Home » Eclipse Projects » Remote Application Platform (RAP) » Changing Mouse Cursor
Changing Mouse Cursor [message #115113] Tue, 09 December 2008 12:02 Go to next message
I wanted to change the mouse cursor in an application containing multiple
tabfolders which contain tables using the
Display.getCurrent().getActiveShell().setCursor method to the busy cursor.
But the cursor is just set busy for parts of the shell. In a RCP
application the cursor is set to busy for every child. Trying to set the
cursor to SWT.WAIT for the tables manually did not work in the RAP
application. I wanted to ask if their is another way to change the cursor
for the whole application.
Thanks in advance
Gunnar
Re: Changing Mouse Cursor [message #115139 is a reply to message #115113] Tue, 09 December 2008 15:40 Go to previous messageGo to next message
Hi Gunnar,
thanks for reporting this issue.
> multiple tabfolders which contain tables using the
> cursor. But the cursor is just set busy for parts of the shell.
But it is set somewhere? I just tested with a simple snippet and found
that the custom cursor on a shell was not shown at all!
> In a RCP
> cursor for the whole application.
This is obviously a bug. Could you please file a bugzilla entry?
Regards, Ralf
Re: Changing Mouse Cursor [message #115151 is a reply to message #115113] Tue, 09 December 2008 15:47 Go to previous messageGo to next message
Oh, I forgot to mention that you can use
BusyIndicator.showWhile( Display, Runnable() )
to show a busy cursor on the entire display during a long-running task.
Ralf
Re: Changing Mouse Cursor [message #115224 is a reply to message #115151] Wed, 10 December 2008 05:26 Go to previous messageGo to next message
Thank you,
I filed a Bug Report and tried the BusyIndicator.showWhile method. But it
is not really working for me. In my case when the user selects an item in
a table, a shell which contains more detailed info on the selected item
opens. The process of creating and filling the shell doesn't take much
time. The problem seems to be opening the shell. The command returns fast
so no busy cursor is displayed, but it takes about one or two seconds
until the new shell is displayed. Is there a possibility making the
application wait until the shell is displayed so that the cursor is shown?
> Ralf
Re: Changing Mouse Cursor [message #115261 is a reply to message #115224] Wed, 10 December 2008 06:56 Go to previous message
Gunnar Wurl wrote:
> Thank you,
> it is not really working for me. In my case when the user selects an
> item in a table, a shell which contains more detailed info on the
> selected item opens. The process of creating and filling the shell
> doesn't take much time. The problem seems to be opening the shell. The
> command returns fast so no busy cursor is displayed, but it takes about
> one or two seconds until the new shell is displayed. Is there a
> possibility making the application wait until the shell is displayed so
Thanks for the bug report.
I don't see a simple solution for your problem and I don't like to
recommend something like including a Thread.sleep in your Runnable...
Ralf
Previous Topic:Changing date format of DateTime widget
Next Topic:Tooling source code?
Current Time: Tue Jul 22 06:33:45 EDT 2025
Powered by FUDForum. Page generated in 0.08968 seconds
