ReferenceError: "BarSeriesImpl" is not defined. at line X of chart script:'' [message #876812] |
Fri, 25 May 2012 10:08 |
Dejan Vujanic Messages: 67 Registered: October 2011 |
Member |
My report works fine in birt.
But when I import in some system (IBM maximo) I am getting this error instead of displaying the bar chart:
ReferenceError: "BarSeriesImpl" is not defined. at line 8 of chart script:''
I used this script to show me some values on Bar chart.
importPackage( Packages.java.util );
importPackage( Packages.org.eclipse.birt.chart.model.type.impl );
function afterDataSetFilled(series, dataSet, icsc)
if( series.getClass() == BarSeriesImpl ){
var inv =
parseInt(icsc.getExternalContext().getScriptable().getPersistentGlobalVariable("IN"));
var outv =
parseInt(icsc.getExternalContext().getScriptable().getPersistentGlobalVariable("OUT"));
var canv =
parseInt(icsc.getExternalContext().getScriptable().getPersistentGlobalVariable("CANCELED"));
var narray1 = new ArrayList( );
narray1.add(inv);
narray1.add(outv);
narray1.add(canv);
dataSet.setValues(narray1);
}else{
var catArray = new ArrayList();
catArray.add("IN");
catArray.add("OUT");
catArray.add("CANCELED");
dataSet.setValues(catArray);
How to solve this? Does I have to impost somehow this class in my system or ..?
I am sending an example which works fine in BIRT
Thank you
[Updated on: Fri, 25 May 2012 12:14] Report message to a moderator
FUDForum. Page generated in 0.03099 seconds
