| Bad performance of XML Schema Editor [message #115933] |
Mon, 04 July 2005 16:28  |
is there any reason for slow performance of Graph page of XML Schema Editor ?
Anytime i click on graph page (or when i expand some subitem in graph), the
CPU is used at 90% for around a 30-60 secs by Eclipse (and Eclipse looks like
freezed). This makes graphical XML Schema editor unusable.
Eclipse 3.1 (built from source on Gentoo Linux), WTP 0.7M5.
Frantisek Augusztin
| Re: Bad performance of XML Schema Editor [message #118849 is a reply to message #116555] |
Sat, 09 July 2005 12:05  |
So, I eventually got around profiling the workbench with my XML schema
open.
It actually took me a while because I had to do my own porting of eclipse
profiler plugin (Konstantin Scheglov's) to Eclipse 3.1.
First of all I want to say that if I use a normal, simple XML schema,
everything works fine.
That is, as soon as the XSD is loaded and validated, the CPU counters
freeze.
On the other hand, if I load my XSD (a valid one, if I'm to believe the
validator and XMLS[lop]py), then things start to go wrong.
First of all, the CPU keeps working even if I only loaded the file in the
editor. I don't even edit it.
Here are a few conclusions from eclipse profiler
- Only one worker thread is to blame.
- This thread execute in continuation the
org.eclipse.wst.sse.ui.internal.reconcile.DirtyRegionProcess or#run
If I follow the path of the most CPU hungry calls I drill down as follows.
I've added the number of invocations counted by Eclipse Profiler so that
one understands where the 'gap' lies, percentage are CPU% for that thread.
100% 1 invocation -
100% 1 invocation -
org.eclipse.wst.sse.ui.internal.reconcile.StructuredRgionPro cess.process
87% 66 invocations -
org.eclipse.wst.sse.ui.internal.reconcile.AbstractStructured TextReconcilingStrategy#reconcile
org.eclipse.wst.sse.ui.internal.validation.ReconcileStepForM arkup#reconcileModel
66% 66 invocations -
org.eclipse.wst.sse.ui.internal.validation.ReconcileStepForM arkup#getStructuredDocumentRegions
65% 236783 invocations -
org.eclipse.wst.xml.core.internal.document.DOMModelIml#getIn dexedRegion
So I guess there is something wrong in
ReconcileStepForMarkup#getStructuredDocumentRegions that results in never
returning.
So I got into the src code and I found this bit.
I don't know the context but I wonder when you get out of this loop.
Could that be it ?
while (sdRegion != null
&& !sdRegion.isDeleted()
&& xmlNode != null
&& sdRegion.getEndOffset() <= xmlNode.getEndOffset()) {
if (!sdRegion.isDeleted())
regions.add(sdRegion);
sdRegion = sdRegion.getNext();
xmlNode = getXMLNode(sdRegion);
Hope this helps to make this very nice XSD editor more usable ;-)
If you need my XSD or assistance with the Eclipse Profiler plugin
(it's very powerful but, having been developed for Eclipse version 2, it's
aging a bit), please fee free to send me a mail at
alain dot m dot pannetier at atosorigin dot com
Alain Pannetier
FUDForum. Page generated in 0.16091 seconds
