Home » Modeling » BPEL Designer » PartnerLink Problem
PartnerLink Problem [message #10439] Mon, 07 April 2008 07:13 Go to next message
Dea All
I have designed a simple process to call a web service. In order to define
a new PartnerLink,I click on new partner link.
Then I click on "Add WSDL" button of "Choose Prtner Link Type" and import
the WSDL file.
But after clicking on "OK" button and filling the approperiate fields, the
dialog box is not closed by clicking on
"Finish" button.
I don't know which part of my work is wrong.
Thanks for your help,
Arman
Re: PartnerLink Problem [message #507592 is a reply to message #10439] Wed, 13 January 2010 18:52 Go to previous messageGo to next message
Hi Arman,
I had the same problem. It's been a while, how did you solve it?
I have found a solution that seems to work for me and posted it here:
http://www.eclipse.org/forums/index.php?t=msg&goto=50759 1&#msg_507591
Thuy
[Updated on: Wed, 13 January 2010 18:52] by Moderator
Re: PartnerLink Problem [message #509005 is a reply to message #10439] Thu, 21 January 2010 00:30 Go to previous messageGo to next message
I can not reproduce your problem in my workspace. Could you write your steps detailed? 1.. 2.. 3..
Re: PartnerLink Problem [message #509115 is a reply to message #509005] Thu, 21 January 2010 07:31 Go to previous message
Hi grid.qian,
please check my new post at
It seems like I just had a faulty eclipse IDE.
Previous Topic:Unable to use element-typed variable in an invoke?
Next Topic:Cannot create a PartnerLink in BPEL Designer?
Current Time: Sun Jul 13 17:05:28 EDT 2025
Powered by FUDForum. Page generated in 0.03193 seconds
