Home » Archived » BIRT » Unable to display BIRT chart report in JSP page
Unable to display BIRT chart report in JSP page [message #115245] Wed, 25 January 2006 03:47 Go to next message
hi duds,
i created birt CHART report using BIRT report disigner.
after that i am accessing that in JSP but i am unable to display it.
same time i generated birt simple report( which contain TABLE ) .
but i am able to display the table report in JSP
Could u help me how to display Chart report in JSP.
Venkata r
Re: Unable to display BIRT chart report in JSP page [message #115295 is a reply to message #115245] Wed, 25 January 2006 04:55 Go to previous messageGo to next message
hi floks ,
it's urgent solution
please help me
Re: Unable to display BIRT chart report in JSP page [message #115346 is a reply to message #115245] Wed, 25 January 2006 05:18 Go to previous messageGo to next message
I can help you, but I need more information. Can you send me your report
design and jsp code so I can take a look? Do you see any error message in
the log or elsewhere?
Are you sure to have deployed your application correctly? Please check this
page: http://www.eclipse.org/birt/deploy/
David Michonneau
BIRT Committer
"venkata r" <venkatar@euclid.com> wrote in message
news:f29482eeb394f8a39a7ffb7bc6ab2daa$1@www.eclipse.org...
> hi duds,
> Venkata r
Re: Unable to display BIRT chart report in JSP page [message #115431 is a reply to message #115346] Wed, 25 January 2006 06:24 Go to previous messageGo to next message
hi David Michonneau,
thanks for immediate reply.
this is Java file
public String selectReport(){
System.out.println("###########ReportBean.selectReport()
Started########");
String IKGO_HOME = System.getProperty("ikigo.home");
String reportDir =IKGO_HOME + "\\"+"reportTemplates";
BirtReportBinder birtReportBinder = BirtReportBinder.getInstance();
try{
FacesContext facesContext = FacesContext.getCurrentInstance();
Map params =
facesContext.getExternalContext().getRequestParameterMap();
String source =(String)params.get("source");
StringTokenizer stk=new StringTokenizer(source,":");
stk.nextToken();stk.nextToken();
String reportIndex=stk.nextToken();
String reportName=(String)reportList.get(Integer.parseInt(reportInd ex));
AdfFacesContext afContext = AdfFacesContext.getCurrentInstance();
String reportName
=(String)afContext.getProcessScope().get("reportName");
System.out.println("$$$$$$$$$ Report Name : "+reportName);
String extName =".rptdesign";
String reportPath = reportDir+"\\"+reportName+extName;
System.out.println("$$$$$$$$$ Report Path : "+reportPath);
Report reportObj = birtReportBinder.load(reportPath);
ArrayList promptsList = reportObj.getPrompts();
ByteArrayOutputStream byteArrayOutputStreamObj = new
ByteArrayOutputStream();
Iterator iter=promptsList.iterator();
while(iter.hasNext()){
Prompt prmpt=(Prompt)iter.next();
if(prmpt.getSelectionList()!=null){
Iterator
iterSelectList=prmpt.getSelectionList().iterator();
List selectList=new ArrayList();
while(iterSelectList.hasNext()){
SelectItem selectItem=new SelectItem();
ParameterSelectionChoice
paramChoice=(ParameterSelectionChoice)iterSelectList.next();
selectItem.setLabel(paramChoice.getLabel());
System.out.println("class of value"
+paramChoice.getValue().getClass());
if(paramChoice.getValue() instanceof String){
selectItem.setValue(paramChoice.getValue());
}else{
selectItem.setValue(paramChoice.getValue().toString());
selectList.add(selectItem);
prmpt.setSelectionList(selectList);
HttpSession session
=(HttpSession)facesContext.getExternalContext().getSession(f alse);
int count = promptsList.size();
if (count == 0){
ReportResult reportResultObj =
birtReportBinder.execute(reportObj,byteArrayOutputStreamObj) ;
session.setAttribute("OutputStreamObj",byteArrayOutputStreamObj);
return "goto_reportResults";
}else{
setReportObj(reportObj);
return "goto_reportPrompts";
}catch(Exception e){
