Home » Eclipse Projects » GEF » GEF I20040205 and Logic Example from CVS?
GEF I20040205 and Logic Example from CVS? [message #115902] Thu, 05 February 2004 07:15 Go to next message
Originally posted by: joerg.von.frantzius.artnology.nospam.com
Hi all,
maybe I'm mixing up something here, but I get compile errors in the
Logic Example plugin project that I just got from the CVS. I have GEF
I20040205 installed here. Maybe the example is only for GEF 2.1.2 or
something like that?
I get e.g. "Type mismatch: cannot convert from LogicRulerProvider to
RulerProvider" in LogicEditor.java line 379.
Thanks for any help,
Jörg.
Re: GEF I20040205 and Logic Example from CVS? [message #115915 is a reply to message #115902] Thu, 05 February 2004 09:23 Go to previous messageGo to next message
Originally posted by: brian.fernandes.codito.com
Perhaps you should check out GEF as well, instead of using the Integration
build - even though it is so recent.
Re: GEF I20040205 and Logic Example from CVS? [message #115927 is a reply to message #115902] Thu, 05 February 2004 09:28 Go to previous messageGo to next message
"Joerg von Frantzius" <joerg.von.frantzius@artnology.nospam.com> wrote in
message news:bvtc0i$cj1$1@eclipse.org...
No, the Logic plugin is being updated along with GEF; the CVS checkout which
you got should work with the GEF version existing in the repositry.
Re: GEF I20040205 and Logic Example from CVS? [message #115939 is a reply to message #115915] Thu, 05 February 2004 10:40 Go to previous messageGo to next message
OK now it compiles.
Jörg.
Re: GEF I20040205 and Logic Example from CVS? [message #115972 is a reply to message #115939] Thu, 05 February 2004 10:57 Go to previous message
For the moment, use the CVS build of GEF if you are using the CVS build of
the LogicEditor. The most recent Integration build of GEF is not up-to-date.
message news:bvto03$rug$1@eclipse.org...
Integration
> OK now it compiles.
> J
Previous Topic:FreeformFigure and LayoutManager
Next Topic:which version to use with the last integration build of eclipse
Current Time: Tue Jul 22 09:05:35 EDT 2025
Powered by FUDForum. Page generated in 0.03363 seconds
