The VE do not open [message #115897] |
Wed, 25 January 2006 23:07  |
Originally posted by: vinicius.negrisoli.gmail.com
I hava installed the VE but I am not getting use it. To use the eclipse
and VE I have unzipped the follow archieve:
eclipse-SDK-3.1.1-win32
emf-sdo-runtime-2.0.1
GEF-runtime-3.0.1
VE-runtime-1.2M1
After it I had started the eclipse with the flag -clean. The problem is
that when I try to open some Visual class with the VE it not works. A new
window of VE is openned but bottons of VE stay inactive and no error
messages are shown. I hava sawn on Manage Configuration and all,
including the VE, are enabled. Can someone help me ? Thank you!
Re: The VE do not open [message #115923 is a reply to message #115911] |
Thu, 26 January 2006 07:12  |
VE 1.2 M1 will only run on Eclipse 3.2 M4. See the requirements section
on the 1.2 M1 download page. You can use VE 1.1.0.1 on Eclipse 3.1.1.
Hope this helps,
- Jeff
Re: The VE do not open [message #611847 is a reply to message #115897] |
Thu, 26 January 2006 00:03  |
Originally posted by: pangzi.sjtu.gmail.com
Vinicius wrote:
> GEF-runtime-3.0.1
> VE-runtime-1.2M1
> new window of VE is openned but bottons of VE stay inactive and no error
The same problem happens to me.
Re: The VE do not open [message #611850 is a reply to message #115911] |
Hope this helps,
- Jeff
FUDForum. Page generated in 0.03767 seconds
