Home » Language IDEs » Java Development Tools (JDT) » automatic build disabled?
automatic build disabled? [message #115722] Tue, 11 November 2003 11:06 Go to next message
Hi all,
hopefully just a short question: So far eclipse always did a build
when I saved an edited file, i.e. I always used to do just a Control-S
to save the file and then I could start the newly-built program (which
I did using an external batch file (i.e. not using the eclipse Run
command)).
But today - for some strange reason - eclipse suddenly does not do
these automatic builds any more and I always have to select the
project first and then go via the menu Project => Build to trigger a
build, which I find tedious.
I am not aware of having modified anything with respect to that
behavior and I didn't find any config option to change this either.
So, what could cause Eclipse to suddenly not do these automatic
rebuilds any more? Is there some preference setting somewhere to
switch this automatic (re-)build on/off that I might accidentally have
flipped?
This is on Eclipse 3.0 (M4) from Oct. 10th, 2003 running on Windows
2000 (SP4)
Michael
Re: automatic build disabled? [message #115748 is a reply to message #115722] Tue, 11 November 2003 11:12 Go to previous messageGo to next message
Michael,
The setting I'm aware of is in
Window > Preferences > Workbench > Perform build automatically on resource
modification
HTH Graham
Re: automatic build disabled? [message #115761 is a reply to message #115722] Tue, 11 November 2003 11:14 Go to previous messageGo to next message
Originally posted by: eclipse.tkilla.ch
Michael Moser wrote:
> Hi all,
> command)).
> flipped?
For some reason, the autobuild preference seems to be turned off
occasionaly. Go to Window->Preferences, Workbench, "Perform build
automatically upon resource modification".
HTH
-tom
Re: automatic build disabled? [message #115800 is a reply to message #115748] Tue, 11 November 2003 12:26 Go to previous message
"Tom Eicher" <eclipse@tkilla.ch> wrote in message
news:bor1qq$qe2$1@eclipse.org...
> HTH
> -tom
"Graham Mead" <Graham.mead@fsmail.net> wrote in message
news:bor1q5$qhr$1@eclipse.org...
> Michael,
resource
> modification
> HTH Graham
Hi you both!
Thanks - that helped.
Stupid me - that's the VERY FIRST option on the VERY FIRST top level
preference tab, but somehow I had always overlooked that one and had
delved into the Build-Order, Java- and Run/Debug tabs instead
searching for a corresponding option...
From Tom's comments I conclude, that this occasional option-reset it a
known bug and that there is no need to submit that again...
Michael
Previous Topic:Eclipse Java style checking - run standalone?
Next Topic:Slow down eclipse
Current Time: Fri Jul 25 02:36:03 EDT 2025
Powered by FUDForum. Page generated in 0.05139 seconds
