Tomcat 5.0 on Gentoo with WTP [message #115611] |
Sun, 03 July 2005 12:18  |
how can i configure Eclipse Web Tools for Tomcat server on Gentoo ? Tomcat 5 on
Gentoo is installed in following way :
/usr/share/tomcat-5/bin
/usr/share/tomcat-5/common/endorsed
/usr/share/tomcat-5/common/lib
/usr/share/tomcat-5/lib
/usr/share/tomcat-5/server/lib
/usr/share/tomcat-5/server/webapps (standard webapps - admin, manager)
/var/lib/tomcat-5/default/conf
/var/lib/tomcat-5/default/logs
/var/lib/tomcat-5/default/temp
/var/lib/tomcat-5/default/webapps (other webapps)
/var/lib/tomcat-5/default/work
So, Tomcat 5 is divided into 2 parts and due this Eclipse says that any of two directories
(/usr/share/tomcat-5 or /var/lib/tomcat-5) is not valid Tomcat 5 installation directory.
It's somehow possible to make it work with WTP ? Or should i create special tomcat-5
installation just for development ?
Frantisek Augusztin
Re: Tomcat 5.0 on Gentoo with WTP [message #116279 is a reply to message #115611] |
Tue, 05 July 2005 09:26  |
Hi Frantisek,
You are welcome to an enhancement request in Bug database to see if you
can have your use case covered. Tomcat runtimes and servers don't
currently support separately specified catalina_home and catalina_base.
However, the default Tomcat server does run in this fashion, but
doesn't allow you to specify the catalina_base. It will appear under a
directory like ".metadata\.plugins\org.eclipse.wst.server.core\tmp?".
If you create multiple servers from the same runtime, you will get
multiple "tmp?" directories, if that is in any way useful.
Larry
Frantisek Augusztin wrote:
> Hello,
> Thanks
> Frantisek Augusztin
FUDForum. Page generated in 0.03586 seconds
