Home » Language IDEs » Java Development Tools (JDT) » Exit code 128
Exit code 128 [message #114237] Thu, 06 November 2003 04:59 Go to next message
Originally posted by: yen-yei.cheong.accenture.com
This is really urgent and I would be grateful if anyone can help. I am
unable to start up eclipse as a popup with the following message occurs
when I try to start it up:
Eclipse
JVM terminated. Exit code=128
C:\WINNT\system32\javaw.exe
-Xmx256M
-cp C:\Program Files\eclipse\startup.jar org.eclipse.core.launcher.Main
-os win32
-ws win32
-arch x86
-showsplash C:\Program Files\eclipse\eclipse.exe -showsplash 600
OK
Hope someone can help
Yen-yei
Re: Exit code 128 [message #114250 is a reply to message #114237] Thu, 06 November 2003 05:48 Go to previous messageGo to next message
> -Xmx256M
> -os win32
> -ws win32
> -arch x86
What kind of vm are you using? See
http://eclipsewiki.swiki.net/134#vmVersion for the requited JRE
versions. (You will need an 1.4 VM for the latest builds).
-tom
Re: Exit code 128 [message #114263 is a reply to message #114237] Thu, 06 November 2003 05:57 Go to previous message
Originally posted by: scheglov_ke.nlmk.ru
Yen-yei <yen-yei.cheong@accenture.com> wrote:
Remove javaw.exe from system32 and ensure that you have good one
in PATH.
> Eclipse
> -Xmx256M
> -os win32
> -ws win32
> -arch x86
> OK
> Yen-yei
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Previous Topic:"Synchronize CVS Projects"
Next Topic:Problem with RMI in eclipse (ClassNotFound)
Current Time: Fri Sep 12 15:30:02 EDT 2025
Powered by FUDForum. Page generated in 0.03017 seconds
