Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo - NamedQuery annotation support
Teneo - NamedQuery annotation support [message #115394] Sun, 23 March 2008 02:37 Go to next message
I am trying to extend the hibernate annotation support for NamedQuery. I
have added a new NamedQuery element to hbannotation.ecore. Then I am trying
to extend the HibernateMappingGenerator with a new NamedQueryMapper. But I
am not able to understand how I can process the NamedQuery annotation from
the new Mapper I am trying to create. Please help me understand this so that
I can implement NamedQuery support hibernate.
Phaneesh
Re: Teneo - NamedQuery annotation support [message #115420 is a reply to message #115394] Sun, 23 March 2008 05:28 Go to previous messageGo to next message
Hi Phaneesh,
After adding the namedquery annotation to the hbannotation.ecore: Then you should add the NamedQuery
element (Upper Bound==-1) as an ereference to the HbAnnotatedEPackage and the HbAnnotatedEClass.
Then reload the hbannotation.genmodel and regenerate the source code.
The next step is to create the correct hibernate mapping.
The global namedqueries can be processed as follows: see the processPersistentClasses method in the
HibernateMappingGenerator. As the namedquery should be placed at the end of the mapping file I would
add a for loop (at the end of the try block) which walks through the paModel.getPaEPackages and
for each package gets the namedqueries and create the correct elements and add to the mapping
document (see other mappers for examples).
The namedqueries on class level can be processed as follows: see the method processEntity in the
EntityMapper class. As the namedquery should be added to the end I would add the handling of the
namedquery to the end of this method. The namedqueries can be handled in the same way as on package
level (so it makes probably sense to have a separate global method somewhere handling these).
If you don't want to change the standard then the above changes in the HibernateMappingGenerator and
EntityMapper can be made in custom subclasses. Teneo can be directed to use your subclasses using
the Teneo ExtensionManager approach (http://www.elver.org/hibernate/extensions.html).
To be complete, the NamedQuery element in hbannotation.ecore should have a Target eannotation
pointing to EClass and one pointing to EPackage (see the other annotations for an example). Then the
xsd generator (see HbMappingSchemaGenerator) knows where to create an xsd element. Note that the
HbMappingSchemaGenerator currently is set to create an xsd in a path which is specific for my
computer so you would need to change that before running the xsd generator.
Afaics the above description is complete, let me know if I missed something. And ofcourse feel free
to contribute any changes to Teneo when it works for you (just send me a patch)...
gr. Martin
Phaneesh wrote:
> trying to extend the HibernateMappingGenerator with a new
> NamedQueryMapper. But I am not able to understand how I can process the
> NamedQuery annotation from the new Mapper I am trying to create. Please
> help me understand this so that I can implement NamedQuery support
> hibernate.
> Thanks
> Phaneesh
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo - NamedQuery annotation support [message #115463 is a reply to message #115420] Sun, 23 March 2008 11:14 Go to previous messageGo to next message
Hi Martin,
Thanks for a very descriptive explanation. As soon as I get it working I
will send you the patch. If I have any queries regarding this will ping you
back.
Phaneesh
"Martin Taal" <mtaal@elver.org> wrote in message
news:fs57t1$79l$1@build.eclipse.org...
> Hi Phaneesh,
> should add the NamedQuery element (Upper Bound==-1) as an ereference to
> the HbAnnotatedEPackage and the HbAnnotatedEClass. Then reload the
> of the mapping file I would add a for loop (at the end of the try block)
> which walks through the paModel.getPaEPackages and for each package gets
> method processEntity in the EntityMapper class. As the namedquery should
> be added to the end I would add the handling of the namedquery to the end
> package level (so it makes probably sense to have a separate global method
> HibernateMappingGenerator and EntityMapper can be made in custom
> subclasses. Teneo can be directed to use your subclasses using the Teneo
> Target eannotation pointing to EClass and one pointing to EPackage (see
> the other annotations for an example). Then the xsd generator (see
> the HbMappingSchemaGenerator currently is set to create an xsd in a path
> which is specific for my computer so you would need to change that before
> something. And ofcourse feel free to contribute any changes to Teneo when
> gr. Martin
> Phaneesh wrote:
>> hibernate.
>> Thanks
>> Phaneesh
> The Netherlands
Re: Teneo - NamedQuery annotation support [message #115552 is a reply to message #115463] Mon, 24 March 2008 03:34 Go to previous messageGo to next message
Hi Martin,
Please find the attached patch. I have added NamedQuery annotation support
for Hibernate mapper. I have followed the first approach.
Please let me know if you face problems integrating the patch.
Phaneesh
"Phaneesh" <n_phaneesh17010@yahoo.com> wrote in message
news:fs5s4p$ka$1@build.eclipse.org...
> Hi Martin,
> you
> back.
> Regards
> Phaneesh
>> Hi Phaneesh,
>> you
>> method
>> a
>> gr. Martin
>> Phaneesh wrote:
>>> Hi,
>>> hibernate.
>>> Thanks
>>> Phaneesh
>> The Netherlands
Re: Teneo - NamedQuery annotation support [message #115578 is a reply to message #115552] Mon, 24 March 2008 17:10 Go to previous messageGo to next message
Hi Phaneesh,
Thanks, I will take a look at/apply it within a few days.
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Re: Teneo - NamedQuery annotation support [message #116065 is a reply to message #115552] Thu, 27 March 2008 05:05 Go to previous message
Hi Phaneesh,
One administrative question, can you open a bugzilla and attach your patch to it? Afaik because of
licensing reasons contributions should be send in as part of a bugzilla.
Thanks!
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Re: Teneo - NamedQuery annotation support [message #615955 is a reply to message #115394] Sun, 23 March 2008 05:28 Go to previous message
Hi Phaneesh,
gr. Martin
Phaneesh wrote:
> hibernate.
> Thanks
> Phaneesh
The Netherlands
Re: Teneo - NamedQuery annotation support [message #615958 is a reply to message #115420] Sun, 23 March 2008 11:14 Go to previous message
Hi Martin,
back.
Phaneesh
> Hi Phaneesh,
> gr. Martin
> Phaneesh wrote:
>> hibernate.
>> Thanks
>> Phaneesh
> The Netherlands
Re: Teneo - NamedQuery annotation support [message #615965 is a reply to message #115463] Mon, 24 March 2008 03:34 Go to previous message
Hi Martin,
Phaneesh
> Hi Martin,
> you
> back.
> Regards
> Phaneesh
>> Hi Phaneesh,
>> you
>> method
>> a
>> gr. Martin
>> Phaneesh wrote:
>>> Hi,
>>> hibernate.
>>> Thanks
>>> Phaneesh
>> The Netherlands
Re: Teneo - NamedQuery annotation support [message #615967 is a reply to message #115552] Mon, 24 March 2008 17:10 Go to previous message
Hi Phaneesh,
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Re: Teneo - NamedQuery annotation support [message #616004 is a reply to message #115552] Thu, 27 March 2008 05:05 Go to previous message
Hi Phaneesh,
Thanks!
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Previous Topic:Extra Primary Key Join Column
Next Topic:[Teneo] NoSuchMethodError exception when trying to add element to an EList
Current Time: Sun Nov 09 01:20:09 EST 2025
Powered by FUDForum. Page generated in 0.05354 seconds
