No File | New | Web project menu available [message #115259] |
Fri, 01 July 2005 12:16  |
Originally posted by: jominsky.fcg.com
I've installed Eclipse 3.1 and the latest stable builds for EMF, GEF, and
JEM as well as the WebTools M5 runtime. I'm able to configure a server
through the Preferences, but I cannot create a new Web project as the menu
does not exist. I even checked in the Window | Customize Perspective for
the Submenu New, but it does not display there either. I'm just trying to
get this up and running. Any ideas? Thanks.
Jon
Re: No File | New | Web project menu available [message #119864 is a reply to message #117964] |
Tue, 12 July 2005 08:47   |
Originally posted by: w.decker.ing.diba.de
I have the same problem as denis;
My Installation is as follows:
new installation of eclipse 3.1
then wtp-sdk-1.0M5.zip
Only thing is that I run it with an existing workspace.
I ran eclipse with -clean option
But there is no Web project at all
I also have the server perspective, so WTP seems to be there (at least
partly)
Any Ideas?
thanks,
Wolfgang
Fabio Da Soghe wrote:
> denis ha scritto:
>>> Does the Web category show up when you choose "Other..."?
>> I've the same problem as Jon and in my case, the Web category never
>> appear, neither in open perpective/other, nor customize perpective/new.
>> The only reference I found after installing WTP is the server view.
>> Thanks
>> Denis
> Well, the only thing I can think of is there's something wrong with the
> installation. Maybe you didn't selected the right packages? I used,
> besides the requirements listed in the WTP download page, the sdk
> version of the WTP:
http://download.eclipse.org/webtools/downloads/drops/S-1.0M5 -200506302219/wtp-sdk-1.0M5.zip
> I unzipped all the files in the same directory and executed eclipse from
> there, as usual.
> Could you explain in details what you did and which files you used to
> install WTP?
FUDForum. Page generated in 0.04999 seconds
