| How to open a new connection wizard for a particular system type? [message #10580] |
Fri, 08 June 2007 12:55  |
Hi there,
I have the following problem.
From within my code I would like to open the wizard for a new connectio=
n =
to create a new connection of a certain system type. What I do is:
<codesnippet>
RSEMainNewConnectionWizard newConnWizard =3D new =
RSEMainNewConnectionWizard();
IRSESystemType systemType =3D =
RSECorePlugin.getTheCoreRegistry().getSystemTypeById("my.system.type ");
newConnWizard.restrictToSystemType(systemType);
Shell shell =3D getShell();
SystemWizardDialog dialog =3D null; =
dialog =3D new SystemWizardDialog(shell, newConnWizard); =
dialog.setBlockOnOpen(true);
dialog.open();
</codesnippet>
"my.system.type" is a custom type.
With DSDP 2.0M7 this code brings up something weird:
The main page of RSEMainNewConnectionWizard comes up displaying the tree=
with system types, restricted to "my.system.type" as the only entry, the=
'next' and 'Finish' buttons are disabled and there is nothing I can do.
In RSE 1.0.1 I did exactly the same (there using the class =
RSENewConnectionWizard) and it worked perfectly: there was no system typ=
e =
selection necessary as I restricted the wizard to a particular kind. =
Instead the connectionpage was displayed immediately. Exactly what I nee=
d.
Looking at the code of RSEMainNewConnectionWizard I can see that in the =
case of "onlySystemType" no other pages are added to wizard. Why's that?=
The other thing is that with RSE 1.0.1 I did this:
<codesnippet>
dialog.open();
if (!dialog.wasCancelled()) {
// Select the newly created host
Object output =3D newConnWizard.getOutputObject();
// some code here
</codesnippet>
This does not work either as getOutputObject is gone from the wizard. Ho=
w =
do I get the handle to the newly created IHost?
Andreas
| Re: How to open a new connection wizard for a particular system type? [message #12002 is a reply to message #10580] |
Tue, 26 June 2007 15:22  |
Hello Andreas,
could you try again with CVS HEAD?
We fixed the "getOutputObject" issue, and chances are that the
restrictToSystemType() thing should also work. If not, please file a bug.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Andreas Schik wrote:
> Hi there,
> connection to create a new connection of a certain system type. What I
> do is:
> <codesnippet>
> RSEMainNewConnectionWizard newConnWizard = new
> Shell shell = getShell();
> SystemWizardDialog dialog = null;
> dialog = new SystemWizardDialog(shell, newConnWizard);
> dialog.open();
> </codesnippet>
> type selection necessary as I restricted the wizard to a particular
> kind. Instead the connectionpage was displayed immediately. Exactly what
> I need.
> <codesnippet>
> dialog.open();
> Object output = newConnWizard.getOutputObject();
> // some code here
> </codesnippet>
> How do I get the handle to the newly created IHost?
> Andreas
| Re: How to open a new connection wizard for a particular system type? [message #568538 is a reply to message #10580] |
Hello Andreas,
Martin Oberhuber
> Hi there,
> do is:
> <codesnippet>
> dialog.open();
> </codesnippet>
> I need.
> <codesnippet>
> dialog.open();
> // some code here
> </codesnippet>
> Andreas
FUDForum. Page generated in 0.10023 seconds
