Home » Language IDEs » C / C++ IDE (CDT) » Unable to find Library file
Unable to find Library file [message #114807] Tue, 10 August 2004 04:00 Go to next message
Originally posted by: alanbocutt.ntlworld.com
I am sure that I am doing something stupid here so some help would be
appreciated if possible.
I have two projects in my workspace one to create a library file and one
which uses this library for inclusion of some functions..
The library file compiles correctly but the executable fails saying that
it cant find the library archive.
I have the library file complete pathed in the linker section of the
executable project but the only error I get is that the library cannot be
found
Re: Unable to find Library file [message #114848 is a reply to message #114807] Tue, 10 August 2004 09:34 Go to previous messageGo to next message
Alan,
Copy the linker output in your reply to the group. It might help us
diagnose the problem. Usually, it's something easy like a bad path, but
it could be the actual library you are telling the linker to link
against. Either way, it's easier to help with a real error output to
look at.
Sean
> found
Re: Unable to find Library file [message #114860 is a reply to message #114848] Tue, 10 August 2004 10:20 Go to previous messageGo to next message
Sean
this is the output that I get from the Linker
**** Incremental build of configuration Debug for project chprn_parser ****
make -k all
Building target: chprn_parser
gcc -static -ochprn_parser chprn_fun_parser.o
-l/home/bocutta/workspace/library/Release/liblibrary.a
/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../../i686-pc -linux-gnu/bin/ld:
cannot find -l/home/bocutta/workspace/library/Release/liblibrary.a
collect2: ld returned 1 exit status
make: *** [chprn_parser] Error 1
make: Target `all' not remade because of errors.
Build complete for project chprn_parser
and this is the library location
bocutta@jaguar Release $ ls -l
total 96
-rw-r--r-- 1 bocutta users 767 Aug 10 08:43 chprn_fun_asc2int_s.d
-rw-r--r-- 1 bocutta users 2152 Aug 10 08:43 chprn_fun_asc2int_s.o
-rw-r--r-- 1 bocutta users 1265 Aug 10 08:43 chprn_fun_asc2ip4_s.d
-rw-r--r-- 1 bocutta users 2196 Aug 10 08:43 chprn_fun_asc2ip4_s.o
-rw-r--r-- 1 bocutta users 1265 Aug 10 08:43 chprn_fun_asc2ip6_s.d
-rw-r--r-- 1 bocutta users 2524 Aug 10 08:43 chprn_fun_asc2ip6_s.o
-rw-r--r-- 1 bocutta users 767 Aug 10 08:43 chprn_fun_asc2num_s.d
-rw-r--r-- 1 bocutta users 2168 Aug 10 08:43 chprn_fun_asc2num_s.o
-rw-r--r-- 1 bocutta users 503 Aug 10 08:43 chprn_fun_instr.d
-rw-r--r-- 1 bocutta users 1008 Aug 10 08:43 chprn_fun_instr.o
-rw-r--r-- 1 bocutta users 1172 Aug 10 08:43 chprn_fun_parser_stack.d
-rw-r--r-- 1 bocutta users 5528 Aug 10 08:43 chprn_fun_parser_stack.o
-rw-r--r-- 1 bocutta users 635 Aug 10 08:43 chprn_fun_strings.d
-rw-r--r-- 1 bocutta users 1172 Aug 10 08:43 chprn_fun_strings.o
-rw-r--r-- 1 bocutta users 17706 Aug 10 08:43 liblibrary.a
-rw-r--r-- 1 bocutta users 704 Aug 10 08:43 makefile
-rw-r--r-- 1 bocutta users 663 Aug 10 08:43 objects.mk
-rw-r--r-- 1 bocutta users 383 Aug 10 08:43 sources.mk
-rw-r--r-- 1 bocutta users 1169 Aug 10 08:43 subdir.mk
Thanks for your help
Alan
Sean Evoy wrote:
> Alan,
> look at.
> Sean
> > found
Re: Unable to find Library file [message #114887 is a reply to message #114860] Tue, 10 August 2004 11:52 Go to previous messageGo to next message
Alan,
Usually, you spec the name of the library with the -l flag, and the
search path with the -L flag (i.e. -library and
-L/home/bocutta/workspace/library/Release). If you want to use the full
path as the argument to -l, I think you will want to format it as
-l/home/bocutta/workspace/library/Release/library.
Assuming you are using the managed build system, this is a problem that
is caused by the UI not stripping off the path and extension when you
browse to a library file. There's an open bug on it, 70274.
Alan Bocutt wrote:
> Sean
> make -k all
> total 96
> Alan
> Sean Evoy wrote:
>>Alan,
>>look at.
>>Sean
>>>found
Re: Unable to find Library file [message #114978 is a reply to message #114887] Wed, 11 August 2004 02:22 Go to previous messageGo to next message
Hi Sean
Thanks for your help this has solved my problem for me now just down to
debugging my code :)
Regs
Alan
Sean Evoy wrote:
> Alan,
> Alan Bocutt wrote:
> > Sean
> > make -k all
> > total 96
> > Alan
> > Sean Evoy wrote:
> >>Alan,
> >>look at.
> >>Sean
> >>>found
Re: Unable to find Library file [message #117139 is a reply to message #114887] Wed, 25 August 2004 06:16 Go to previous message
Originally posted by: toereki.web.de
Sean,
any workaround available ?
Andreas
Sean Evoy wrote:
> Alan,
> Alan Bocutt wrote:
>> Sean
>> make -k all Building target: chprn_parser
>> total 96
>> Alan
>> Sean Evoy wrote:
>>> Alan,
>>> but it could be the actual library you are telling the linker to link
>>> look at.
>>> Sean
>>>> one
>>>> that
>>>> cannot be
>>>> found
Previous Topic:Difference between MiniGW and VC6 compiling
Next Topic:How to prevent CDT from hanging?
Current Time: Mon Jul 21 20:08:48 EDT 2025
Powered by FUDForum. Page generated in 0.04357 seconds