e.printStackTrace();
System.out.println("###########ReportBean.selectReport() Ended########");
return null;
This JSP file
<%@ page session="true" %>
<%@ page import="java.io.*" %>
<html>
<body>
ByteArrayOutputStream outputStream
=(ByteArrayOutputStream)sesssion.getAttribute("OutputStreamObj ");
out.print(outputStream);
</metrikus:tableformat>
<%@include file="../common/footer.inc" %>
</f:view>
</body>
</html>
Re: Unable to display BIRT chart report in JSP page [message #115444 is a reply to message #115346] Wed, 25 January 2006 06:26 Go to previous messageGo to next message
this is Java file
Started########");
try{
Map params =
String reportName
Iterator
}else{
HttpSession session
if (count == 0){
}else{
return null;
This JSP file
<html>
<body>
ByteArrayOutputStream outputStream =(ByteArrayOutputStream)
sesssion.getAttribute("OutputStreamObj");
</body>
</html>
ONE THING TO TELL U
Re: Unable to display BIRT chart report in JSP page [message #115454 is a reply to message #115346] Wed, 25 January 2006 06:27 Go to previous messageGo to next message
this is Java file
Started########");
try{
Map params =
String reportName
Iterator
}else{
HttpSession session
if (count == 0){
}else{
return null;
This JSP file
<html>
<body>
</body>
</html>
ONE THING TO TELL U
THIS IS WORKING FINE WITH GENERAL TABLE REPORTS
BUT ITS PROBLEM WITH CHART REPORTS
PLEASE KINDLY HELP ME BECAUSE THIS IS URGENT SOLTION
THANK U
VENKATA r
Re: Unable to display BIRT chart report in JSP page [message #115491 is a reply to message #115454] Wed, 25 January 2006 07:24 Go to previous messageGo to next message
Unfortunately this doesn't give me much information, what is
BirtReportBinder? I think it if it's working for table reports, it's really
a configuration problem. Can you try to put an image in your report and see
if it works?
Please double check the instructions there
http://www.eclipse.org/birt/deploy/ There is also a sample application
included to show reports in web apps, you might want to try it as well.
David Michonneau
BIRT Committer
"venkatar" <venkatar@euclid.com> wrote in message
news:f06ad21ad005b2a0faa3c58eb7f5a7c1$1@www.eclipse.org...
> this is Java file
> Started########");
> String IKGO_HOME = System.getProperty("ikigo.home"); String reportDir
> try{
> /* Map params =
> facesContext.getExternalContext().getRequestParameterMap(); String source
> =(String)params.get("source"); StringTokenizer stk=new
> AdfFacesContext afContext = AdfFacesContext.getCurrentInstance(); String
> reportName =(String)afContext.getProcessScope().get("reportName");
> Iterator iterSelectList=prmpt.getSelectionList().iterator();
> }else{
> HttpSession session
> =(HttpSession)facesContext.getExternalContext().getSession(f alse); int
> if (count == 0){
> return "goto_reportResults"; }else{
> return "goto_reportPrompts"; }
> return null;
> This JSP file
> <html>
> <body>
> </body>
> </html>
> ONE THING TO TELL U
> THANK U
> VENKATA r
Re: Unable to display BIRT chart report in JSP page [message #115557 is a reply to message #115491] Wed, 25 January 2006 07:51 Go to previous messageGo to next message
hi
i generated report with image using designer and tryed to display that in
JSP its not showing any error but its not displaying that image in JSP.
currently i am using birt-report-framework-1_0_1.zip to generate
reports.
Thank U,
venkatar
Re: Unable to display BIRT chart report in JSP page [message #115613 is a reply to message #115557] Wed, 25 January 2006 08:02 Go to previous messageGo to next message
This is a typical problem, please search the newsgroups for a resolution, it
has been answered several times I think. I quickly look and it seems you
need to call this at some point: HTMLRenderContext renderContext = new
HTMLRenderContext();
task.setContext(renderContext);
David Michonneau
BIRT Committer
news:1c8d3bb1df768e049286617fa34f0cef$1@www.eclipse.org...
> hi
> reports.
