Home » Eclipse Projects » GEF » Getting the grid working
Getting the grid working [message #114736] Thu, 29 January 2004 13:14 Go to next message
Originally posted by: brian.fernandes.codito.com
I'm working with the latest CVS checkouts of GEF / Draw2d.
I want to know how I can get the grid working...
I've added the ToggleGridAction and added the grid to the view menu. the
menu entry toggles on and off just fine.
I've also set the properties of the gird like in the
LogicEditor#loadProperties.
Since I extended ScalableRootEditPart (for scaling only in the X direction),
I had to reimplement the GRID relavent portions in that.
But when I add the GRID_LAYER, my editor does not show up.. gives me an
"Error occured while creating this editor"
I think I traced this to a nullpointer exception in
ScrollingGraphicalViewer().getControl().setFocus() .. and control is null
for ScrollingGraphicalViewer..
I couldn't trace this further.. is there something else I need to be doing ?
Brian.
Re: Getting the grid working [message #114814 is a reply to message #114736] Fri, 30 January 2004 06:41 Go to previous messageGo to next message
I made a silly mistake, I had 2 lines setting the rulers
PROPERTY_GRID_SPACING. Once to a Dimension and once to a Point.
While copying the line, I forgot to change PROPERTY_GRID_SPACING to
PROPERTY_GRID_ORIGIN. aargh.
Brian.
Re: Getting the grid working [message #114826 is a reply to message #114736] Fri, 30 January 2004 06:50 Go to previous messageGo to next message
?n
No, that's it. You're doing everything you're supposed to do. Can you
provide a stack trace of the NPE?
"Brian Fernandes" <brian.fernandes@codito.com> wrote in message
news:bvbieo$649$1@eclipse.org...
direction),
> Brian.
Re: Getting the grid working [message #114889 is a reply to message #114736] Fri, 30 January 2004 10:51 Go to previous messageGo to next message
I got the GRID working, the error was what I mentioned in the last post -
forgot to mention that that was the cause of the NPE.
I would like to be able to have only vertical grid lines - for my app. the
horizontal grid lines are useless...
Since the GRID is still being developed, could you add that option in ? To
have either only horizontal or vertical grid lines ?
Brian.
Re: Getting the grid working [message #114915 is a reply to message #114814] Fri, 30 January 2004 11:17 Go to previous messageGo to next message
Pratik, the grid layer shouldn't barf from a missing property. Does it work
without setting the origin?
news:bvdfpc$7pl$1@eclipse.org...
> Brian.
Re: Getting the grid working [message #114968 is a reply to message #114915] Fri, 30 January 2004 11:24 Go to previous messageGo to next message
Hi Randy,
I just checked - it does not screw up if I fail to specify
PROPERTY_GIRD_ORIGIN.
My problem was, I had incorrectly specified a Point as a parameter to
To make it clearer; instead of the following two lines,
getGraphicalViewer().setProperty(SnapToGrid.PROPERTY_GRID_SP ACING, new
Dimension(10,10));
getGraphicalViewer().setProperty(SnapToGrid.PROPERTY_GRID_OR IGIN, new
Point());
I had incorrectly used these two (forgot to change the property when I
copied the first line - spent hours debugging it)
Dimension(10,10));
Point());
Brian.
Re: Getting the grid working [message #115006 is a reply to message #114889] Fri, 30 January 2004 13:07 Go to previous messageGo to next message
Please open a feature request for that.
news:bvdude$q78$1@eclipse.org...
To
> Brian.
Re: Getting the grid working [message #115159 is a reply to message #114736] Mon, 02 February 2004 09:03 Go to previous messageGo to next message
I have the grid layer working fine now (but I still need only vertical grid
lines).
My editor usually opens a very large diagram and after examing it, I clip
the diagram, by disregarding some models and moving the remaining models
forward along the X axis.
Unfortunately, the diagram remains as large as it was before the clipping.
If the diagram initally was 10000 pixels wide, and I clip all before 9000
pixels, the resulting diagram should be 1000 pixels wide. But it remains at
10000 pixels.
Since I'm using my own RootEditPart, I can remove the GRID layer - if I do,
and then clip the diagram, it is correctly sized at 1000 pixels wide and the
scrollbars behave appropriately.
Shouldn't the GRID layer be resizing itself ? Or is there anyway in which I
can force it to do so ?
Brian.
Re: Getting the grid working [message #115172 is a reply to message #115006] Mon, 02 February 2004 09:15 Go to previous messageGo to next message
Here is my feature request for a GRID with only horizontal or vertical grid
lines.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=51012
Re: Getting the grid working [message #115434 is a reply to message #115159] Tue, 03 February 2004 13:02 Go to previous messageGo to next message
It sounds like the grid layer is not implementing getPreferredSize(int, int)
correctly. Please open a bugzilla. This is an easy fix.
news:bvll79$pqt$1@eclipse.org...
grid
> lines).
> 10000 pixels.
do,
the
I
> Brian.
Re: Getting the grid working [message #115547 is a reply to message #115434] Wed, 04 February 2004 07:34 Go to previous message
Bug reported here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=51153
Hope that that is the problem, and it is indeed an easy fix.
Previous Topic:how can contentoutline responds to platformUI change
Next Topic:gef bendpoints problem
Current Time: Tue Dec 02 12:08:11 EST 2025
Powered by FUDForum. Page generated in 0.06174 seconds
