which version to use with the last integration build of eclipse [message #115674] |
Wed, 04 February 2004 14:56  |
Originally posted by: emerson.tre-sc.gov.br
I tried to install the last integration build of GEF with the last
integration build of eclipse. I expand the GEF at eclipse root dir, but it
doens't show any restart warning at eclipse startup, as it used to be.
And when I tried to install a plugin that needs GEF it says that I doens't
have GEF installed:
"The bundle com.bonevich.eclipse.cvsgrapher [85] could not be resolved.
Reason: missing required bundle org.eclipse.gef,required bundle
org.eclipse.draw2d"
Any clues?
Re: which version to use with the last integration build of eclipse [message #116012 is a reply to message #115985] |
Thu, 05 February 2004 14:13  |
Now it worked.
In some versions ago, eclipse itserlf asked for a restart when finding an
detected change.
And there was an easier option directly at the help menu to detect changes
Maybe this option should be put back :P
Thanks!!!
Whitney Sorenson wrote:
> Have you checked to see if the GEF and Draw2d plugins show up in the
> Help->About Eclipse Platform->Plug-in Details page?
> If they are not there, try going to Help->Software Updates->Manage
> Configuration. Right click on Eclipse Platform, and click on Detected
> changes.. GEF should be there, and you can click "Finish" to complete the
> installation.
> "Emerson Cargnin" <emerson@tre-sc.gov.br> wrote in message
> news:bvtopq$t24$1@eclipse.org...
> > Didn't work...
> > I changed : plugins/org.eclipse.gef_3.0.0/plugin.xml
> > <import plugin="org.eclipse.osgi"/>
> > <added> <import plugin="org.eclipse.core.runtime.compatibility"/>
> > </requires>
> > But it gives any different sign...
> > > The latest integration build of GEF doesn't work with the latest
> Integration
> > > build of Eclipse. You may want to try the latest from CVS, wait for the
> next
> > > Integration build, or add org.eclipse.core.runtime.compatibility as a
> > > required plugin to the GEF plugin.xml.
> > > news:bvripv$gij$1@eclipse.org...
> but it
> doens't
> > > > have GEF installed:
> resolved.
> > > > org.eclipse.draw2d"
> > > > Any clues?
FUDForum. Page generated in 0.07644 seconds
