Home » Eclipse Projects » Equinox » Question regarding ServiceSelector Filter mechanism
Question regarding ServiceSelector Filter mechanism [message #114815] Mon, 21 July 2008 07:41 Go to next message
Originally posted by: fappel.innoopract.com
------=_NextPart_000_0076_01C8EB37.A59456F0
Content-Type: text/plain;
charset="us-ascii"
doing a follow up on a RAP user complaint regarding that the eclipse
help doesn't work with RAP anymore I came across the ServiceSelector
filter mechanism (bug 158168
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=158168> ). It took me a
while to figure out that using
'-Dorg.eclipse.equinox.http.jetty.other.info=org.eclipse.hel p' as VM
argument revives the help system.
Unfortunately RAP applications are most often not deployed using OSGi
standalone with the Jetty engine as HttpService provider, they run
embedded in the various available servlet container implementations. So
what I couldn't figure out is what I have to do to bring the help system
back to work in those scenarios (e.g running in tomcat). My hope is that
users don't have to configure a different startup parameter for each
container implementation, since this will cause us user-acceptance
problems. Anyway it would be nice if somebody could point me to more
detailed information or solution regarding this problem.
By the way something that I couldn't understand properly by reading the
bug, is why this functionality was introduced the first time, since it
was stated by Simon that ' its quite rare to run more than one
HttpService in a single VM'. So I'm wondering if there was a real
usecase where the previous situation actually caused problems.
Ciao
Frank
Content-Type: text/html;
charset="us-ascii"
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:m=3D"http://schemas.microsoft.com/office/2004/12/omml" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 12 (filtered medium)">
<style>
/* Font Definitions */
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:11.0pt;
font-family:"Calibri","sans-serif";}
a:link, span.MsoHyperlink
{mso-style-priority:99;
color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
color:purple;
pre
mso-style-link:"HTML Vorformatiert Zchn";
margin:0cm;
font-size:10.0pt;
font-family:"Courier New";}
span.E-MailFormatvorlage17
{mso-style-type:personal-compose;
color:windowtext;}
span.HTMLVorformatiertZchn
{mso-style-name:"HTML Vorformatiert Zchn";
mso-style-link:"HTML Vorformatiert";
..MsoChpDefault
{mso-style-type:export-only;}
@page Section1
{size:612.0pt 792.0pt;
margin:70.85pt 70.85pt 2.0cm 70.85pt;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]-->
</head>
<body lang=3DDE link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal>Hi,<o:p></o:p></p>
<p class=3DMsoNormal><o:p>&nbsp;</o:p></p>
<p class=3DMsoNormal>doing a follow up on a RAP user complaint regarding =
that the
eclipse help doesn't work with RAP anymore I came across the =
ServiceSelector
filter mechanism (bug <a
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D158168">158168</a=
>). It
took me a while to figure out that using =
'-Dorg.eclipse.equinox.http.jetty.other.info=3Dorg.eclipse.h elp'
as VM argument revives the help system.<o:p></o:p></p>
<p class=3DMsoNormal>Unfortunately RAP applications are most often not =
deployed using
OSGi standalone with the Jetty engine as HttpService provider, they run
embedded in the various available servlet container implementations. So =
what I
couldn't figure out is what I have to do to bring the help system back =
to work
in those scenarios (e.g running in tomcat). My hope is that users don't =
have to
configure a different startup parameter for each container =
implementation,
since this will cause us user-acceptance problems. Anyway it would be =
nice if somebody
could point me to more detailed information or solution regarding this =
problem.<o:p></o:p></p>
<pre><span =
style=3D'font-size:11.0pt;font-family:"Calibri","sans-serif "'>By the way =
something that I couldn't understand properly by reading the bug, is why =
this functionality was introduced the first time, since it was stated by =
Simon that ' its quite rare to run more than one HttpService in a single =
VM'. &nbsp;So I'm wondering if there was a real usecase where the =
previous situation actually caused problems.<o:p></o:p></span></pre>
<p class=3DMsoNormal>Ciao<o:p></o:p></p>
<p class=3DMsoNormal>Frank<o:p></o:p></p>
</div>
</body>
</html>
------=_NextPart_000_0076_01C8EB37.A59456F0--
Re: Question regarding ServiceSelector Filter mechanism [message #114853 is a reply to message #114815] Mon, 21 July 2008 11:48 Go to previous messageGo to next message
Hi Frank,
I'm afraid you need to patch the help plug-in to register with *any*
HttpService available (or use an alternate filter if necessary).
