Home » Eclipse Projects » Equinox » Compressed metadata generation using product build
Compressed metadata generation using product build [message #115553] Wed, 30 July 2008 08:52 Go to next message
Hi all,
I'd like to know if there are any properties to be added in
build.properties in order to generate compressed metadata (content.jar and
artifacts.jar) - like "-compress" parameter that can be used in feature
metadata generation.
I verified that AssembleConfigScriptGenerator does not write the
p2.generator task with the parameter "-compress" and there are no
constants defined in IBuildPropertiesConstants that references this
parameter as well.
-- Euclides
Re: Compressed metadata generation using product build [message #115567 is a reply to message #115553] Wed, 30 July 2008 11:07 Go to previous message
There is no way to do this currently.
See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=222962
-Andrew
Euclides Arcoverde wrote:
> Hi all,
> and artifacts.jar) - like "-compress" parameter that can be used in
> feature metadata generation.
> parameter as well.
> -- Euclides
Previous Topic:Eclipse 3.4 JAAS integration
Next Topic:P2 Mirroring - Missing metadata
Current Time: Tue Jul 22 02:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.26243 seconds
