Home » Eclipse Projects » JFace » int / float values in a table
int / float values in a table [message #10554] Thu, 28 May 2009 04:22 Go to next message
unfortunately I have some problems with my table. I have several columns
which only accept floats or ints as input, which is why I created a
FloatCellEditor, respectively an IntegerCellEditor.
Everything works fine, except of a visual thing:
If i enter a cell and activate it (so that the "old" value gets
highlighted and the cursor blinks) the previously empty cell is filled
with the value 0. Well, this seems logical because the value of this
cell in the model is actually 0, which is the default.
If the cell is deactivated, it becomes cleared, because my LabelProvider
checks if a value is 0 and then returns an empty String instead.
How can I achieve this behaviour for an active cell?
Lars
Re: int / float values in a table [message #10788 is a reply to message #10554] Thu, 04 June 2009 09:10 Go to previous messageGo to next message
Hi Lars,
Wouldn't you want to display a zero if that's the value in your model
object? I would expect the empty string to stand for "no value" (null) - you
could implement this by using java.lang.Float instead of float, or
java.lang.Integer instead of int.
Boris
"Lars Bischoff" <molehillrocker@googlemail.com> wrote in message
news:gvlhko$mkv$1@build.eclipse.org...
> Hello,
> with the value 0. Well, this seems logical because the value of this cell
> Best regards,
> Lars
Re: int / float values in a table [message #12004 is a reply to message #10788] Fri, 05 June 2009 04:30 Go to previous message
Hello Boris,
using Float and Integer instead of the corresponding primitive types was
my first thought too, but unfortunately this is not conducive to the
performance. Since my tables contain >10.000 rows where each row has ~20
columns I'd need 10.000 row objects + (10.000 * 20 cells) = 210.000
objects per table. However, there are at least 10 tables open at the
same time...
I figured out a little workaround now, if the user deletes a cell-entry
via delete or backspace key, I just write a zero back into the model :)
Lars
Boris Bokowski schrieb:
> Hi Lars,
> Boris
>> Hello,
>> Best regards,
>> Lars
Previous Topic:Enable/disable custom toolbar shortcuts automatically
Next Topic:Invoking WIzardNewFileCreator
Current Time: Tue Jul 22 01:50:48 EDT 2025
Powered by FUDForum. Page generated in 0.27622 seconds