> the bug, is why this functionality was introduced the first time,
> since it was stated by Simon that ' its quite rare to run more than
> one HttpService in a single VM'. So I'm wondering if there was a
> real usecase where the previous situation actually caused problems.
I can't comment on why it was introduced the first time. However, I have
a use case. I'm developing a platform which provides multiple
HttpService instances. One is for "public" stuff and the other for
"admin" stuff. Think of it as an admin/system back office which - in
addition to being password protected - must also be hidden from the
public port.
Yet another use case might be virtual hosting or SSL sites. Some content
should only be available over an SSL connection.
FWIW, I actually patched RAP to only register with a specific service
instance. This works well for the actual servlet but not for the resources.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241210
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Question regarding ServiceSelector Filter mechanism [message #114987 is a reply to message #114853] Tue, 22 July 2008 05:01 Go to previous messageGo to next message
Hm,
I think you have a valid use case, but our end user's use case is as
valid as the one that you describe. So the filter approach solves one
problem by bringing in a problem that didn't exist before. To me it
seems not a good strategy to make the usage of Equinox on the serverside
more popular by suggesting to our users to patch bundles to solve such
problems.
I would prefer an approach e.g. that allows to declare such filters
independently from the servlet/resources registration. This would solve
the problem you describe and still allows people to use the help.webapp
bundle.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Gunnar Wagenknecht [mailto:gunnar@wagenknecht.org]
Bereitgestellt: Montag, 21. Juli 2008 17:48
Bereitgestellt in: eclipse.technology.equinox
Unterhaltung: Question regarding ServiceSelector Filter mechanism
Betreff: Re: Question regarding ServiceSelector Filter mechanism
Hi Frank,
public port.
resources.
-Gunnar
Gunnar Wagenknecht
Re: Question regarding ServiceSelector Filter mechanism [message #115050 is a reply to message #114987] Tue, 22 July 2008 13:45 Go to previous messageGo to next message
> bundle.
Hehe, by "patching" I mean providing a patch attached to Bugzilla which
could be integrated into a following release. ;)
-Gunnar
Gunnar Wagenknecht
Re: Question regarding ServiceSelector Filter mechanism [message #115080 is a reply to message #115050] Wed, 23 July 2008 03:54 Go to previous messageGo to next message
Bereitgestellt: Dienstag, 22. Juli 2008 19:46
solve
help.webapp
> bundle.
-Gunnar
Gunnar Wagenknecht
Re: Question regarding ServiceSelector Filter mechanism [message #115092 is a reply to message #115050] Wed, 23 July 2008 03:56 Go to previous messageGo to next message
sorry for the misunderstanding...I'll see if I found something usefull.
Ciao
Frank
solve
help.webapp
> bundle.
-Gunnar
Gunnar Wagenknecht
Re: Question regarding ServiceSelector Filter mechanism [message #115132 is a reply to message #115092] Wed, 23 July 2008 14:50 Go to previous messageGo to next message
Hmm... unfortunately, the service selector is introduced via plugin.xml.
Thus, the only way will be to use product customization via XSLT
transformation of the extension registry.
http://wiki.eclipse.org/Product_Customization
http://wiki.eclipse.org/Equinox_Transforms
Ideally, it would be configurable in the help webapp plug-in. The
plug-in would check a configuration property if the service selector
should be used or not. But I don't see a way to pass that to the
extension registry from outside other than the concept mentioned above.
-Gunnar
Gunnar Wagenknecht
Re: Question regarding ServiceSelector Filter mechanism [message #115291 is a reply to message #115132] Fri, 25 July 2008 03:52 Go to previous messageGo to next message
Hi Gunnar,
thanks for your thoughts on this. I didn't made up my mind yet how to
handle this. But I'm not lucky how this filter mechanism is working. In
my opinion those filters should not be set by the plug-in developer like
it happens in the webapp plug-in. This should be done by the one who
knows about the target system. I mean someone like that person who
creates a product. He is the one how can decide things like "ok I have
two http services instances and I map servlet x to service httpservice
one and servlet y to service two".
Ciao
Frank
Bereitgestellt: Mittwoch, 23. Juli 2008 20:50
usefull.
-Gunnar
Gunnar Wagenknecht
Re: Question regarding ServiceSelector Filter mechanism [message #115343 is a reply to message #115291] Fri, 25 July 2008 06:15 Go to previous messageGo to next message
--------------070803020002010000000306
> In my opinion those filters should not be set by the plug-in
> developer like it happens in the webapp plug-in. This should be done
> by the one who knows about the target system. I mean someone like
> that person who creates a product.
