Home » Archived » BIRT » Print PDF button doesn't work properly when parameter changed
Print PDF button doesn't work properly when parameter changed [message #114992] Tue, 24 January 2006 22:34 Go to next message
I have downloaded and installed the BIRT 2.0 Final. When I ran the
test.rptdesign report and changed the parameter on the parameter dialog
box, the change was made to the screen but as I clicked on the print
button the PDF output still cached the previous parameter. Is this a bug
or is there any additional setting? Please advice. Thank you.
Re: Print PDF button doesn't work properly when parameter changed [message #115742 is a reply to message #114992] Wed, 25 January 2006 09:38 Go to previous messageGo to next message
Originally posted by: maspeli.deloitte.co.uk
"Eric Yang" <sirericyang@gmail.com> wrote in message
news:a03b6992e6b6f13b89f9209073ee3309$1@www.eclipse.org...
I was having this problem too in RC2, and in 2.0 final I can't get PDF
output at all. :-(
Martin
Re: Print PDF button doesn't work properly when parameter changed [message #116237 is a reply to message #114992] Wed, 25 January 2006 13:27 Go to previous messageGo to next message
Eric:
Can you check your installation? The Web Viewer in the BIRT 2.0 Final build
doesn't support print operation. You should not see the print button in
inside the web viewer. You need to use the PDF viewer's print function.
-wenbin
Re: Print PDF button doesn't work properly when parameter changed [message #116897 is a reply to message #116237] Wed, 25 January 2006 20:44 Go to previous message
Wenbin He wrote:
> Eric:
> -wenbin
>>Sorry. I used the BIRT 2.0 RC2 JSP files instead of current 2.0 Final JSP
files. I intentionally swaped the files for testing purpose. On the BIRT RC2,
it has the same problem when parameter chaned, too. Any idea, when can it be
fixed? Thank you!
Previous Topic:Change the embedded image of a element dinamicaly
Next Topic:After Deploying on Tomcat the Exporting to excel option is not coming in BIRT 2.
Current Time: Mon Jul 21 20:05:26 EDT 2025
Powered by FUDForum. Page generated in 0.04216 seconds
