Supporting REDO &UNDO in graphic editor [message #115846] |
Thu, 05 February 2004 03:30  |
Originally posted by: sreejaak.yahoo.com
I need to support REDO and UNDO in my class that extends
GraphicalEditorWithPalette. I tried the two options
1) Tried using org.eclipse.gef.ui.actions.ActionBarContributor as the
contributorClass. I got an error saying that ActionBarContributor could
not be instantiated.
2) Tried extending ActionBarContributor. In the extended class, I provided
the following methods
protected void buildActions() {
addRetargetAction(new UndoRetargetAction());
addRetargetAction(new RedoRetargetAction());
addRetargetAction(new DeleteRetargetAction());
protected void declareGlobalActionKeys() {
addGlobalActionKey(IWorkbenchActionConstants.UNDO);
addGlobalActionKey(IWorkbenchActionConstants.REDO);
public void contributeToToolBar(IToolBarManager tbm) {
tbm.add(getAction(IWorkbenchActionConstants.UNDO));
tbm.add(getAction(IWorkbenchActionConstants.REDO));
} public void contributeToMenu(IMenuManager menubar) {
super.contributeToMenu(menubar);
I have just one label and one text in the editor. The Undo/Redo menu items
come disabled and the Ctrl-Z, Ctrl-Y commands are not working. What could
I be doing wrong?
Thanks in advance,
Sree
Re: Supporting REDO &UNDO in graphic editor [message #115890 is a reply to message #115846] |
Thu, 05 February 2004 06:46  |
Originally posted by: brian.fernandes.codito.com
Have you had a look at how the Logic plugin implements undo and redo ?
It's pretty straight forward, your Commands should have undo and redo
methods (if you don't supply a redo method then the execute method is
called)
Brian.
"Sree" <sreejaak@yahoo.com> wrote in message
news:bvsv03$se3$1@eclipse.org...
> I be doing wrong?
> Thanks in advance,
> Sree
FUDForum. Page generated in 0.06934 seconds