Yupp, I agree. There should be a "default" which can be overwritten by
product creators.
The problem with the serviceSelector element is that it leaks runtime
environment specifics into development.
FWIW, I've opend bug 239555 which patches the HTTP registry to limit the
service it registers with (mainly for security reasons). But this is not
really related to the HELP case. I think that the HELP WebApp developers
wanted to be good citizens. The HELP plug-in starts it's own service on
a random port only for the purpose to run the help content on it. Thus,
the usage of the serviceSelector is reasonable.
But did you know that there is any easy workaround? Simply deploy the
attached bundle and it will register the help content without any
serviceSelector. :)
-Gunnar
Gunnar Wagenknecht
Content-Type: application/octet-stream;
name="org.eclipseguru.eclipse.help.webapp.public_1.0.0.jar"
Content-Disposition: attachment;
filename*0="org.eclipseguru.eclipse.help.webapp.public_1.0.0.jar "
UEsDBAoAAAAAAORh+TgAAAAAAAAAAAAAAAAJAAQATUVUQS1JTkYv/soAAFBL AwQKAAAACADj
Yfk47O335FABAACwAgAAFAAAAE1FVEEtSU5GL01BTklGRVNULk1GfVFLa8JA EL4H8h8Wz2ZI
fLQQ8dCCtBUs0kI9b+KYrEl2t/vw8e+7JjFElN6Gne85u6Kc7VCb4AeVZoLH JILQ914t35YY
rNpttxx1q09aYUxWtEDyjqUkG0xepCRrm5Qs7VDf5yoR7qFBC5UBpiWTGjOr 7HWG3AnAERMq
JchaYKYZz0r0PWKc7dwoi51mP2kv6xf+WqZwuzhhao0DLPiBKcEr5CYmS3qg 34sggqfhclQP
0+sw8b2PSgplgjVNC5q1QYXOGOyUC34UqpgdGtf5IIIxhAPfa/2Cxv6mXL/Q LGnidfyx40dh
OBjWBNew5VzkuDjBXkvYUy1RgcKMaaPOdxp181ahoTudTiE3Rv7P7fyppGmO rd8F6nRu0FOY
QvR8YwWpUAjKcsMqfFBvconmdO4OklD9CN+co/e9fCtUTN4s51SRjfsQXnBM c+N7vvcHUEsD
BAoAAAAAAORh+TgAAAAAAAAAAAAAAAAKAAAALnNldHRpbmdzL1BLAwQKAAAA CADkYfk4GORE
a9AAAAB4AQAACgAAAC5jbGFzc3BhdGiVkMFqAjEQhs8t9B2W3J2tl9LDbqWU LShUi257lZgM
69R0EieJ6NurpVLxIPQ2//DNx/BXg+23KzYokTzXqg/3qkA23hJ3tfpoX3uP avB0d1sZp2MM
Oi0P4eYvISfZFStiWyvjWRXHZa28dIDGUYgIXzaB05nN8uCE0bSZv0zG7fNw 3EzLS444obB2
YHGRO8j0e4kCs6TZarGfb+0uYDnSGz1ren14UOW/XwoWwXhBEFxnErTvLnfE 8ZoqijmpjuMV
0ucUcjrBC+IfuCrPK9wDUEsDBAoAAAAIAORh+TjTB1LX8gAAAL8CAAAIAAAA LnByb2plY3S9
ks1KAzEUhdcKvkOZvUm7c5FOoUp3SqH1ATLJNU3JH/mpPn6TmFGGQXAh7s45 uYfvkoRsPrRa
XMAHac26W6FltwDDLJdGrLvX4+7+odv0d7fEeXsGFp8gMC9dzNM5vSGGauit FwiYki6ASD6N
Gp1AOfQOA3UOuTQoyQiuhdJkVmswsSd4VCVtmFANnrghScUPDlhxzT7mKjW8 JvNl0JlHxKzP
