Page control? [message #114726] |
Tue, 24 January 2006 15:09  |
Originally posted by: mlorenz.nc.rr.com
I've seen references to a "Page" control on the palette. I don't find one
- is there something I missed with my 2.0RC2 upgrade?
I'm trying to add page number to my MasterPage.
Re: Page control? [message #117921 is a reply to message #117480] |
Thu, 26 January 2006 14:55   |
Hi Mark,
You can insert only one top-level element in the header or footer. Because
there's already a date element in the footer, you can't insert the page
element.
If you want only the page element, delete the date element first, then
insert the page element.
If you want to insert multiple elements, delete the date element first,
insert a grid, then insert as many elements as you want in the grid.
-Diana
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:3b27470f8da9f001acc6cdd697b9098b$1@www.eclipse.org...
> Thanks so much! I see the tabs at the top (as well as the menu items you
> mention). I had not noticed them - I had used the Outline to get to the
> Master page.
> OK, now I see the Palette items, but when I try to use them on the Master
> page, I get the "not" cursor and it won't add them. I want to have a page
> number instead of the date. How do I make this change?
> Thanks again, Mark
Re: Page control? [message #118131 is a reply to message #118081] |
Thu, 26 January 2006 16:35  |
Glad I was able to help. The rules aren't particularly intuitive. Speaking
of rules, there's another one that other users have unwittingly broken: No
data set fields on the master page.
-Diana
news:213c6c5b961cb563836c50ac322f7a6f$1@www.eclipse.org...
> Thanks for your help Diana. I finally got it to work. I didn't know
> about the "rules" you stated. Also, my palette and master page were
> acting a bit flaky (sometimes works, sometimes not).
> Mark
FUDForum. Page generated in 0.29824 seconds
