widget properties problem [message #115934] |
Thu, 26 January 2006 10:52  |
Originally posted by: alexandre.gzsistemas.com.br
I've been using ve since yesterday. So, there are a lot to learn ! Sorry
if it's so beginners question.
Sometimes, when I select a widget the only property that appear at
properties tab is the one called "name". Nothing more.
Why ? Is there any solution for that or it's a bug.
I updated ve yesterday too.
Thanks.
Re: widget properties problem [message #115989 is a reply to message #115976] |
Thu, 26 January 2006 15:14  |
Rich Kulp escreveu:
> It sounds like you may have a bad cache.
> First make sure you the right versions installed. For Eclipse 3.1.1 you
> need
> EMF 2.1
> GEF 3.1.1
> VE 1.1.0.1
> If you have those installed then clear the cache:
> 1) Bring up a VE and then close it and all other VE's. But leave
> workspace up.
> 2) Select Project->Clean...->Clean All. Hit OK and wait for build to
> finish.
> 3) Bring up a VE. See if it now works.
> Alexandre Boaventura wrote:
>> Sorry if it's so beginners question.
>> Thanks.
Sorry Rich.
I know what happened. If the Shell widget is completely empty then it
will not have access to properties. It's solved.
Thanks for your help.
Re: widget properties problem [message #611867 is a reply to message #115934] |
Thu, 26 January 2006 13:57  |
First make sure you the right versions installed. For Eclipse 3.1.1 you need
EMF 2.1
GEF 3.1.1
VE 1.1.0.1
workspace up.
2) Select Project->Clean...->Clean All. Hit OK and wait for build to finish.
> Thanks.
Rich Kulp
Re: widget properties problem [message #611871 is a reply to message #115976] |
Rich Kulp escreveu:
> need
> EMF 2.1
> GEF 3.1.1
> VE 1.1.0.1
> workspace up.
> finish.
>> Thanks.
Sorry Rich.
FUDForum. Page generated in 0.33827 seconds
