Home » Language IDEs » ServerTools (WTP) » How do I configure an existing web module in Eclipse 3.1 + Web Tools M5 ?
How do I configure an existing web module in Eclipse 3.1 + Web Tools M5 ? [message #115141] Fri, 01 July 2005 10:33
I just installed Eclipse 3.1 and Web Tools M5. I have an existing Tomcat
web module with the following directory structure.
Current : Root directory
Current/src/java : Java source directory
Current/src/web : Web source directory
Current/src/web/WEB-INF/classes : Java compile target directory
Current/src/web/WEB-INF/lib : lib directory
How do I set up a dynamic web application for Tomcat 5.0 using webtools in
Eclipse to use the above directory structure?
When I try to create a dynamic web application using the wizard, it
creates JavaSource and WebSource directories. And it does not point to the
directory structure above. Is there any way to change the JavaSource
directory and the WebSource directory to point to the correct ones I need ?
Any help would be highly appreciated!!!!
Previous Topic:Announcement: WTP 0.7 M5 Available!
Next Topic:XML source editor missing?!
Current Time: Sat Jul 26 07:44:33 EDT 2025
Powered by FUDForum. Page generated in 1.03664 seconds
