Home » Modeling » GMF (Graphical Modeling Framework) » Generated diagram editor's Undo-Redo history
Generated diagram editor's Undo-Redo history [message #115478] Thu, 29 March 2007 14:05 Go to next message
Originally posted by: NOSPAM.xyz.com
If I create a new Project, then create and open
a new diagram resource and then access the "Edit" menu
I can see an enabled "Undo" item there. It turns out that
it is actually a "Undo Create New Project" action, so if one
selects it, the new projects is of course removed taking the
new diagram resource along with it, closing the editor, etc...
I am not sure if this is a bug or is it the expected behavior?
BTW, who provides for the Undo and Redo global actions?
The generated editor contributes to
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.globalActi onHandlerProviders ">
providers for "Save", "Copy", "Paste", etc., but there is nothing
about "Undo" and "Redo".
The default text editor behaves the same way, so most
likely this isn't a bug. It looks odd to me , though...
Cheers
Re: Generated diagram editor's Undo-Redo history [message #115699 is a reply to message #115478] Fri, 30 March 2007 09:03 Go to previous messageGo to next message
Marian,
As far as I know this is behaviour deliberately introduced by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162964. The global undo
context is used when there is no activity in a specific undo context
(which in this case is the undo context for the diagram editor). Note
that this is also the cause of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=173361.
Linda
> <extension
> Cheers
Re: Generated diagram editor's Undo-Redo history [message #115712 is a reply to message #115699] Fri, 30 March 2007 11:05 Go to previous messageGo to next message
Hi Linda,
thank you for the references.
I agree that the solution they came up with in
is a reasonable compromise.
I also noticed myself the problem you described in
Thanks for saving me the efford to report it.
"Linda Damus" <ldamus@ca.ibm.com> wrote in message
news:euj1rh$5r9$1@build.eclipse.org...
> Marian,
> Linda
>> <extension
>> Cheers
Re: Generated diagram editor's Undo-Redo history [message #115724 is a reply to message #115712] Fri, 30 March 2007 11:18 Go to previous message
Still,
there is a minor glitch to the solution of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162964 :
When there is nothing in the local history of the fresh editor instance
the menu item label is just "Undo" instead of
"Undo New Project"
"Marian" <NOSPAM@xyz.com> wrote in message
news:euj5bl$hct$1@build.eclipse.org...
> Hi Linda,
>> Marian,
>> Regards,
>> Linda
>>> <extension
>>> Cheers
Previous Topic:Can't show the project explorer properly in RCP
Next Topic:Changing displayed names in popup bar creation tool
Current Time: Sat Jul 26 19:40:15 EDT 2025
Powered by FUDForum. Page generated in 0.05326 seconds
