Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » teneo:support for QName
teneo:support for QName [message #114123] Fri, 07 March 2008 17:52 Go to next message
Hi Martin,
I thought there was a fix for QName in one of the latest builds. I am
using build 200802122150 and I get this error
[java] Initializing database datastore...
[java] javax.jdo.JDOUserException: Field "com.i
mpl.EventDefinitionImpl.alias" is declared as a reference type
(interface/Object
) but no implementation classes of "java.lang.Object" have been found!
[java] at
org.jpox.metadata.MetaDataUtils.getImplementationNamesForRef e
If I substitute "string" instead, my error goes away. Is QName note
supported by teneo?
Julia
Re: teneo:support for QName [message #114125 is a reply to message #114123] Fri, 07 March 2008 18:05 Go to previous message
--------------050009040503020503020503
Hi Julia,
I have a testcase for qname. I attached some of the (generated) files of the testcase so you can see
if there is a difference with your generated code. Maybe you don't have an explicit use of the QName
type in your code but your members have the type Object instead of QName?
gr. Martin
Julia wrote:
> Hi Martin,
> (interface/Object
> [java] at
> supported by teneo?
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="mysql_a_o_package.jdo"
Content-Disposition: inline;
filename="mysql_a_o_package.jdo"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPCFET0NU WVBFIGpkbyBT
WVNURU0gImZpbGU6L2phdmF4L2pkby9qZG8uZHRkIj4KCjxqZG8+Cgk8cGFj a2FnZSBuYW1l
PSJvcmcuZWNsaXBzZS5lbWYudGVuZW8uc2FtcGxlcy5lbWYuc2NoZW1hY29u c3RydWN0cy5x
bmFtZS5pbXBsIj4KCQk8Y2xhc3MgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLnRl bmVvLnNhbXBs
ZXMuZW1mLnNjaGVtYWNvbnN0cnVjdHMucW5hbWUuaW1wbC5NeXRlc3RJbXBs IiByZXF1aXJl
cy1leHRlbnQ9InRydWUiIHBlcnNpc3RlbmNlLW1vZGlmaWVyPSJwZXJzaXN0 ZW5jZS1jYXBh
YmxlIiBkZXRhY2hhYmxlPSJ0cnVlIiB0YWJsZT0ibXl0ZXN0IiBpZGVudGl0 eS10eXBlPSJk
YXRhc3RvcmUiPgoJCQk8aW1wbGVtZW50cyBuYW1lPSJvcmcuZWNsaXBzZS5l bWYudGVuZW8u
c2FtcGxlcy5lbWYuc2NoZW1hY29uc3RydWN0cy5xbmFtZS5NeXRlc3QiLz4K CQkJPGltcGxl
bWVudHMgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLmVjb3JlLkVPYmplY3QiLz4K CQkJPGltcGxl
bWVudHMgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLmNvbW1vbi5ub3RpZnkuTm90 aWZpZXIiLz4K
CQkJPGluaGVyaXRhbmNlIHN0cmF0ZWd5PSJuZXctdGFibGUiPgoJCQkJPGRp c2NyaW1pbmF0
b3IgY29sdW1uPSJkdHlwZSIgc3RyYXRlZ3k9InZhbHVlLW1hcCIgdmFsdWU9 Ik15dGVzdCIv
PgoJCQk8L2luaGVyaXRhbmNlPgoJCQk8dmVyc2lvbiBzdHJhdGVneT0idmVy c2lvbi1udW1i
ZXIiIGNvbHVtbj0iZV92ZXJzaW9uIi8+CgkJCTxmaWVsZCBuYW1lPSJkZXNj cmlwdGlvbiIg
cGVyc2lzdGVuY2UtbW9kaWZpZXI9InBlcnNpc3RlbnQiIG51bGwtdmFsdWU9 ImV4Y2VwdGlv
biIvPgoJCQk8ZmllbGQgbmFtZT0ibmFtZSIgcGVyc2lzdGVuY2UtbW9kaWZp ZXI9InBlcnNp
c3RlbnQiIG51bGwtdmFsdWU9ImV4Y2VwdGlvbiIgZW1iZWRkZWQ9InRydWUi Lz4KCQkJPGZp
ZWxkIG5hbWU9Im5hbWVzIiBwZXJzaXN0ZW5jZS1tb2RpZmllcj0icGVyc2lz dGVudCI+CgkJ
CQk8Y29sbGVjdGlvbiBlbGVtZW50LXR5cGU9ImphdmF4LnhtbC5uYW1lc3Bh Y2UuUU5hbWUi
PgoJCQkJCTxleHRlbnNpb24gdmVuZG9yLW5hbWU9Impwb3giIGtleT0iY2Fj aGUtbGF6eS1s
b2FkaW5nIiB2YWx1ZT0idHJ1ZSIvPgoJCQkJPC9jb2xsZWN0aW9uPgoJCQkJ PGpvaW4gbmFt
ZT0ibXl0ZXN0X25hbWVzIi8+CgkJCQk8b3JkZXIgY29sdW1uPSJNWVRFU1Rf TkFNRVNfSURY
Ii8+CgkJCTwvZmllbGQ+CgkJPC9jbGFzcz4KCTwvcGFja2FnZT4KPC9qZG8+
Content-Type: text/x-java;
name="Mytest.java"
filename="Mytest.java"
* <copyright>
* </copyright>
* $Id: Mytest.java,v 1.1 2007/11/15 19:56:40 mtaal Exp $
package org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname;
import javax.xml.namespace.QName;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.ecore.EObject;
* <!-- begin-user-doc -->
* A representation of the model object '<em><b>Mytest</b></em>'.
