SWT Menubar [message #116017] |
Fri, 27 January 2006 07:26  |
Originally posted by: uli.spielviel.de
Hi Group,
I want to get a SWT menubar into my SWT shell widget. In the palette I
selected "MenuBar" under SWT Menus and clicked on the shell widget in the
Java Beans view which created an entry titled "menuBar" beneath the shell
widget. I then selected "MenuItem.SubMenu" and wanted to place it beneath
the menuBar widget I just created but the mouse cursor doesn't change to
the "insert here" symbol but stays in "not allowed" mode.
I'm using Eclipse 3.1.1, GEF 3.1.0, EMF 2.1.0 and VE 1.1.0.1. I also tried
replacing GEF with version 3.1.1 and EMF with version 2.1.2 to no avail.
Thanks for helping me
Uli
Re: SWT Menubar [message #116458 is a reply to message #116425] |
Tue, 31 January 2006 13:01   |
Originally posted by: alexandre.gzsistemas.com.br
--------------060805010403000105080006
Alexandre Boaventura escreveu:
> Rich Kulp escreveu:
>> Are there any errors in the .log file? Did you try a clean cache?
>> Alexandre Boaventura wrote:
>>> Rich Kulp escreveu:
>>>> That should of worked. Is there any errors in the .log file?
>>>> Ulrich Staerk wrote:
>>>>> I tried to drop a "MenuItem.SubMenu"-item right on top of an empty
>>>>> menuBar-item in the Java Beans view. Exactly how you described it...
>>>>> Uli
>>> Rich,
>>> I have exactly the same problem. My configuration is Eclipse SDK
>>> 3.1.1, GEF 3.1.1, EMF 2.1.1 and Visual Editor 1.1.0.1.
>>> I'm running Eclipse on Windows XP Professional.
>>> What can be wrong ?
>>> Thanks.
> Hi Rich,
> Here is my log file. I've cleaned it before open Eclipse. The first
> error occurs just by opening Eclipse.
> It opened the last visual class I was working on. It was clean, with no
> widgets. So, I inserted a Menu widget and tried to insert a MenuItem.
> I hope this error log can help to find what is the problem.
> Thank you.
Now, the error log attached. Sorry.
name="error.log"
Content-Disposition: inline;
filename="error.log"
!SESSION 2006-01-31 15:13:59.500 -----------------------------------------------
eclipse.buildId=M20050929-0840
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_BR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ve.java.core 4 0 2006-01-31 15:14:21.46
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
at org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1358)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:923)
at org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:16:20.437
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:16:20.437
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
at org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:90)
at org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
at org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
at org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
at org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:16:22.937
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:16:22.937
!STACK 0
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:16:47.750
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:16:47.750
!STACK 0
... 18 more
!ENTRY org.eclipse.ve.java.core 4 0 2006-01-31 15:17:50.625
!STACK 0
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.doSave(JavaVisualEditorPart.java:2817)
at org.eclipse.ui.internal.SaveableHelper$1.run(SaveableHelper. java:95)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:116)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:621)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2134)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:122)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:100)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1154)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2714)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2727)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:69)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:18:11.281
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:18:11.281
!STACK 0
... 18 more
--------------060805010403000105080006--
Re: SWT Menubar [message #116497 is a reply to message #116470] |
Tue, 31 January 2006 14:10  |
Rich Kulp escreveu:
> We have a problem with a set of our caches. They sometimes get
> corrupted. We've found a major reason why in just the last few weeks for
> VE 1.2 and have fixed that one. This error is usually due to a cache
> problem.
> To clean the cache do the following:
> 1) Open a VE and then close it. Close all open VE's.
> 2) Go to Project->Clean...->Clean All and apply it. Then wait for build
> the to complete.
> 3) Open a VE. It should now be ok.
Good ! Very good. Now it works.
Thank you again Rich.
Re: SWT Menubar [message #611881 is a reply to message #116017] |
Fri, 27 January 2006 09:29  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Did you try dropping it right on the MenuBar in the JavaBeans Viewer? If
there are no children to the MenuBar then you need to drop right on it.
Rich Kulp
Re: SWT Menubar [message #611882 is a reply to message #116046] |
Fri, 27 January 2006 10:15  |
Uli
Re: SWT Menubar [message #611891 is a reply to message #116057] |
Fri, 27 January 2006 14:43  |
> Uli
Rich Kulp
Re: SWT Menubar [message #611904 is a reply to message #116177] |
Tue, 31 January 2006 08:29  |
Rich Kulp escreveu:
>> Uli
Rich,
I have exactly the same problem. My configuration is Eclipse SDK 3.1.1,
What can be wrong ?
Thanks.
Re: SWT Menubar [message #611906 is a reply to message #116404] |
Tue, 31 January 2006 11:07  |
> Rich Kulp escreveu:
>>> Uli
> Rich,
> What can be wrong ?
> Thanks.
Rich Kulp
Re: SWT Menubar [message #611907 is a reply to message #116417] |
Tue, 31 January 2006 12:27  |
Rich Kulp escreveu:
>> Rich Kulp escreveu:
>>>> Uli
>> Rich,
>> What can be wrong ?
>> Thanks.
Hi Rich,
Thank you.
Re: SWT Menubar [message #611910 is a reply to message #116425] |
> Rich Kulp escreveu:
>>> Rich Kulp escreveu:
>>>>> Uli
>>> Rich,
>>> What can be wrong ?
>>> Thanks.
> Hi Rich,
> Thank you.
name="error.log"
!STACK 0
!STACK 0
... 18 more
!STACK 0
... 18 more
!STACK 0
... 18 more
!STACK 0
!STACK 0
... 18 more
Re: SWT Menubar [message #611912 is a reply to message #116458] |
Tue, 31 January 2006 13:44  |
problem.
the to complete.
Rich Kulp
Re: SWT Menubar [message #611917 is a reply to message #116470] |
Rich Kulp escreveu:
> problem.
> the to complete.
FUDForum. Page generated in 0.05831 seconds
