Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Association table not created for one-to-many EMF reference
[Teneo] Association table not created for one-to-many EMF reference [message #115219] |
Thu, 20 March 2008 18:35  |
Hi Guys,
I noticed that some references in my data (persisted with Teneo) were null
when I reloaded them from the DB. I looked at the DB and found that I was
inexplicably missing one of the association tables. The offending
association is for the EMF-modeled type and reference
"WarfareSystem.dependencies". The corresponding entry in the auto-genned
hbm file is:
<list name="dependencies" lazy="true">
<key update="true" foreign-key="warfaresystem_dependencies">
<column name="`warfaresystem_dependencies_e_id`"
not-null="false" unique="false"/>
</key>
<list-index column="`warfaresystem_dependencies_idx`"/>
<one-to-many entity-name="WarfareSystem"/>
</list>
The relevant mapping info message that is printed to console during the
mapping is:
1969 [main] INFO org.hibernate.cfg.HbmBinder - Mapping collection:
WarfareSystem.dependencies -> warfaresystem
Note that I have an analagous reference for another type that is being
persisted correctly with it's own association table. The entry in the hbm
file is identical (modulo the name/type of the reference), and the info
message is:
1938 [main] INFO org.hibernate.cfg.HbmBinder - Mapping collection:
Step.outputsTo -> step_outputsto
Which I believe is correct. Any idea why this might happen to the
"dependencies" reference? Are there any other diagnostics I can perform to
get you more info?
Daniel
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115247 is a reply to message #115233] |
Thu, 20 March 2008 21:52   |
OK. I think I may have finally uncovered the real problem
You're right about the association table. I had forgotten that I had added
an annotation for "Step.outputsTo" that (for whatever reason) induces an
association table. I did the same for the "Warfare.dependencies" reference
and it appears to have solved the problem for the object with the null
references. The annotation is:
<eclass name="WarfareSystem">
<property name="dependencies">
<many-to-many fetch="EAGER" target-entity="WarfareSystem">
<cascade>MERGE</cascade>
<cascade>PERSIST</cascade>
</many-to-many>
</property>
</eclass>
So it's the lazy loading that's the problem. Because the references aren't
actually null, they're just waiting for me to call system.getDependencies()
to be loaded from the DB.
This poses a problem, however. I'm trying to serialize the object from the
DB to a resource, and the EMF code doesn't do the nice thing and call
system.getDependencies(), it just tries to persist what's already in memory.
So I get the following error:
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getHREF(XMLHelp erImpl.java:781)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveEObjectMany(X MLSaveImpl.java:1842)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1277)
So there are two solutions:
1. I find some way (or petition the EMF guys) to make the EMF serialization
code call the appropriate methods to trigger hibernate to retrieve
referenced objects.
2. I eagerly load everything (which is essentially every reference in my
data model).
If (2) is my only option, is there an easy way to tell Teneo/Hibernate to
eagerly load *everything*?
"Martin Taal" <mtaal@elver.org> wrote in message
news:fruplj$p6$1@build.eclipse.org...
> Hi Daniel,
> I think it is not a missing table (otherwise you would get a hibernate/sql
> error). Afaics the association you are mentioning below is not persisted
> using a join table but using a foreign key in the child table.
> A cause for having null values in a list is that a child got deleted
> without removing it from the list of the parent. For example if you just
> read the child from the db (and not the parent) and then remove the child
> then hibernate won't update the indexes in the list. This results in a
> hole in the indexes in the childs. When reading the contents of the list
> hibernate will place null values in the list in the missing locations. You
> can check this out by looking in the db and see if values in the
> warfaresystem_dependencies_idx column are correct (no missing values).
> If this is the cause then there are two solutions:
> - change your code so that when removing the child it is also removed from
> the parent
> - change the mapping to a set/bag instead of a list, then the idx column
> is not present. This is only possible if the order of the children is not
> important. See here for more info:
> http://www.elver.org/hibernate/hibernate_relations.html#Mapp ing+non-indexed+relations
> gr. Martin
> Daniel Tuohy wrote:
>> Hi Guys,
>> null when I reloaded them from the DB. I looked at the DB and found that
>> I was inexplicably missing one of the association tables. The offending
>> hbm file is:
>> </key>
>> </list>
>> mapping is:
>> hbm file is identical (modulo the name/type of the reference), and the
>> info message is:
>> to get you more info?
