How to insert a menu by VE [message #115772] |
Tue, 24 January 2006 14:27  |
Originally posted by: alexandre.gzsistemas.com.br
Hi all,
I'm trying to insert a menu into a Shell but I can't find how to do it.
I've searched on newsgroups, helps, but I didn't find a solution.
Can anyone help me ?
Re: How to insert a menu by VE [message #115884 is a reply to message #115871] |
Wed, 25 January 2006 13:44  |
Rich Kulp escreveu:
> Just check and make sure that you have VE 1.1.0.1 installed if you are
> working on Eclipse 3.1.x. If you just did an install for the first time
> of VE from the update manager it will pick up VE 1.1.0. You will need to
> run update again to get it up to 1.1.0.1.
> VE 1.1.0.1 has a palette category labeled SWT Menus.
>> I suppose I'm using the latest version because I downloaded and
>> installed from Update Manager yesterday !
Thank you Rich.
Now it works !
Re: How to insert a menu by VE [message #611821 is a reply to message #115772] |
Tue, 24 January 2006 14:53  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Drop a menubar on the shell. Then you can drop menus on the menubar in
the JavaBeans viewer.
Alexandre Boaventura wrote:
> Hi all,
Rich Kulp
Re: How to insert a menu by VE [message #611830 is a reply to message #115784] |
Wed, 25 January 2006 07:02  |
Rich Kulp escreveu:
>> Hi all,
>> it. I've searched on newsgroups, helps, but I didn't find a solution.
Well, a menubar component is not available at swt pallete. What could be
wrong ?
Re: How to insert a menu by VE [message #611833 is a reply to message #115835] |
Wed, 25 January 2006 07:03  |
Enric Tordera escreveu:
> "Alexandre Boaventura" <alexandre@gzsistemas.com.br> escribió en el mensaje
> news:dr5v38$3s7$1@utils.eclipse.org...
>> Hi all,
> Make sure you are using the last version of Visual Editor. If not sure try
> updating from the Help menu.
> Enric
Re: How to insert a menu by VE [message #611837 is a reply to message #115859] |
Wed, 25 January 2006 10:20  |
Rich Kulp
Re: How to insert a menu by VE [message #611839 is a reply to message #115871] |
Rich Kulp escreveu:
Thank you Rich.
Now it works !
FUDForum. Page generated in 0.08562 seconds
