Home » Eclipse Projects » Eclipse Platform » Eclipse Help - accessing more than one plugin dir outside the eclipse structure
Eclipse Help - accessing more than one plugin dir outside the eclipse structure [message #114160] Thu, 21 August 2003 15:50 Go to next message
With feedback from people on this newsgroup, I was able to figure out how
to point to documentation outside the Eclipse directory structure.
I created a links directory under the Eclipse directory. Then in the
links directory, I created a file called .links and then added the line :
path=C:\\mydocumentation\\eclipse_plugins
When I ran Eclipse help again, it looked in
c:\mydocumentation\eclipse_plugins
and displayed the documentation in navigation window of the Eclipse help
system.
My next question is, could I specify more than one directory in the .links
file. Can I have two or more different paths. So that people could place
their documentation in more than one spot outside the Eclipse directory
structure. How would I do that?
I tried adding two paths such as:
path=C:\\mydocumentation\\anotherdirectory
But it always picks the last one. It does not use both the paths.
Is there another way to specify the paths so that more than one path can
be specified?
Probir
Re: Eclipse Help - accessing more than one plugin dir outside the eclipse structure [message #114257 is a reply to message #114160] Thu, 21 August 2003 19:35 Go to previous message
Originally posted by: dorian.birsan.net
Try adding another .link file.
"Probir Mukerjee" <probirkmukerjee@yahoo.com> wrote in message
news:bi37pe$ie9$1@eclipse.org...
> system.
> be specified?
> Probir
Previous Topic:ANNOUNCE: eclipse visualization tool
Next Topic:Plug-in manifest editor layout
Current Time: Sun Jul 13 11:12:19 EDT 2025
Powered by FUDForum. Page generated in 0.03847 seconds