>> Daniel
> With Regards, Martin Taal
> Springsite/Elver.org
> Office: Hardwareweg 4, 3821 BV Amersfoort
> Postal: Nassaulaan 7, 3941 EC Doorn
> The Netherlands
> Tel: +31 (0)84 420 2397
> Fax: +31 (0)84 225 9307
> Mail: mtaal@springsite.com - mtaal@elver.org
> Web: www.springsite.com - www.elver.org
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115273 is a reply to message #115247] |
Fri, 21 March 2008 01:43   |
I am not sure why the many-to-many solved your npe. Regarding lazy loading, even without going
through the getter the lazy loaded list should be automatically loaded when accessed (for example
through an iterator) and not have null values. Afaics null values in the list point to the problem I
described in my previous reply (holes in the list).
Regarding eager loading, there is this option: PersistenceOptions.FETCH_CONTAINMENT_EAGERLY, if you
set this to true then it will eagerly load all containment lists.
gr. Martin
> </many-to-many>
> </property>
> </eclass>
> java.lang.NullPointerException
> at
> at
> at
> referenced objects.
> data model).
>> Hi Daniel,
>> the parent
>> gr. Martin
>> Daniel Tuohy wrote:
>>> Hi Guys,
>>> hbm file is:
>>> </key>
>>> </list>
>>> mapping is:
>>> info message is:
>>> Daniel
>> The Netherlands
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115299 is a reply to message #115273] |
Fri, 21 March 2008 17:04   |
So, in your estimation, there is no way EMF could be accessing those
references and not triggering lazy loading? I suspect that the references
are being retrieved using feature IDs, although I don't know that would make
a difference.
As far as the holes-in-the-list conjecture, I should mention that I'm
literally creating the object, persisting it, reloading it and attempting to
serialize to a resource. There is no adding to or removal from any list
references going on. If this were the case, then I shouldn't be seeing an
inconsistency between the in-memory and persisted representations, right?
news:frvhu0$ha9$1@build.eclipse.org...
>even without going through the getter the lazy loaded list should be
>automatically loaded when accessed (for example through an iterator) and
> PersistenceOptions.FETCH_CONTAINMENT_EAGERLY, if you set this to true then
> gr. Martin
>> added an annotation for "Step.outputsTo" that (for whatever reason)
>> induces an association table. I did the same for the
>> "Warfare.dependencies" reference and it appears to have solved the
>> problem for the object with the null references. The annotation is:
>> </many-to-many>
>> </property>
>> </eclass>
>> aren't actually null, they're just waiting for me to call
>> system.getDependencies() to be loaded from the DB.
>> the DB to a resource, and the EMF code doesn't do the nice thing and call
>> memory. So I get the following error:
>> at
>> at
>> at
>> serialization code call the appropriate methods to trigger hibernate to
>> retrieve referenced objects.
>> data model).
>>> Hi Daniel,
>>> hibernate/sql error). Afaics the association you are mentioning below is
>>> not persisted using a join table but using a foreign key in the child
>>> table.
>>> child then hibernate won't update the indexes in the list. This results
>>> in a hole in the indexes in the childs. When reading the contents of the
>>> list hibernate will place null values in the list in the missing
>>> locations. You can check this out by looking in the db and see if values
>>> in the warfaresystem_dependencies_idx column are correct (no missing
>>> values).
>>> from the parent
>>> not important. See here for more info:
>>> gr. Martin
>>> Daniel Tuohy wrote:
>>>> Hi Guys,
>>>> that I was inexplicably missing one of the association tables. The
>>>> offending association is for the EMF-modeled type and reference
>>>> auto-genned hbm file is:
>>>> </key>
>>>> </list>
>>>> mapping is:
>>>> info message is:
>>>> perform to get you more info?
>>>> Daniel
>>> The Netherlands
> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115314 is a reply to message #115299] |
Sat, 22 March 2008 06:08   |
I agree that if you only do create, persist and reload that there should not be a hole-in-list
situation.
A few questions:
- Does it fail on the first element in the list?
- Are other parts of the list set?
- What class is the list?
