Home » Language IDEs » C / C++ IDE (CDT) » JNI code debug?
JNI code debug? [message #115551] Mon, 16 August 2004 10:08 Go to next message
Originally posted by: schifane.di.unito.it
I'm writing a Java application with native code in C (using JNI). I can
debug only the Java code by means of the standard Eclipse's debugger. It
stops at breakpoints made in java code, but it does not stop at
breakpoints made in C code... How I can debug the C code?
Rossano S.
Re: JNI code debug? [message #115852 is a reply to message #115551] Tue, 17 August 2004 09:09 Go to previous messageGo to next message
We have not yet gotten integrated CDT/JDT debugging working yet.
"Schifanella Rossano" <schifane@di.unito.it> wrote in message
news:cfqes2$tb4$1@eclipse.org...
> Thanks
> Rossano S.
Re: JNI code debug? [message #115903 is a reply to message #115551] Tue, 17 August 2004 09:14 Go to previous message
Originally posted by: alain.nowhere.ca
Schifanella Rossano wrote:
There is simply no easy way to do this at the moment.
The integration of the different debuggers is just not there.
Basically, you could reattach to the VM, put a breakpoint at the right
function name, continue ... but I'm glossing over a lot of things.
Somebody should right a howto about this so we can post it to this group
this question come back every so often.
Previous Topic:Change C++ source file extension
Next Topic:C++ Configuration Problem
Current Time: Tue Jul 22 03:16:21 EDT 2025
Powered by FUDForum. Page generated in 0.06089 seconds
