Home » Eclipse Projects » DTP » sources missing in M6 distro
sources missing in M6 distro [message #10517] Mon, 10 April 2006 22:20 Go to next message
Originally posted by: anil.samuel.gmail.com
I downloaded the M6 version of eclipse, GEF, emf and dtp(4/7/06). When I
check the source attachment in Project Properties->Java Build
Path->Libraries, I see that source attachments are missing for
extensions like routineeditor. Also missing are sources for
org.eclipse.datatools.connectivity.db.derby.
org.eclipse.datatools.connectivity.derby
org.eclipse.datatools.modelbase.derby
org.eclipse.datatools.sqltools.db.derby
The src directory contents
(eclipse/plugins/org.eclipse.datatools.source_0.9.0.20060407 1/src/) are
org.eclipse.datatools.connectivity_0.7.0.200602241
org.eclipse.datatools.connectivity.dbdefinition.db2.luw_0.7. 0.200602241
org.eclipse.datatools.connectivity.dbdefinition.derby_0.7.0. 200602241
org.eclipse.datatools.connectivity.dbdefinition.mysql_0.7.0. 200602241
org.eclipse.datatools.connectivity.dbdefinition.oracle_0.7.0 .200602241
org.eclipse.datatools.connectivity.dbdefinition.sybase_0.7.0 .200602241
org.eclipse.datatools.connectivity.db.generic_0.7.0.20060224 1
org.eclipse.datatools.connectivity.db.generic.ui_0.7.0.20060 2241
org.eclipse.datatools.connectivity.oda_3.0.1.200604061
org.eclipse.datatools.connectivity.oda.consumer_3.0.0.200604 071
org.eclipse.datatools.connectivity.oda.design.ui_3.0.1.20060 4051
org.eclipse.datatools.connectivity.sqm.core.ui_0.7.0.2006030 71
org.eclipse.datatools.connectivity.sqm.server.ui_0.7.0.20060 03081
org.eclipse.datatools.connectivity.ui_0.7.0.200602241
org.eclipse.datatools.connectivity.ui.dse_0.7.0.200602241
org.eclipse.datatools.modelbase.dbdefinition_0.7.0.200602241
org.eclipse.datatools.modelbase.edit_0.7.0.200602241
org.eclipse.datatools.modelbase.sql_0.7.0.200602241
org.eclipse.datatools.modelbase.sql.query_0.7.0.200602241
org.eclipse.datatools.modelbase.sql.xml.query_0.7.0.20060224 1
org.eclipse.datatools.sqltools.parsers.sql_0.7.0.200602241
org.eclipse.datatools.sqltools.parsers.sql.lexer_0.7.0.20060 2241
org.eclipse.datatools.sqltools.parsers.sql.query_0.7.0.20060 2241
org.eclipse.datatools.sqltools.parsers.sql.xml.query_0.7.0.2 00602241
Anthos
Re: sources missing in M6 distro [message #10551 is a reply to message #10517] Tue, 11 April 2006 11:11 Go to previous message
Originally posted by: jograham.sybase.com
Anil T Samuel wrote:
> Hi
> Anthos
Anil,
Thanks for pointing this out. This is a result of our recent jarring of
certain plug-ins. We'll get the source added into tomorrow's (4/12) build
again.
John Graham
Eclipse Data Tools Platform PMC Chair
Staff Software Engineer
Sybase, Inc.
Re: sources missing in M6 distro [message #572223 is a reply to message #10517] Tue, 11 April 2006 11:11 Go to previous message
> Hi
> Anthos
Anil,
again.
John Graham
Sybase, Inc.
Previous Topic:sources missing in M6 distro
Next Topic:Tutorial or Getting Started?
Current Time: Thu Jul 17 22:00:25 EDT 2025
Powered by FUDForum. Page generated in 0.06412 seconds