gl5oLYD/XiE3qBepsEPzeBoQPKP8ius4oGdq5BuEuP1f7IGdQNM/gbZkvPLM i8lDm/40M/xe
JSHNSz0s9Dr0U2HyPGbWGXUhfv2F6Qe8AlBLAwQKAAAACADkYfk46Qa/PpcA AABLAQAAJAAA
AC5zZXR0aW5ncy9vcmcuZWNsaXBzZS5qZHQuY29yZS5wcmVmc5WOvQrCMACE 90LfIeAemmpF
hE6ioJOgLxDba4nkj0vq89uls3U5bvg+7jYXGnGbrKgbodRxtz02SpzOj6eo q+pQFuisiQky
EgMI3yHJD5hM8K0qi8BRLsi7z7ILxBwuGgvOpccIL7PmiHy3Og+BrlVy/9t0 0Ro9z62hI8PL
wkmdEpivPXw2gwFbkIFrbfjJ/eumMHH5+AVQSwMECgAAAAgA5GH5OBrBg3ty AAAAewAAACQA
AAAuc2V0dGluZ3Mvb3JnLmVjbGlwc2UucGRlLmNvcmUucHJlZnMVycEKAiEU BdC94D8I7WUU
hokBV9EsWgX1A2V3wniovadDn1+d7dktnMypk/GjcW4ep9lP5nC8XI0fhr1W iJSqwFbGCkaO
ELuBJZUcnFaV+jPlM5cXYrP4NOR/SWjcoRVDCm2wjHdPjHvPD0JYbyS//AJQ SwMECgAAAAgA
5GH5OJiADecgAwAA2goAAAsAAABIRUxQLmxhdW5jaJ1WTW/aQBC9V+p/sKwc m6VVeqiq0AQF
mlRKAiIfl6qy1uvBLFl2t/sBWFH+e8c2wZQY4/aAIibzZt/MvH3s6dlqLoIF GMuV7IafyMcw
AMlUwmXaDR/uvx9/CQPrqEyoUBK6oVTh2bf3704F9ZJNL5Sc8NQb6hAeuExj hjIpASa4tkB0
AsRzMvjtuVSr6wIDJswLxEoJoLLnnOGxdxA8QdYNqdYgE0JNasNgQYXHgs54 CDsNGO/UHBmw
XpJsQBMqbDvUIxU8oQ7qoBYhMt1BYj2H/6B6g2hIxn7ZE1S8ft4Obwe/mogx jJlysK0psSL9
WrFiERvY0fNSmSerKYNIKPbSIXNwFJulHaKFT7m0nd11MWWgczW4HjVxTGBC vXBRPsQI5WFc
zba4dHtgBSISsACxwX1uOo9LJnwCQ523R0XdXAS3u8dtt5ZA7NNcixO6UIY7 uDTKaxu+QgfS
mey1bC2wVHwBK4PVuf8GNl6W0M5fnPcud7vgLHHrWphHRuPh5bh3E/XGlw83 g9v7u81gjpUN
jp5xzCk4ouxLcLzcCizzADVsWoXybxiUogpJgQFUlsWNNGhvP7274cP4YhCN evdXEVJ9/NEf
jMO6Ma1tIhdrDLmtCGpRtW46MmrBE3SM/zn+sXYw/ddknkqUek/rbi7Z4Liv bMqJVHdT7xK1
lN1KybUH56TXxrmpfkJOmmRsp2oZWRDAHCSRkiJrfcPLnUSxl4mAyhuZmhMe 44f58/Xt+rr+
+2F7MlA6MJlZTWbUajDEQIryM1kjLncDAittwOaN2tpkigYzBSI8AwmE4gXN LK9P3eUzdU43
M1kXx0bneD4RKkXbSg+TRuE6kC7/TTpMuhXXNjTL2TaWm4LQZAkx/tTV5s2V cTHNyAyQfCti
+yrtjA7Em6wZXdAVsWAWAi88iuMg88ODR3tzfN5upJUcW6WjDCdg0CGgnbrK zpu7bi/TwwvJ
HeT869uRzFTcTLjQRExt89QKg8pp87YDKHjvabTJqPB1w/CWtX9NeQv9smz5 cukZoDVPglpr
q94ou+42z8rJrO9yfQedmqcoxv8AUEsDBAoAAAAIAORh+TiQ9TntiAAAAAEB AAAQAAAAYnVp
bGQucHJvcGVydGllc22PsQoCMQyG90LfoQ+gvSdwcDhR0MPB0aWXK2cltqVJ wMc3OCk0Q4bv
J99PqEiD6L3bOWowWFOEq/AXzCkr0O1TBpQlksLLeNtvT9Nh2Nytcf/jO6yi rGp4v9AabfhV
zZJw8bWVGhunSJ3r43i+egyS4dHrAwxENXA3VPEzAvciiswpr6TvfQBQSwME CgAAAAgA5GH5
OFbPVvvDAQAAIA4AAAoAAABwbHVnaW4ueG1s1ZffTsIwFMbvTXyHpZcmdP65 MYbBhZGIMcYE
fIBSDqOktLXt5nh7O9jYBpgowyb0au16vvM735bmtNvPljxIQRsmRYRu8DUK QFA5ZSKO0Md4
