Home » Language IDEs » ServerTools (WTP) » cannot start Jonas serverr from eclipse
cannot start Jonas serverr from eclipse [message #115639] |
Sun, 03 July 2005 16:24  |
Originally posted by: enrique.martinez.gmail.com
Hi there,
I downloaded and installed the wtp for eclipse successfully and started
to play around with the example "WTP Tutorials - Testing the Creation of
Annotated and Non-Annotated Servlets in the Web Tools Project"
( http://www.eclipse.org/webtools/jst/components/j2ee/scenario s/ServletScenario.html).
I followed all the steps, and configured a new server on
windows>preference>server>installed runtimes but insted of Tomcat I'm
using Jonas 4.4.2 so I selected "Generic Jonas 4.1.4".
The problem raises when I try to start jonas from eclipse. It begins
well with the console showing the output as it is starting, but some
seconds after that eclipse opens an error message saying "Server JonAS
4.1.4(Generic)failed to start", but I don't have any error on the
console and also everytime that I try it, it stops in a different part
of the raising jonas' process. Seems, like a time out issue, or
something like that, but I'm not sure.
Also I see that on windows>preference>server there is a configuration
for the "Relative speed machine" and I set that to "Very slow". But the
problem is still there.
If I start jonas from a console (outside eclipse) I have no problem, and
also as the war file was compiled and deployed successfully by eclipse
on the autoload folder, I can see my HellowWorld page working fine. So
the only problem is why I cannot start jonas from eclipse.
Later on, without changing anything, I finally started it, but just
once. I played around with it a little to see that everything was
working fine and I stopped it to try one more time. But once again I
cannot start it.
As I was able to start it, at least one time, I think the server is
configured fine, but I keep on thinking in some kind of time out or
something.
Anyone has an idea?
Re: cannot start Jonas serverr from eclipse [message #115665 is a reply to message #115639] |
Sun, 03 July 2005 18:40   |
Enrique wrote:
> Hi there,
> cannot start it.
> something.
> Anyone has an idea?
I'm able to start Jonas from Eclipse if I match the two versions. Jonas
4.1.4 with "Generic Jonas 4.1.4". I've generally found out WTP server
configurations to be very picky about the version. "Generic Jonas 4.1.4"
really means that it only works on Jonas 4.1.4.
* Janne Kario
Re: cannot start Jonas serverr from eclipse [message #123137 is a reply to message #115665] |
Tue, 19 July 2005 14:35  |
Janne Kario wrote:
> Enrique wrote:
>> Hi there,
>> cannot start it.
>> something.
>> Anyone has an idea?
> * Janne Kario
Sorry for the delay, I've been out for a while.
Now I have eclipse with wtp and Jonas 4.1.4 working fine. It was a bad
configuration (sorry my misstake). I didn't tryed with other Jonas'
versions but I will and tell the results.
I just wanted to close this thread with a good news :D
Now I have other questions but I will open a new thread.
- Enrique.
Current Time: Fri Jul 18 04:08:04 EDT 2025
Powered by FUDForum. Page generated in 1.16683 seconds