- If it is one of the hibernate teneo list implementations, what does the isLoaded property say
(just before the npe happens)?
If you can make a (small) reproducible test then I can look at it also. You can send it to me
directly by email (mtaal_at_elver.org).
gr. Martin
> a difference.
>> gr. Martin
>>> </many-to-many>
>>> </property>
>>> </eclass>
>>> at
>>> at
>>> at
>>> data model).
>>>> Hi Daniel,
>>>> table.
>>>> values).
>>>> from the parent
>>>> gr. Martin
>>>> Daniel Tuohy wrote:
>>>>> Hi Guys,
>>>>> </key>
>>>>> </list>
>>>>> mapping is:
>>>>> info message is:
>>>>> Daniel
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115367 is a reply to message #115314] |
Sat, 22 March 2008 16:31   |
1. Yes, it fails on the first element in the list.
2. Yes. There are four elements in the list, and the last one is set, the
first three are null.
3. The list is a HibernatePersistableEList.
4. isLoaded() returns "true"
I should also note that I am now seeing inconsistent behavior. Sometimes
the list for the object is full of the correct references, sometimes the
first three are null and only the last is set, and sometimes the list is
actually empty.
The object being persisted is very elaborate, and the object whose
references are corrupted is contained within the object I'm trying to
serialize. The JUnit test I am running is not complicated, it consists of
object creation, persistence, retrieval, and serialization (failing on
serialization when it gets to these references).
Unfortunately, it concerns a great deal of data and a large EMF model, so I
will have to consult my employer before I can commit to sending over a test
case. Does anything further oc
news:fs2lrj$nbg$1@build.eclipse.org...
> situation.
> A few questions:
> isLoaded property say (just before the npe happens)?
> You can send it to me directly by email (mtaal_at_elver.org).
> gr. Martin
>> references are being retrieved using feature IDs, although I don't know
>> that would make a difference.
>> to serialize to a resource. There is no adding to or removal from any
>> list references going on. If this were the case, then I shouldn't be
>> seeing an inconsistency between the in-memory and persisted
>>> loading, even without going through the getter the lazy loaded list
>>> should be automatically loaded when accessed (for example through an
>>> to the problem I described in my previous reply (holes in the list).
>>> gr. Martin
>>>> </many-to-many>
>>>> </property>
>>>> </eclass>
>>>> call system.getDependencies(), it just tries to persist what's already
>>>> in memory. So I get the following error:
>>>> at
>>>> at
>>>> at
>>>> my data model).
>>>> to eagerly load *everything*?
>>>>> Hi Daniel,
>>>>> is not persisted using a join table but using a foreign key in the
>>>>> child table.
>>>>> just read the child from the db (and not the parent) and then remove
>>>>> the child then hibernate won't update the indexes in the list. This
>>>>> results in a hole in the indexes in the childs. When reading the
>>>>> contents of the list hibernate will place null values in the list in
>>>>> the missing locations. You can check this out by looking in the db and
>>>>> see if values in the warfaresystem_dependencies_idx column are correct
>>>>> from the parent
>>>>> column is not present. This is only possible if the order of the
>>>>> children is not important. See here for more info:
>>>>> gr. Martin
>>>>> Daniel Tuohy wrote:
>>>>>> Hi Guys,
>>>>>> </key>
>>>>>> </list>
>>>>>> the mapping is:
>>>>>> being persisted correctly with it's own association table. The entry
>>>>>> in the hbm file is identical (modulo the name/type of the reference),
>>>>>> and the info message is:
>>>>>> Daniel
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115380 is a reply to message #115367] |
Sat, 22 March 2008 16:37   |
Sorry, I sent that prematurely. It was meant to end: "Does anything further
occur to you in light of the answers to your questions, or due to the
inconsistency in the contents of that list?"
I should also note that I see this inconsistency only when I recreate the DB
and persist the object each time I run the test. If I just load the object
from the same DB repeatedly, the behavior is consistent.
"Daniel Tuohy" <danielr2e@gmail.com> wrote in message
news:fs3q7l$j5r$1@build.eclipse.org...
> the first three are null.
> actually empty.
> I will have to consult my employer before I can commit to sending over a
> test case. Does anything further oc
>> situation.