> Thank U,
> venkatar
Re: Unable to display BIRT chart report in JSP page [message #115651 is a reply to message #115613] Wed, 25 January 2006 08:48 Go to previous messageGo to next message
hi
i am using follwoing code for out put
HTMLRenderOption options = new HTMLRenderOption( );
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML) ;
options.setOutputStream(out);
task.setRenderOption( options );
task.setParameterValues( hmap );
i am displaying table reports with this code but not chart and image
reports
thanks
venkata r
Re: Unable to display BIRT chart report in JSP page [message #115677 is a reply to message #115651] Wed, 25 January 2006 09:20 Go to previous messageGo to next message
hi
i did not fine the code how to display report with image in previous posts.
could u send me code how to display a image or table or chart report in
standalone java program
please help me
using that code i can solve my problem
regards
venkata r
Re: Unable to display BIRT chart report in JSP page [message #115714 is a reply to message #115677] Wed, 25 January 2006 09:32 Go to previous messageGo to next message
There you go:
"Jun Zhai" <jzhai@actuate.com> wrote in message
news:<2769a605a0c7d26a642e29a2aeda9f52$1@www.eclipse.org>...
> Vikas,
> You have to set the image directory and base image URL right like this
> below:
> HTMLRenderContext renderContext = new HTMLRenderContext( );
> renderContext.setImageDirectory( EngineAccessor.ImageDirectory );
> renderContext.setBaseImageURL( request.getContextPath( ) +
> EngineAccessor.ImageBaseUrl );
> The image base url will be used to construct the URL of your embedded
> image/chart in the report. The image directory is the physical location
> engine uses to store generated image/chart. You have to make sure the
> image can be loaded by the url constructed from that base image url.
> For example in Birt viewer, we define image dir as "/report/images", base
> image url to be "/report/images" too. Also make sure the "/report/images"
> is available in your web app's doc root. This is a very simple and quick
> solution and you can develop more advanced one.
> Jun Zhai
"VENKATAR" <venkatar@euclid.com> wrote in message
news:85bf92fd718b656f86766c035df0ba03$1@www.eclipse.org...
> hi
> posts.
> please help me using that code i can solve my problem
> regards
> venkata r
Re: Unable to display BIRT chart report in JSP page [message #115828 is a reply to message #115714] Wed, 25 January 2006 09:59 Go to previous messageGo to next message
hi
i did not get from that code
if possible could u send me that total program
regards
venkata r
Re: Unable to display BIRT chart report in JSP page [message #115929 is a reply to message #115828] Wed, 25 January 2006 10:26 Go to previous messageGo to next message
Please check out the sample app:
http://www.eclipse.org/birt/index.php?page=deploy/engine.htm l#jump_10
David
"venkatar " <venkatar@euclid.com> wrote in message
news:0f70b2494f332ca9d96a99677c2b9ade$1@www.eclipse.org...
> hi i did not get from that code if possible could u send me that total
> program
> regards
> venkata r
Re: Unable to display BIRT chart report in JSP page [message #116984 is a reply to message #115929] Thu, 26 January 2006 02:09 Go to previous messageGo to next message
hi
i saw the RunReport.java program and i run that program
even this program is generating .html file for image reports but when i
saw that image.html file no image is displaying in that file.
the code is
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler( );
hc.setImageHandler( imageHandler );
config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc );
// HTML reports can have embedded images or charts. Set up the
configuration
// required to write these into a directory in the output directory.
// The HTMLCompleteImageHandler is one provided by BIRT for this purpose.
// Your application can create a customized version to provide alternative
// ways to handle images.
i am not clear with the above comments. so could u please explain me
clearly
regards
venkata r
here in the comments its cleanly expl
Re: Unable to display BIRT chart report in JSP page [message #117054 is a reply to message #116984] Thu, 26 January 2006 03:05 Go to previous message
Can you post a new message regarding this issue so that somebody familiar
with the sample app can help you?
David
news:0681ae012b6e26479e3e96e425885d10$1@www.eclipse.org...
> hi i saw the RunReport.java program and i run that program
> the code is
> configuration
> clearly
> regards venkata r
Previous Topic:Scripting issues
Next Topic:freaky attitude of the bottom-line
Current Time: Sat Aug 30 06:18:36 EDT 2025
Powered by FUDForum. Page generated in 0.07071 seconds
