu:
>>> Uli
> Rich,
> What can be wrong ?
> Thanks.
Rich Kulp
Re: SWT Menubar [message #116425 is a reply to message #116417] Tue, 31 January 2006 12:27 Go to previous messageGo to next message
Rich Kulp escreveu:
>> Rich Kulp escreveu:
>>>> Uli
>> Rich,
>> 3.1.1, GEF 3.1.1, EMF 2.1.1 and Visual Editor 1.1.0.1.
>> What can be wrong ?
>> Thanks.
Hi Rich,
Here is my log file. I've cleaned it before open Eclipse. The first
error occurs just by opening Eclipse.
It opened the last visual class I was working on. It was clean, with no
widgets. So, I inserted a Menu widget and tried to insert a MenuItem.
I hope this error log can help to find what is the problem.
Thank you.
Re: SWT Menubar [message #116458 is a reply to message #116425] Tue, 31 January 2006 13:01 Go to previous messageGo to next message
--------------060805010403000105080006
Alexandre Boaventura escreveu:
> Rich Kulp escreveu:
>>> Rich Kulp escreveu:
>>>>> Uli
>>> Rich,
>>> What can be wrong ?
>>> Thanks.
> Hi Rich,
> Thank you.
Now, the error log attached. Sorry.
name="error.log"
Content-Disposition: inline;
filename="error.log"
!SESSION 2006-01-31 15:13:59.500 -----------------------------------------------
eclipse.buildId=M20050929-0840
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_BR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ve.java.core 4 0 2006-01-31 15:14:21.46
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
at org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1358)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:923)
at org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:16:20.437
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:16:20.437
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
at org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:90)
at org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
at org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
at org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
at org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:16:22.937
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:16:22.937
!STACK 0
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:16:47.750
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:16:47.750
!STACK 0
... 18 more
!ENTRY org.eclipse.ve.java.core 4 0 2006-01-31 15:17:50.625
!STACK 0
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.doSave(JavaVisualEditorPart.java:2817)
at org.eclipse.ui.internal.SaveableHelper$1.run(SaveableHelper. java:95)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:116)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:621)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2134)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:122)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:100)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1154)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2714)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2727)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:69)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:18:11.281
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:18:11.281
!STACK 0
... 18 more
--------------060805010403000105080006--
Re: SWT Menubar [message #116470 is a reply to message #116458] Tue, 31 January 2006 13:44 Go to previous messageGo to next message
We have a problem with a set of our caches. They sometimes get
corrupted. We've found a major reason why in just the last few weeks for
VE 1.2 and have fixed that one. This error is usually due to a cache
problem.
To clean the cache do the following:
1) Open a VE and then close it. Close all open VE's.
2) Go to Project->Clean...->Clean All and apply it. Then wait for build
the to complete.
3) Open a VE. It should now be ok.
Rich Kulp
Re: SWT Menubar [message #116497 is a reply to message #116470] Tue, 31 January 2006 14:10 Go to previous message
Rich Kulp escreveu:
> problem.
> the to complete.
Good ! Very good. Now it works.
Thank you again Rich.
Re: SWT Menubar [message #611881 is a reply to message #116017] Fri, 27 January 2006 09:29 Go to previous message
Rich Kulp
Re: SWT Menubar [message #611882 is a reply to message #116046] Fri, 27 January 2006 10:15 Go to previous message
Uli
Re: SWT Menubar [message #611891 is a reply to message #116057] Fri, 27 January 2006 14:43 Go to previous message
> Uli
Rich Kulp
Re: SWT Menubar [message #611904 is a reply to message #116177] Tue, 31 January 2006 08:29 Go to previous message
Rich Kulp escreveu:
>> Uli
Rich,
What can be wrong ?
Thanks.
Re: SWT Menubar [message #611906 is a reply to message #116404] Tue, 31 January 2006 11:07 Go to previous message
> Rich Kulp escreveu:
>>> Uli
> Rich,
> What can be wrong ?
> Thanks.
Rich Kulp
Re: SWT Menubar [message #611907 is a reply to message #116417] Tue, 31 January 2006 12:27 Go to previous message
Rich Kulp escreveu:
>> Rich Kulp escreveu:
>>>> Uli
>> Rich,
>> What can be wrong ?
>> Thanks.
Hi Rich,
Thank you.
Re: SWT Menubar [message #611910 is a reply to message #116425] Tue, 31 January 2006 13:01 Go to previous message
> Rich Kulp escreveu:
>>> Rich Kulp escreveu:
>>>>> Uli
>>> Rich,
>>> What can be wrong ?
>>> Thanks.
> Hi Rich,
> Thank you.
name="error.log"
!STACK 0
!STACK 0
... 18 more
!STACK 0
... 18 more
!STACK 0
... 18 more
!STACK 0
!STACK 0
... 18 more
Re: SWT Menubar [message #611912 is a reply to message #116458] Tue, 31 January 2006 13:44 Go to previous message
problem.
the to complete.
Rich Kulp
Re: SWT Menubar [message #611917 is a reply to message #116470] Tue, 31 January 2006 14:10 Go to previous message
Rich Kulp escreveu:
> problem.
> the to complete.
Previous Topic:No SWT item in the palette
Next Topic:ve creates widgets by itself
Current Time: Sat Jul 26 14:44:21 EDT 2025
Powered by FUDForum. Page generated in 0.07029 seconds