>> A few questions:
>> gr. Martin
>>> attempting to serialize to a resource. There is no adding to or removal
>>> from any list references going on. If this were the case, then I
>>> shouldn't be seeing an inconsistency between the in-memory and persisted
>>>> point to the problem I described in my previous reply (holes in the
>>>> list).
>>>> gr. Martin
>>>>> </many-to-many>
>>>>> </property>
>>>>> </eclass>
>>>>> from the DB to a resource, and the EMF code doesn't do the nice thing
>>>>> and call system.getDependencies(), it just tries to persist what's
>>>>> already in memory. So I get the following error:
>>>>> at
>>>>> at
>>>>> at
>>>>> to retrieve referenced objects.
>>>>> my data model).
>>>>>> Hi Daniel,
>>>>>> child table.
>>>>>> and see if values in the warfaresystem_dependencies_idx column are
>>>>>> from the parent
>>>>>> gr. Martin
>>>>>> Daniel Tuohy wrote:
>>>>>>> Hi Guys,
>>>>>>> were null when I reloaded them from the DB. I looked at the DB and
>>>>>>> found that I was inexplicably missing one of the association tables.
>>>>>>> The offending association is for the EMF-modeled type and reference
>>>>>>> </key>
>>>>>>> </list>
>>>>>>> the mapping is:
>>>>>>> entry in the hbm file is identical (modulo the name/type of the
>>>>>>> reference), and the info message is:
>>>>>>> Daniel
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115407 is a reply to message #115380] |
Sun, 23 March 2008 04:54   |
Hmmm, looking back to your remark in the beginning, what is also possible is that the one-to-many is
really a many-to-many.
So what can happen is that the elements in one list are present in another list also. When the lists
are mapped using foreign keys then when lists are persisted a list which is persisted later will
overwrite the foreign keys of the elements of a first list. So depending on the order in which lists
are persisted, it results in empty entries. A simple setting to try this out can be to set the
following option to true:
PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS
then you should get jointables for all associations (except contained).
or you can force a jointable for individual associations with the jointable annotation:
@JoinTable(name="MyGreatJoinTable")
or use the many-to-many as you mention below.
gr. Martin
>> actually empty.
>>> situation.
>>> A few questions:
>>> gr. Martin
>>>>> list).
>>>>> gr. Martin
>>>>>> </many-to-many>
>>>>>> </property>
>>>>>> </eclass>
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> my data model).
>>>>>>> Hi Daniel,
>>>>>>> child table.
>>>>>>> from the parent
>>>>>>> gr. Martin
>>>>>>> Daniel Tuohy wrote:
>>>>>>>> Hi Guys,
>>>>>>>> </key>
>>>>>>>> </list>
>>>>>>>> the mapping is:
>>>>>>>> Daniel
>>>>>>> The Netherlands
>>>>> The Netherlands
>>> The Netherlands
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115436 is a reply to message #115407] |
Sun, 23 March 2008 10:59   |
I think you're right. It hadn't occured to me that this association was
n-to-m, but indeed it is. Without using that PersistenceOption, I'm still
seeing the error on some other objects, but I would bet that I've simply
overlooked another many-to-many association in the model.
news:fs55t8$mqh$1@build.eclipse.org...
> is that the one-to-many is really a many-to-many.
> list also. When the lists are mapped using foreign keys then when lists
> are persisted a list which is persisted later will overwrite the foreign
> lists are persisted, it results in empty entries. A simple setting to try
> this out can be to set the following option to true:
> gr. Martin
>> further occur to you in light of the answers to your questions, or due to
>> the inconsistency in the contents of that list?"
>> DB and persist the object each time I run the test. If I just load the
>> object from the same DB repeatedly, the behavior is consistent.
>>> Sometimes the list for the object is full of the correct references,
>>> sometimes the first three are null and only the last is set, and
>>> sometimes the list is actually empty.
>>> of object creation, persistence, retrieval, and serialization (failing
>>> on serialization when it gets to these references).
>>> so I will have to consult my employer before I can commit to sending
>>> over a test case. Does anything further oc
>>>> situation.
>>>> A few questions:
>>>> the isLoaded property say (just before the npe happens)?
>>>> gr. Martin
>>>>> know that would make a difference.
>>>>> removal from any list references going on. If this were the case,
>>>>> then I shouldn't be seeing an inconsistency between the in-memory and
>>>>>> list).
