XDC Tool dependency [message #880] |
Mon, 02 February 2009 13:02  |
The following provides an overview of the changes done on the same code
base without any modifications. The only changes are migrating to later
releases of XDC. The plan is to baseline the changes on XDC Version
3.15.00.16. Is this recommended?
XDC Tools 3.15.000.13
Codec Engine 3.00.00.12
BIOS Version 6.20.00.07
Modifications required to code : Possibly due to BIOS dependency we need
to explicitly include use.Module for GateMP module in the cfg file, else
it throws an error unbound proxy for GateMP module
Build Status SUCCESSFUL
XDC Tools 3.15.00.15
Modifications required to the code:
Doesn't require changes related to GateMP, but throws different set of
errors
Build Status FAILURE
Error description Cannot resolve Assert.Id
Build Errors:
"Y:\WTSD_DucatiMMSW\omx\khronos1.1\omx_h264_dec>""c:\Program Files\Texas
Instruments\xdctools_3_15_00_15\xdc.exe""
making package.mak (because of package.bld) ...
generating interfaces for package omx_h264_dec (because
package/package.xdc.inc is older than package.xdc) ...
configuring out/h264vd.xm3 from package/cfg/out/h264vd_xm3.cfg ...
""ti/sysbios/knl/Clock.xdc"", line 162: can't resolve name (Assert.Id)
java.lang.reflect.InvocationTargetException
at xdc.services.intern.xsr.PkgLoader.exec(PkgLoader.java:145)
at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:155)
org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMetho d.java:243)
org.mozilla.javascript.Interpreter.interpretLoop(Interpreter .java:3237)
org.mozilla.javascript.Interpreter.interpret(Interpreter.jav a:2394)
org.mozilla.javascript.InterpretedFunction.exec(InterpretedF unction.java:176)
at org.mozilla.javascript.Context.evaluateReader(Context.java:1 227)
at config.Shell.evaluateLoad(Shell.java:761)
at config.Shell.processLoad(Shell.java:634)
at config.Shell.load(Shell.java:1197)
XDC Tools 3.15.00.16
BIOS Version 6.20.00.16
Modifications required to the code :
Changes:
- XDC Changes related to migration of M3 within ARM under packages family
subdirectory
- catalog.c470.nda needs to be catalog.arm.nda
- SRAM is not a recognized heap memory location"
Error description can't resolve name (IGateProvider.Handle)
Build Errors "Y:\WTSD_DucatiMMSW\omx\khronos1.1\omx_h264_dec>""c:\Program
Files\Texas Instruments\xdctools_3_15_00_16\xdc.exe""
making package.mak (because of config.bld) ...
ti.sdo.osal.bios6.Settings.module$use(): Intializing
xdc.runtime.knl.Semaphore.Proxy to bios6 Semaphore
xdc.runtime.knl.SemaphoreMP.Proxy to bios6 SemaphoreMP
xdc.runtime.knl.Gate.Proxy to bios6 Gate
xdc.runtime.knl.GateMP.Proxy to bios6 GateMP
xdc.runtime.knl.Thread.Proxy to bios6 Thread
xdc.runtime.knl.Condition.Proxy to bios6 Condition
Configuration for Ducati...
ti.sdo.fc.ires.hdvicp.HDVICP2.module$use(): Setting HDVICP2.gate...
ti.sdo.fc.dskt2.DSKT2CFG.module$use(): Setting DSKT2.common$.gate...
""ti/sdo/fc/dman3/DMAN3CFG.xdc"", line 392: can't resolve name
WARNING: xdc.loadPackage('ti.sdo.fc.dman3'): package cycle: ti.sdo.fc.dman3
js:
"" Y:/WTSD_DucatiMMSW/ext_rel/packages/codec_engine_3_00_00_12/ packages/ti/sdo/ce/alg/Settings.xdt "",
line 26: TypeError: Cannot read property ""DMAN3CFG"" from undefined
(Y:\WTSD_DucatiMMSW\ext_re
l\packages\codec_engine_3_00_00_12\packages\ti\sdo\ce\alg\Se ttings.xdt#26)
line 26
line 128
gmake.exe: *** [package/cfg/out/h264vd_xm3.xdl] Error 1
gmake.exe: *** [package/cfg/out/h264vd_xm3.xdl] Deleting file
`package/cfg/out/h264vd_xm3.c'
Re: XDC Tool dependency [message #913 is a reply to message #880] |
Mon, 02 February 2009 14:37   |
XDCtools 3.15.* has not been released. We only have "early access"
releases available for those that require one or more capabilities not
currently supported in XDCtools 3.10.
If you need to fix on a stable release of XDCtools in the near-term, the
best option is to use the latest XDCtools 3.10.* release.
If you require other products that are leveraging XDCtools 3.15.*
capabilities, you may need to use a later version of 3.15; I see that
3.15.00.19 early access release is now available.
Based on the information below, the BIOS and Codec Engine teams can
probably provide the best advise about which version of XDCtools you
should use. I'll forward this to them.
> errors
> Build Errors:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Changes:
> family subdirectory
> Build Errors
> js:
> line 26
> line 128
FUDForum. Page generated in 0.03792 seconds
