[ANN] SWT Designer 1.2.1 Released [message #115137] |
Sat, 08 November 2003 12:35 |
Major v1.2.1 update to SWT Designer includes support for FormLayout,
multi-widget editing, custom composite creation, SWT project creation,
platform undo/redo, plus many other new features.
[+] FormLayout Support (professional only). Intelligent "snap"
points for fixed, percentage and widget attachmnets.
Specify preferences for default offsets and percentages.
Convert null layouts to FormLayouts and vice versa.
[+] Multiple widget select and property update (professional only).
Easily change common properties on multiple widgets.
[+] Marquee select (professional only)
[+] SWT Composite wizard for creating custom subclasses of
org.eclipse.swt.widgets.Composite (professional only)
[+] SWT/JFace Java Project wizard. Automatically adds the correct
SWT and JFace imports and the ResourceManager class to the project.
[+] Added New Wizard shortcuts and toolbar items
[+] Integration with platform Undo, Redo and Revert
[+] Preference for controlling default layout manager to use for
new windows. Composites may also inherit the parent layout manager
[+] Set the shell size in code or dynamically
[+] See the natural size of the window and the minumum size of the window
[*] ResourceManager automatically added to project when needed
[*] Improved support for Linux/Motif
[*] Reparenting support in null layout
[-] Fix for clipping and z-order issues
[-] Fixed problem with default line ending styles
[-] Fixed bug causing source corruption
[-] Fixed "Widget is disposed" problem under Linux
[-] Fixed problem with external strings and source folders
[-] Fixed bug with non static value in call of setItems() call.
"Argument can not be null produced". Fixed by providing empty
String array instead of null.
-Eric Clayberg
Sr. Vice President of Product Development
Instantiations, Inc.
mailto:cpsws-support@instantiations.com
http://www.instantiations.com
http://www.instantiations.com/codepro/ws
http://www.swt-designer.com
FUDForum. Page generated in 0.07110 seconds