>>>>>> gr. Martin
>>>>>>> had added an annotation for "Step.outputsTo" that (for whatever
>>>>>>> reason) induces an association table. I did the same for the
>>>>>>> </many-to-many>
>>>>>>> </property>
>>>>>>> </eclass>
>>>>>>> thing and call system.getDependencies(), it just tries to persist
>>>>>>> what's already in memory. So I get the following error:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> in my data model).
>>>>>>> Teneo/Hibernate to eagerly load *everything*?
>>>>>>>> Hi Daniel,
>>>>>>>> below is not persisted using a join table but using a foreign key
>>>>>>>> in the child table.
>>>>>>>> deleted without removing it from the list of the parent. For
>>>>>>>> example if you just read the child from the db (and not the parent)
>>>>>>>> and then remove the child then hibernate won't update the indexes
>>>>>>>> in the list. This results in a hole in the indexes in the childs.
>>>>>>>> When reading the contents of the list hibernate will place null
>>>>>>>> values in the list in the missing locations. You can check this out
>>>>>>>> values).
>>>>>>>> removed from the parent
>>>>>>>> gr. Martin
>>>>>>>> Daniel Tuohy wrote:
>>>>>>>>> Hi Guys,
>>>>>>>>> and found that I was inexplicably missing one of the association
>>>>>>>>> tables. The offending association is for the EMF-modeled type and
>>>>>>>>> reference "WarfareSystem.dependencies". The corresponding entry
>>>>>>>>> in the auto-genned hbm file is:
>>>>>>>>> <key update="true"
>>>>>>>>> </key>
>>>>>>>>> </list>
>>>>>>>>> during the mapping is:
>>>>>>>>> collection: WarfareSystem.dependencies -> warfaresystem
>>>>>>>>> collection: Step.outputsTo -> step_outputsto
>>>>>>>>> Daniel
>>>>>>>> The Netherlands
>>>>>> The Netherlands
>>>> The Netherlands
> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115449 is a reply to message #115436] |
Sun, 23 March 2008 11:01   |
And thanks so much for your help!
news:fs5r4g$s8q$1@build.eclipse.org...
>> another list also. When the lists are mapped using foreign keys then when
>> lists are persisted a list which is persisted later will overwrite the
>> in which lists are persisted, it results in empty entries. A simple
>> setting to try this out can be to set the following option to true:
>> gr. Martin
>>> to the inconsistency in the contents of that list?"
>>> the DB and persist the object each time I run the test. If I just load
>>> the object from the same DB repeatedly, the behavior is consistent.
>>>>> situation.
>>>>> A few questions:
>>>>> also. You can send it to me directly by email (mtaal_at_elver.org).
>>>>> gr. Martin
>>>>>>> list).
>>>>>>> gr. Martin
>>>>>>>> is:
>>>>>>>> </many-to-many>
>>>>>>>> </property>
>>>>>>>> </eclass>
>>>>>>>> references aren't actually null, they're just waiting for me to
>>>>>>>> call system.getDependencies() to be loaded from the DB.
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> hibernate to retrieve referenced objects.
>>>>>>>> in my data model).
>>>>>>>>> Hi Daniel,
>>>>>>>>> in the child table.
>>>>>>>>> parent) and then remove the child then hibernate won't update the
>>>>>>>>> indexes in the list. This results in a hole in the indexes in the
>>>>>>>>> childs. When reading the contents of the list hibernate will place
>>>>>>>>> null values in the list in the missing locations. You can check
>>>>>>>>> values).
>>>>>>>>> gr. Martin
>>>>>>>>> Daniel Tuohy wrote:
>>>>>>>>>> Hi Guys,
>>>>>>>>>> <key update="true"
>>>>>>>>>> </key>
>>>>>>>>>> </list>
>>>>>>>>>> the "dependencies" reference? Are there any other diagnostics I
>>>>>>>>>> can perform to get you more info?
>>>>>>>>>> Daniel
>>>>>>>>> The Netherlands
>>>>>>> The Netherlands
>>>>> The Netherlands
>> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #115527 is a reply to message #115436] |
Sun, 23 March 2008 16:19  |
It is good that I now know of this issue. I am considering of changing the option below to a default
value of true (so always have jointables). It seems to be a safer first approach. This will probably
be in the next release.
gr. Martin
>> gr. Martin
>>>>> situation.
