Home » Modeling » GMF (Graphical Modeling Framework) » Extending Palette from another plugin...
Extending Palette from another plugin... [message #114213] Mon, 26 March 2007 05:24 Go to next message
Hello all,
I'm actually trying to extend an Existing palette, by adding it a new
item, forwarding to a custom action.
But the problem is that i'm trying to do this from another plugin.
I followed the GMF Tutorial called "Configuring and Extending the
Diagram Palette", but whatever I do, my Item does not appear in the
palette... Do I forgot something, for example, to make a reference
between the 2 plugins ?
Thanks a lot in advance for your help !
Maxence
Re: Extending Palette from another plugin... [message #117437 is a reply to message #114213] Thu, 05 April 2007 10:54 Go to previous message
Maxence,
Did you get this to work yet? It should work if you followed the
tutorial. Is your provider being called at all?
Cherie
Maxence Vanbesien wrote:
> Hello all,
> Maxence
Previous Topic:Testing GMF diagram
Next Topic:Outline
Current Time: Fri Jul 18 04:21:18 EDT 2025
Powered by FUDForum. Page generated in 0.07510 seconds
