Home » Eclipse Projects » Remote Application Platform (RAP) » Changing date format of DateTime widget
Changing date format of DateTime widget [message #115039] Tue, 09 December 2008 09:32 Go to next message
Is it possible to change the date format in DateTime Widget ? When I first
try it, the format is MM/dd/yyyy, I want to change it into dd/MM/yyyy.
Setya
Re: Changing date format of DateTime widget [message #115076 is a reply to message #115039] Tue, 09 December 2008 10:17 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
Hi Setya,
the format of date in DateTime widget depends on client (browser) locale
(language). If the browser content language is en-US the format will be
MM/dd/yyyy, but if it is German (de-de) for example, the format will be
dd/MM/yyyy. To check this you can set in Firefox your preferred language
in Options -> Content -> Languages and see the result. Anyway, there is
no explicitly way to set to format if DateTime widget. This is the same
in SWT.
Best,
Ivan
Setya wrote:
> first try it, the format is MM/dd/yyyy, I want to change it into
> dd/MM/yyyy.
> Setya
Re: Changing date format of DateTime widget [message #115100 is a reply to message #115039] Tue, 09 December 2008 10:52 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Use RWT#getLocale() to query the currently used locale and
RWT#setLocale() to alter it.
The date time widget uses this information to display date and time
information.
HTH
Rüdiger
Setya wrote:
> dd/MM/yyyy.
> Setya
Re: Changing date format of DateTime widget [message #940894 is a reply to message #115076] Thu, 11 October 2012 23:29 Go to previous message
Please try with code:
public class LocaleConfig {
public static final String LOCALE_COUNTRY_DEFAULT = "VN";
public static void setDefaultLocale() {
Locale locale = RWT.getLocale();
if (LOCALE_COUNTRY_DEFAULT.equals(locale.getCountry())) {
return;
Locale defaultLocale = null;
Locale[] locales = Locale.getAvailableLocales();
for (Locale loc : locales) {
if (LOCALE_COUNTRY_DEFAULT.equals(loc.getCountry())) {
defaultLocale = loc;
break;
if (defaultLocale != null) {
RWT.setLocale(defaultLocale);
Previous Topic:ProgressMonitorDialog caused an Exception (context disposed) on page reload
Next Topic:Changing Mouse Cursor
Current Time: Tue Jul 22 01:40:35 EDT 2025
Powered by FUDForum. Page generated in 0.25293 seconds