0LlH/d7lRbcPlDNloNp7h283rxRPYibcUxAEXcgsiHzDeroZSjJhIyR1jAsV DJ8JEzLDc2sV
1hAzY/VqPaNSWCdiUK9U6NaWa6pusGmE5sCVSiac0SoiD9JgZKIpdJZEKVdN M9KNSSKmHJpY
uRj+gokLQXsBith5hMJmmnA3T4Ud1rgLd8KtPaewq0xd96pca9ITzojJ2ZvL E2KgI8gS9l/V
2Ic/uFzV/i/VGdAph8aPUCwdri2n1ZLv1EE5MebAR3YQoAXhxdcus+HHjcpo Mz3GlELpD9Qg
dhMdQ+1UvFFbqVz4eTGL2VlSnyO0PkdoQdKWxG8k9UbLWQq5TkvkVyfz7DZ4 PDna/hdjSX3S
zjSJl+1PaEc9KJS80TMxhawl9zDX8Et8IsfX5N49N0A0nbdEH61F/PYg2Ul6 kMyf09vmsiX3
U6njjfwKL8wvDu6yLXab8YIYBbpqjl9G7wNCrdSrh6M69wZws3F3N7pwe6X7 BlBLAQIUAwoA
AAAAAORh+TgAAAAAAAAAAAAAAAAJAAQAAAAAAAAAEADtQQAAAABNRVRBLUlO Ri/+ygAAUEsB
AhQDCgAAAAgA42H5OOzt9+RQAQAAsAIAABQAAAAAAAAAAAAAAKSBKwAAAE1F VEEtSU5GL01B
TklGRVNULk1GUEsBAhQDCgAAAAAA5GH5OAAAAAAAAAAAAAAAAAoAAAAAAAAA AAAQAO1BrQEA
AC5zZXR0aW5ncy9QSwECFAMKAAAACADkYfk4GOREa9AAAAB4AQAACgAAAAAA AAAAAAAApIHV
AQAALmNsYXNzcGF0aFBLAQIUAwoAAAAIAORh+TjTB1LX8gAAAL8CAAAIAAAA AAAAAAAAAACk
gc0CAAAucHJvamVjdFBLAQIUAwoAAAAIAORh+TjpBr8+lwAAAEsBAAAkAAAA AAAAAAAAAACk
geUDAAAuc2V0dGluZ3Mvb3JnLmVjbGlwc2UuamR0LmNvcmUucHJlZnNQSwEC FAMKAAAACADk
Yfk4GsGDe3IAAAB7AAAAJAAAAAAAAAAAAAAApIG+BAAALnNldHRpbmdzL29y Zy5lY2xpcHNl
LnBkZS5jb3JlLnByZWZzUEsBAhQDCgAAAAgA5GH5OJiADecgAwAA2goAAAsA AAAAAAAAAAAA
AKSBcgUAAEhFTFAubGF1bmNoUEsBAhQDCgAAAAgA5GH5OJD1Oe2IAAAAAQEA ABAAAAAAAAAA
AAAAAKSBuwgAAGJ1aWxkLnByb3BlcnRpZXNQSwECFAMKAAAACADkYfk4Vs9W +8MBAAAgDgAA
CgAAAAAAAAAAAAAApIFxCQAAcGx1Z2luLnhtbFBLBQYAAAAACgAKAHYCAABc CwAAAAA=
--------------070803020002010000000306--
Re: Question regarding ServiceSelector Filter mechanism [message #115356 is a reply to message #115343] Fri, 25 July 2008 06:52 Go to previous message
Hi again,
that's the precise phrase I was looking for :-)
Thanks for the bundle, I will check it out.
Ciao
Frank
Bereitgestellt: Freitag, 25. Juli 2008 12:16
> In my opinion those filters should not be set by the plug-in developer
> like it happens in the webapp plug-in. This should be done by the one
> who knows about the target system. I mean someone like that person who
> creates a product.
product creators.
serviceSelector. :)
-Gunnar
Gunnar Wagenknecht
Previous Topic:Resolving Ambiguity for Import-Package
Next Topic:No repository found for my update site
Current Time: Thu Jul 17 02:15:18 EDT 2025
Powered by FUDForum. Page generated in 0.56629 seconds