>>>>> A few questions:
>>>>> gr. Martin
>>>>>>> list).
>>>>>>> gr. Martin
>>>>>>>> </many-to-many>
>>>>>>>> </property>
>>>>>>>> </eclass>
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> in my data model).
>>>>>>>>> Hi Daniel,
>>>>>>>>> in the child table.
>>>>>>>>> values).
>>>>>>>>> gr. Martin
>>>>>>>>> Daniel Tuohy wrote:
>>>>>>>>>> Hi Guys,
>>>>>>>>>> <key update="true"
>>>>>>>>>> </key>
>>>>>>>>>> </list>
>>>>>>>>>> Daniel
>>>>>>>>> The Netherlands
>>>>>>> The Netherlands
>>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615941 is a reply to message #115219] |
Thu, 20 March 2008 18:49  |
Hi Daniel,
I think it is not a missing table (otherwise you would get a hibernate/sql error). Afaics the
association you are mentioning below is not persisted using a join table but using a foreign key in
the child table.
A cause for having null values in a list is that a child got deleted without removing it from the
list of the parent. For example if you just read the child from the db (and not the parent) and then
remove the child then hibernate won't update the indexes in the list. This results in a hole in the
indexes in the childs. When reading the contents of the list hibernate will place null values in the
list in the missing locations. You can check this out by looking in the db and see if values in the
- change your code so that when removing the child it is also removed from the parent
- change the mapping to a set/bag instead of a list, then the idx column is not present. This is
only possible if the order of the children is not important. See here for more info:
gr. Martin
Daniel Tuohy wrote:
> Hi Guys,
> hbm file is:
> </key>
> </list>
> mapping is:
> message is:
> get you more info?
> Daniel
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615942 is a reply to message #115233] |
</many-to-many>
</property>
</eclass>
referenced objects.
data model).
> Hi Daniel,
> the parent
> gr. Martin
> Daniel Tuohy wrote:
>> Hi Guys,
>> hbm file is:
>> </key>
>> </list>
>> mapping is:
>> info message is:
>> Daniel
> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615944 is a reply to message #115247] |
gr. Martin
> </many-to-many>
> </property>
> </eclass>
> at
> at
> at
> referenced objects.
> data model).
>> Hi Daniel,
>> the parent
>> gr. Martin
>> Daniel Tuohy wrote:
>>> Hi Guys,
>>> hbm file is:
>>> </key>
>>> </list>
>>> mapping is:
>>> info message is:
>>> Daniel
>> The Netherlands
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615946 is a reply to message #115273] |
a difference.
> gr. Martin
>> </many-to-many>
>> </property>
>> </eclass>
>> at
>> at
>> at
>> data model).
>>> Hi Daniel,
>>> table.
>>> values).
>>> from the parent
>>> gr. Martin
>>> Daniel Tuohy wrote:
>>>> Hi Guys,
>>>> </key>
>>>> </list>
>>>> mapping is:
>>>> info message is:
>>>> Daniel
>>> The Netherlands
> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615947 is a reply to message #115299] |
situation.
A few questions:
gr. Martin
> a difference.
>> gr. Martin
>>> </many-to-many>
>>> </property>
>>> </eclass>
>>> at
>>> at
>>> at
>>> data model).
>>>> Hi Daniel,
>>>> table.
>>>> values).
>>>> from the parent
>>>> gr. Martin
>>>> Daniel Tuohy wrote:
>>>>> Hi Guys,
>>>>> </key>
>>>>> </list>
>>>>> mapping is:
>>>>> info message is:
>>>>> Daniel
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615951 is a reply to message #115314] |
actually empty.
> situation.
> A few questions:
> gr. Martin
>>> gr. Martin
>>>> </many-to-many>
>>>> </property>
>>>> </eclass>
>>>> at
>>>> at
>>>> at
>>>> my data model).
>>>>> Hi Daniel,
>>>>> child table.
>>>>> from the parent
>>>>> gr. Martin
>>>>> Daniel Tuohy wrote:
>>>>>> Hi Guys,
>>>>>> </key>
>>>>>> </list>
>>>>>> the mapping is:
>>>>>> Daniel
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615952 is a reply to message #115367] |
> actually empty.
