Home » Language IDEs » C / C++ IDE (CDT) » Project path excludes
Project path excludes [message #115244] Thu, 12 August 2004 09:45 Go to next message
I'm working with Eclipse 3.0 and CDT2.0 20040811 build
I have a problem with adding exclude folder in the project paths.
I want that this exluded folder content won't be indexed and shown in C/C++
Project view. I tried to add exclude for project like '**/<foldername>/*.*'
or '<foldername>/*.*', but this didn't worked. So I want to know how to add
project path exclude?
Vaidotas
Re: Project path excludes [message #115628 is a reply to message #115244] Mon, 16 August 2004 10:29 Go to previous messageGo to next message
Originally posted by: alain.nowhere.ca
Vaidotas Radzius wrote:
How did you add the exclusions, for now only the std make project
offers this feature. And you should be able to just add the
folder you want to exclude.
Look at Property Page:
C/C++ Project paths
for Std make project, if you are familiar with the JDT source folder
you should find your ways in the source folder Tab of the CDT.
Please feel PR for any misbehaving.
Re: Project path excludes [message #115642 is a reply to message #115628] Mon, 16 August 2004 11:17 Go to previous messageGo to next message
Thank you for answer Alain. Please find my coments, I included below.
"alain" <alain@nowhere.ca> wrote in message news:cfqgbi$no$1@eclipse.org...
> > Hi,
C/C++
add
Yes I'm using std make projects and I have one folder in those projects
which I want to exclude from project.
> C/C++ Project paths
Yes to add exclusion for source I'm using this page, you mention above, but
when i add there i see indexer warnings on files which are in excluded
folder and in C\C++ project view I also find that folder with files in it.
Thought i exclude it from project.
I'm using Eclipse only to develop projects using CDT, but I investigate that
feature on JDT and if on CDT it works different I will log a PR.
Re: Project path excludes [message #115719 is a reply to message #115642] Mon, 16 August 2004 15:27 Go to previous message
> > C/C++ Project paths
> folder and in CC++ project view I also find that folder with files in it.
Please do(log a PR). The indexer should not parse those files, so someone
it is misbehaving or the exclusion code is buggy.
Previous Topic:Error 127 when compiling hello.c
Next Topic:Linker script file
Current Time: Tue Jul 22 07:26:37 EDT 2025
Powered by FUDForum. Page generated in 0.04147 seconds
