Home » Newcomers » Newcomers » attaching javadoc
attaching javadoc [message #114301] Thu, 03 November 2005 05:01 Go to next message
Originally posted by: ranavishal.gmail.com
Hi All
I am using a external library but when I want to see the javadoc (on
hover/pop-up menu and then pressing F2 to focus) for the function used from
the same doesn't work.
Any ideas how it can be done??
Vishal
Re: attaching javadoc [message #114754 is a reply to message #114301] Fri, 04 November 2005 10:53 Go to previous message
You have to set Source Attachment or Javadoc location for this external
library.
Use following steps to do it:
1) Open project preferences
2) Go on Java Build Path page and Librairies tab
3) Expand your external library
4) Select Source attachment and press Edit button
5) Press on External file... button and find zip file of source files
or External folder... button if your source are still in a folder
6) Validate all dialogs and then you should get javadoc on hover and F2
Vishal Rana wrote:
> Hi All
> Regards
> Vishal
Previous Topic:Building jars.
Next Topic:how to use external packages in eclipse
Current Time: Mon Jul 21 21:02:55 EDT 2025
Powered by FUDForum. Page generated in 0.07454 seconds
