Home » Language IDEs » ServerTools (WTP) » Can't debug JSP pages
Can't debug JSP pages [message #115794] Mon, 04 July 2005 09:36 Go to next message
I installed Eclipse 3.1 and M5 WTP.
I created a new "Dynamic Web Projects" from the J2EE perspective.
I added one jsp page and started the server with "debug".
Unfortunately my break poinst are ignored. Do I have to setup anything
to debug jsp pages?
Oli
ps. "Open Resource" (Ctrl-Shift-R) shows every JSP twice. Once in
WebContent and in .deployable. Is it possible to turn that off?
Re: Can't debug JSP pages [message #115808 is a reply to message #115794] Mon, 04 July 2005 09:49 Go to previous messageGo to next message
Originally posted by: patrick.smart.gmail.com
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg04 264.html
Does that reply to your question?
Patrick
Re: Can't debug JSP pages [message #115820 is a reply to message #115808] Mon, 04 July 2005 09:51 Go to previous messageGo to next message
> Patrick
I'm using tomcat 5.0.28. Any other idea?
Oli
Re: Can't debug JSP pages [message #115898 is a reply to message #115820] Mon, 04 July 2005 12:54 Go to previous messageGo to next message
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg03 182.html
Apparently, you're not the only one to have the issue with that version.
Maybe you could try another one...
Patrick
Re: Can't debug JSP pages [message #116106 is a reply to message #115794] Mon, 04 July 2005 23:15 Go to previous messageGo to next message
> to debug jsp pages?
> Oli
No, I just tried it using WTP M5 with Apache Tomcat 5.0.29 and it
stopped on my breakpoints and made the local variables visible as
expected. The .deployables folder is currently required on Flexible
projects and to function properly I think you need to allow Eclipse
to Build Automatically. With that said, I did run into the same
problem at first when I had Build Automatically turned off--a Clean
and Rebuild of my Flexible project solved that.
So, if you have Build Automatically disabled, try cleaning and
rebuilding the project manually.
- Nitin
Re: Can't debug JSP pages [message #116194 is a reply to message #115898] Tue, 05 July 2005 04:11 Go to previous message
You tried Tomcat 5.5.9 and it works. Thanks for the idea.
Previous Topic:Why are the JSTL tags are not understood by the JSP editor?
Next Topic:Deploymentdescriptor works only with JBoss4.0
Current Time: Sat Jul 26 16:05:19 EDT 2025
Powered by FUDForum. Page generated in 0.04994 seconds