>> situation.
>> A few questions:
>> gr. Martin
>>>> list).
>>>> gr. Martin
>>>>> </many-to-many>
>>>>> </property>
>>>>> </eclass>
>>>>> at
>>>>> at
>>>>> at
>>>>> my data model).
>>>>>> Hi Daniel,
>>>>>> child table.
>>>>>> from the parent
>>>>>> gr. Martin
>>>>>> Daniel Tuohy wrote:
>>>>>>> Hi Guys,
>>>>>>> </key>
>>>>>>> </list>
>>>>>>> the mapping is:
>>>>>>> Daniel
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615954 is a reply to message #115380] |
gr. Martin
>> actually empty.
>>> situation.
>>> A few questions:
>>> gr. Martin
>>>>> list).
>>>>> gr. Martin
>>>>>> </many-to-many>
>>>>>> </property>
>>>>>> </eclass>
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> my data model).
>>>>>>> Hi Daniel,
>>>>>>> child table.
>>>>>>> from the parent
>>>>>>> gr. Martin
>>>>>>> Daniel Tuohy wrote:
>>>>>>>> Hi Guys,
>>>>>>>> </key>
>>>>>>>> </list>
>>>>>>>> the mapping is:
>>>>>>>> Daniel
>>>>>>> The Netherlands
>>>>> The Netherlands
>>> The Netherlands
The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615956 is a reply to message #115407] |
> gr. Martin
>>>> situation.
>>>> A few questions:
>>>> gr. Martin
>>>>>> list).
>>>>>> gr. Martin
>>>>>>> </many-to-many>
>>>>>>> </property>
>>>>>>> </eclass>
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> in my data model).
>>>>>>>> Hi Daniel,
>>>>>>>> in the child table.
>>>>>>>> values).
>>>>>>>> gr. Martin
>>>>>>>> Daniel Tuohy wrote:
>>>>>>>>> Hi Guys,
>>>>>>>>> <key update="true"
>>>>>>>>> </key>
>>>>>>>>> </list>
>>>>>>>>> Daniel
>>>>>>>> The Netherlands
>>>>>> The Netherlands
>>>> The Netherlands
> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615957 is a reply to message #115436] |
>> gr. Martin
>>>>> situation.
>>>>> A few questions:
>>>>> gr. Martin
>>>>>>> list).
>>>>>>> gr. Martin
>>>>>>>> is:
>>>>>>>> </many-to-many>
>>>>>>>> </property>
>>>>>>>> </eclass>
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> in my data model).
>>>>>>>>> Hi Daniel,
>>>>>>>>> in the child table.
>>>>>>>>> values).
>>>>>>>>> gr. Martin
>>>>>>>>> Daniel Tuohy wrote:
>>>>>>>>>> Hi Guys,
>>>>>>>>>> <key update="true"
>>>>>>>>>> </key>
>>>>>>>>>> </list>
>>>>>>>>>> Daniel
>>>>>>>>> The Netherlands
>>>>>>> The Netherlands
>>>>> The Netherlands
>> The Netherlands
Re: [Teneo] Association table not created for one-to-many EMF reference [message #615963 is a reply to message #115436] |
gr. Martin
>> gr. Martin
>>>>> situation.
>>>>> A few questions:
>>>>> gr. Martin
>>>>>>> list).
>>>>>>> gr. Martin
>>>>>>>> </many-to-many>
>>>>>>>> </property>
>>>>>>>> </eclass>
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> in my data model).
>>>>>>>>> Hi Daniel,
>>>>>>>>> in the child table.
>>>>>>>>> values).
>>>>>>>>> gr. Martin
>>>>>>>>> Daniel Tuohy wrote:
>>>>>>>>>> Hi Guys,
>>>>>>>>>> <key update="true"
>>>>>>>>>> </key>
>>>>>>>>>> </list>
>>>>>>>>>> Daniel
>>>>>>>>> The Netherlands
>>>>>>> The Netherlands
>>>>> The Netherlands
>> The Netherlands
The Netherlands
Current Time: Thu Jul 17 22:22:20 EDT 2025
Powered by FUDForum. Page generated in 1.16558 seconds
