Home » Eclipse Projects » Eclipse Platform » [JFace] - Programmatically launching an editor throws an exception.
[JFace] - Programmatically launching an editor throws an exception. [message #114241] Thu, 21 August 2003 19:13 Go to next message
I am trying to create an editor on a file within a perspective but I get
an error of type org.eclipse.ui.PartInitException.
The message that the error gives me also makes no sense:
IWAW0109E Failed to create model.
The code I am using to create the error is given below:
public void performAction(String name)
IWorkspace workspace = ResourcesPlugin.getWorkspace();
IWorkbench bench = PlatformUI.getWorkbench();
IWorkspaceRoot rootSpace = workspace.getRoot();
IWorkbenchPage activePage;
IFile resourceToEdit = null;
try {
IResource[] projects = rootSpace.members();
for ( int i = 0; i < projects.length; i++ )
try {
IProject project =(IProject)projects[i];
resourceToEdit = project.getFile(name);
if ( resourceToEdit != null )
activePage =
bench.getActiveWorkbenchWindow().getActivePage();
activePage.openEditor(resourceToEdit);
} catch ( CoreException ce ) {
System.out.println(ce.getClass().getName() + " " +
ce.getMessage());
continue;
System.out.println("Core Exception while getting the projects");
The name passed in is <filename>.htm
Any ideas on what the error means or a possible solution are greatly
appreciated.
Thanks.
Re: [JFace] - Programmatically launching an editor throws an exception. [message #114321 is a reply to message #114241] Fri, 22 August 2003 01:34 Go to previous messageGo to next message
When is performAction called? In other words, do you have a stack trace for
the PartInitException?
Chris
"Philip Denno" <pdenno@rational.com> wrote in message
news:bi3jjq$smh$1@eclipse.org...
> try {
> try {
> activePage =
> ce.getMessage());
> continue;
> appreciated.
> Thanks.
Re: [JFace] - Programmatically launching an editor throws an exception. [message #114564 is a reply to message #114241] Fri, 22 August 2003 09:14 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
Look at the .lof file for the stack trace
Simon :-)
> try {
> try {
> activePage =
> ce.getMessage());
> continue;
> appreciated.
> Thanks.
Re: [JFace] - Programmatically launching an editor throws an exception. [message #114593 is a reply to message #114564] Fri, 22 August 2003 09:20 Go to previous messageGo to next message
Sorry I meant .log file (not .lof file)
Simon :-)
"Simon Arsenault" <simon@ibm.oti.lab> wrote in message
news:bi54vv$4rg$1@eclipse.org...
> Simon :-)
> > try {
> > try {
> > activePage =
> > ce.getMessage());
> > continue;
> > appreciated.
> > Thanks.
Re: [JFace] - Programmatically launching an editor throws an exception. [message #114868 is a reply to message #114593] Fri, 22 August 2003 12:14 Go to previous messageGo to next message
Best is to place a link on that file and erase it every time you
checked it (it gets huge realy fast ;).
Martin (Kersten)
> Simon :-)
> > Simon :-)
get
> > > try {
> > > try {
> > > activePage =
> > > ce.getMessage());
> > > continue;
> > > appreciated.
> > > Thanks.
Finding the .log file, was Re: [JFace] - Programmatically launching an editor throws an exception. [message #114909 is a reply to message #114868] Fri, 22 August 2003 12:55 Go to previous messageGo to next message
Finding the workspace .log file:
Alternative 1:
Window > Show View > PDE Runtime > Error Log
This gives you a view with the contents of the .log file.
Alternative 2:
Help > About Eclipse Platform > Configuration Details
Alternative 3:
locate the file yourself, <yourworkspace>/.metadata/.log
Chris
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in message
news:bi5fbt$gma$1@eclipse.org...
> Martin (Kersten)
> > Simon :-)
> > > Simon :-)
> get
> > > > try {
> > > > try {
> > > > activePage =
> > > > ce.getMessage());
> > > > continue;
projects");
> > > > appreciated.
> > > > Thanks.
Re: Finding the .log file, was Re: [JFace] - Programmatically launching an editor throws an except [message #115074 is a reply to message #114909] Fri, 22 August 2003 15:39 Go to previous messageGo to next message
> Alternative 1:
This Error log view is great. Never used that (I didn't even know it exists
Thanks Chris
Martin (Kersten)
> Alternative 2:
> Alternative 3:
> Chris
message
> > Martin (Kersten)
> > > Simon :-)
> > > > Simon :-)
I
> > get
> > > > > try {
> > > > > try {
> > > > > activePage =
> > > > > ce.getMessage());
> > > > > continue;
> projects");
greatly
> > > > > appreciated.
> > > > > Thanks.
Re: Finding the .log file, was Re: [JFace] - Programmatically launching an editor throws an except [message #115099 is a reply to message #115074] Fri, 22 August 2003 15:41 Go to previous messageGo to next message
Yeah. All it needs is a "Flush Contents" button <g>
news:bi5rd2$tt2$1@eclipse.org...
> > Alternative 1:
exists
> Thanks Chris
> Martin (Kersten)
> > Alternative 2:
> > Alternative 3:
> > Chris
> message
> > > Martin (Kersten)
> > > > Simon :-)
> > > > > Simon :-)
but
> I
> > > get
> > > > > > try {
> > > > > > try {
> > > > > > activePage =
> > > > > > ce.getMessage());
> > > > > > continue;
> > projects");
> greatly
> > > > > > appreciated.
> > > > > > Thanks.
Re: Finding the .log file, was Re: [JFace] - Programmatically launching an editor throws an except [message #117008 is a reply to message #115099] Tue, 26 August 2003 21:17 Go to previous message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
The red X erases the whole file, and you can also filter to just show the
current session (in 3.0).
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
"Chris Laffra" <Chris_Laffra@oti.com> wrote in message
news:bi5rlm$u75$1@eclipse.org...
Previous Topic:Workspace corrupted due to problems in org.eclipse.core.resources?
Next Topic:Examples cause large pauses/cpu utilization in 3.0 stream
Current Time: Mon Jul 21 22:16:46 EDT 2025
Powered by FUDForum. Page generated in 0.32303 seconds
