Home » Archived » Test and Performance Tools Platform (TPTP) » piAgent don't scale
piAgent don't scale [message #10577] Thu, 17 March 2005 07:40 Go to next message
I should trace the execution time of an api (call we that method
'doIt'). If this method, inside call 1 other method, you get from
piAgent an execution time of 100ms. If calls 100 methods, the execution
time is 1000ms.
The problem is that the execution time taken without piAgent (using
currenttimemillis) for first case is higher than the second, because the
100 calls are faster that the single one (obviously very different
implementation).
It seems that there is a great overhead that is linear on the number of
the method invocations.
Note that I tried filtering only the 'doIt' method, but the overhead
still remains.
So is impossible to compare api that uses behind different architectures
with hyades?
best regards,
Luca
Re: piAgent don't scale [message #12487 is a reply to message #10577] Tue, 29 March 2005 05:47 Go to previous messageGo to next message
Luca Di Stefano wrote:
> time is 1000ms.
> implementation).
> still remains.
> with hyades?
> best regards,
> Luca
I said something wrong? No one have comments for that?
thanks anyway,
Luca
Re: piAgent don't scale [message #12528 is a reply to message #12487] Tue, 29 March 2005 15:42 Go to previous messageGo to next message
Hmm... I am having some trouble understanding the problem. Correct me if I
am wrong.
When running with "-XrunpiAgent":
doIt() -> call 1 method -> total time reported for doIt() is 100ms
doIt() -> call 100 method -> total time reported for doIt() is 1000ms
When running without "-XrunpiAgent" (and use currenttimemillis() instead):
doIt() -> call 1 method -> total time reported for doIt() is "x"ms
doIt() -> call 100 method -> total time reported for doIt() is "y"ms where
(y < x)? This doesn't sound right...
Samson
"Luca Di Stefano" <luca.distefano@wuerth-phoenix.com> wrote in message
news:d2bbpa$t12$2@news.eclipse.org...
> > Hi,
> > time is 1000ms.
> > implementation).
> > still remains.
> > with hyades?
> > best regards,
> > Luca
> thanks anyway,
> Luca
Re: piAgent don't scale [message #12549 is a reply to message #12528] Tue, 29 March 2005 16:29 Go to previous messageGo to next message
If I understand Luca correctly, the problem is that the overhead of the
profiler makes it impossible to evaluate algorithms that involve large
numbers of method invocations.
I that right?
"Samson Wai" <samwai@ca.ibm.com> wrote in message
news:d2celk$j2v$1@news.eclipse.org...
> am wrong.
> Samson
> > Hi,
> > > Hi,
execution
> > > time is 1000ms.
the
> > > implementation).
of
> > > still remains.
architectures
> > > with hyades?
> > > best regards,
> > > Luca
> > thanks anyway,
> > Luca
Re: piAgent don't scale [message #12630 is a reply to message #12528] Wed, 30 March 2005 08:22 Go to previous messageGo to next message
> am wrong.
it is so.
I should say that in the first case (doit() with 1 method invocation)
jni functions are involved, in the second is all 100% pure java. Maybe
that is the problem?
thanks,
Luca
> Samson
>>Hi,
>>>Hi,
>>>time is 1000ms.
>>>implementation).
>>>still remains.
>>>with hyades?
>>>best regards,
>>>Luca
>>thanks anyway,
>>Luca
Re: piAgent don't scale [message #12649 is a reply to message #12549] Wed, 30 March 2005 08:24 Go to previous messageGo to next message
> I that right?
it seems to be so.
thanks,
Luca
>>am wrong.
>>Samson
>>>Hi,
>>>>Hi,
> execution
>>>>time is 1000ms.
> the
>>>>implementation).
> of
>>>>still remains.
> architectures
>>>>with hyades?
>>>>best regards,
>>>>Luca
>>>thanks anyway,
>>>Luca
Re: piAgent don't scale [message #12761 is a reply to message #12630] Thu, 31 March 2005 15:58 Go to previous messageGo to next message
You are right about the JNI overhead. From the stats, the first call always
take the longest. The piAgent uses an internal hash table for storing
profiling information such as stacks, class loads, method, etc. and all
these are being populated when a class is first loaded and/or a method is
first called. That's why it is showing the first method took 100ms to
complete while the other 99 subsequent method takes (900/99) = 9.09ms to
complete.
Samson
news:d2e99f$vee$1@news.eclipse.org...
I
> > am wrong.
instead):
where
> it is so.
> thanks,
> Luca
> > Samson
> >>Hi,
> >>>Hi,
> >>>time is 1000ms.
the
> >>>implementation).
> >>>still remains.
architectures
> >>>with hyades?
> >>>best regards,
> >>>Luca
> >>thanks anyway,
> >>Luca
Re: piAgent don't scale [message #12783 is a reply to message #12761] Fri, 01 April 2005 04:52 Go to previous message
Hi Samson,
> complete.
Thanks for your clear answer.
There is a way to avoid this behavior for tracing java using JNI?
Luca
> Samson
>>Hi,
> I
>>>am wrong.
> instead):
> where
>>it is so.
>>thanks,
>>Luca
>>>Samson
>>>>Hi,
>>>>>Hi,
>>>>>time is 1000ms.
> the
>>>>>implementation).
>>>>>still remains.
> architectures
>>>>>with hyades?
>>>>>best regards,
>>>>>Luca
>>>>thanks anyway,
>>>>Luca
Previous Topic:How can I start?
Next Topic:Porting Custom Test Exec Demo to TPTP 4.0
Current Time: Mon Jul 21 21:17:04 EDT 2025
Powered by FUDForum. Page generated in 0.06238 seconds
