Home » Language IDEs » Java Development Tools (JDT) » CVS Status Feature
CVS Status Feature [message #114810] Fri, 07 November 2003 12:26 Go to next message
It would be very cool if the CVS decorations showed whether a file needed
updating or committing or adding. On the other hand I would ditch the CVS
option string "(ASCII -kkv)" since I can assume that for all of my sources
and it ends up being clutter. BTW, is there a feature request process (e.g.,
JIRA) or just the newsgroup?
Re: CVS Status Feature [message #114823 is a reply to message #114810] Fri, 07 November 2003 12:45 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
You can already get rid of the -kkv, go to the
Windows->Preferences->Team->CVS->Label Decorations.
From there you can remove the {keyword} However that would remove it
for all, even those that are binary.
There is already an indication for needs adding (a ?) or
dirty/needs-commiting (a >)
Thanks, Rich Kulp
Re: CVS Status Feature [message #114849 is a reply to message #114810] Fri, 07 November 2003 13:04 Go to previous messageGo to next message
> file needed updating or committing or adding.
Window-->Preferences-->Team-->CVS-->Label Decorations-->('Icons'
tab)-->Indicate is outgoing.
> On the other hand I would ditch the CVS option string
in:
Window-->Preferences-->Team-->CVS-->Label Decorations-->('Text'
tab)-->'File Format:'
remove the '({keyword})' from the end. if you are using the 'Indicate is
outgoing' option above, you can also remove the '{dirty_flag} from 'File
Format:', 'Folder Format:', and 'Project Format:'.
> BTW, is there a feature request process (e.g., JIRA) or just
> the newsgroup?
goto:
http://bugs.eclipse.org
hth,
alvin
Re: CVS Status Feature [message #114986 is a reply to message #114823] Fri, 07 November 2003 17:44 Go to previous messageGo to next message
Kool, thanks.
Re: CVS Status Feature [message #114997 is a reply to message #114849] Fri, 07 November 2003 17:45 Go to previous messageGo to next message
Great but now I have another problem. EVERYTHING indicates an outgoing
change after I just fetched the whole tree using cvs co from the command
line and then fired up Eclipse. How do I sync 'em up again?
Re: CVS Status Feature [message #115034 is a reply to message #114997] Fri, 07 November 2003 18:04 Go to previous message
After doing an update all was well. All the files that were just checkout so
why an update was required is a mystery.
Previous Topic:"The project cannot be built until build path errors are resolved."
Next Topic:Custom taglets
Current Time: Sat Sep 06 20:56:12 EDT 2025
Powered by FUDForum. Page generated in 0.05124 seconds
