Home » Archived » Visual Editor (VE) » Exporting JAR file - "resource is out of sync with file system"
Exporting JAR file - "resource is out of sync with file system" [message #116002] Thu, 26 January 2006 23:43 Go to next message
Originally posted by: stjohnsoftware.yahoo.com
I'm new to Eclipse.
I'm trying to export a Java project as a JAR file.
I get the following error for a JPG file: "resource is out of sync with
file system"
All of the other JPG files in the same directory as this problem file are
included in the JAR file without any issues. (And all the JPG files were
created in the same manner.)
So does anyone know what this error indicates and/or what I can do to remedy
the problem?
Re: Exporting JAR file - "resource is out of sync with file system" [message #116031 is a reply to message #116002] Fri, 27 January 2006 07:40 Go to previous message
That means the files have changed on the disk since the last time
Eclipse took a look at them. It's easy enough to fix - select the files
and hit F5 (Refresh).
- Jeff
Re: Exporting JAR file - "resource is out of sync with file system" [message #611879 is a reply to message #116002] Fri, 27 January 2006 07:40 Go to previous message
- Jeff
Previous Topic:SWT Menubar
Next Topic:Default font parameters
Current Time: Sat Jun 28 06:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.05693 seconds