* <!-- end-user-doc -->
* <p>
* The following features are supported:
* <ul>
* <li>{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Myt est#getDescription <em>Description</em>}</li>
* <li>{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Myt est#getName <em>Name</em>}</li>
* <li>{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Myt est#getNames <em>Names</em>}</li>
* </ul>
* </p>
* @see org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Qna mePackage#getMytest()
* @model extendedMetaData="name='mytest' kind='elementOnly'"
* @generated
public interface Mytest extends EObject {
* Returns the value of the '<em><b>Description</b></em>' attribute.
* <p>
* If the meaning of the '<em>Description</em>' attribute isn't clear,
* there really should be more of a description here...
* </p>
* @return the value of the '<em>Description</em>' attribute.
* @see #setDescription(String)
* @see org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Qna mePackage#getMytest_Description()
* @model dataType="org.eclipse.emf.ecore.xml.type.String" required="true"
* extendedMetaData="kind='element' name='description' namespace='##targetNamespace'"
* @generated
String getDescription();
* Sets the value of the '{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Myt est#getDescription <em>Description</em>}' attribute.
* @param value the new value of the '<em>Description</em>' attribute.
* @see #getDescription()
* @generated
void setDescription(String value);
* Returns the value of the '<em><b>Name</b></em>' attribute.
* <p>
* If the meaning of the '<em>Name</em>' attribute isn't clear,
* </p>
* @return the value of the '<em>Name</em>' attribute.
* @see #setName(QName)
* @see org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Qna mePackage#getMytest_Name()
* @model dataType="org.eclipse.emf.ecore.xml.type.QName" required="true"
* extendedMetaData="kind='element' name='name' namespace='##targetNamespace'"
* @generated
QName getName();
* Sets the value of the '{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Myt est#getName <em>Name</em>}' attribute.
* @param value the new value of the '<em>Name</em>' attribute.
* @see #getName()
* @generated
void setName(QName value);
* Returns the value of the '<em><b>Names</b></em>' attribute list.
* The list contents are of type {@link javax.xml.namespace.QName}.
* <p>
* If the meaning of the '<em>Names</em>' attribute list isn't clear,
* </p>
* @return the value of the '<em>Names</em>' attribute list.
* @see org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Qna mePackage#getMytest_Names()
* @model unique="false" dataType="org.eclipse.emf.ecore.xml.type.QName" required="true"
* extendedMetaData="kind='element' name='names' namespace='##targetNamespace'"
* @generated
EList<QName> getNames();
} // Mytest
name="MytestImpl.java"
filename="MytestImpl.java"
* <copyright>
* </copyright>
* $Id: MytestImpl.java,v 1.1 2007/11/15 19:56:40 mtaal Exp $
package org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.imp l;
import java.util.Collection;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.impl.ENotificationImpl;
import org.eclipse.emf.ecore.impl.EObjectImpl;
import org.eclipse.emf.ecore.util.EDataTypeEList;
import org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Myt est;
import org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.Qna mePackage;
* An implementation of the model object '<em><b>Mytest</b></em>'.
* <p>
* The following features are implemented:
* <ul>
* <li>{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.imp l.MytestImpl#getDescription <em>Description</em>}</li>
* <li>{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.imp l.MytestImpl#getName <em>Name</em>}</li>
* <li>{@link org.eclipse.emf.teneo.samples.emf.schemaconstructs.qname.imp l.MytestImpl#getNames <em>Names</em>}</li>
* </ul>
* </p>
* @generated
public class MytestImpl extends EObjectImpl implements Mytest {
* The default value of the '{@link #getDescription() <em>Description</em>}' attribute.
* @generated
* @ordered
protected static final String DESCRIPTION_EDEFAULT = null;
* The cached value of the '{@link #getDescription() <em>Description</em>}' attribute.
* @generated
* @ordered
protected String description = DESCRIPTION_EDEFAULT;
* The default value of the '{@link #getName() <em>Name</em>}' attribute.
* @see #getName()
* @generated
* @ordered
protected static final QName NAME_EDEFAULT = null;
* The cached value of the '{@link #getName() <em>Name</em>}' attribute.
* @see #getName()
* @generated
* @ordered
protected QName name = NAME_EDEFAULT;
* The cached value of the '{@link #getNames() <em>Names</em>}' attribute list.
* @see #getNames()
* @generated
* @ordered
protected EList<QName> names;
* @generated
protected MytestImpl() {
super();
* @generated
protected EClass eStaticClass() {
return QnamePackage.Literals.MYTEST;
* @generated
public String getDescription() {
return description;
* @generated
public void setDescription(String newDescription) {
String oldDescription = description;
description = newDescription;
if (eNotificationRequired())
eNotify(new ENotificationImpl(this, Notification.SET, QnamePackage.MYTEST__DESCRIPTION, oldDescription, description));
* @generated
public QName getName() {
return name;
* @generated
public void setName(QName newName) {
QName oldName = name;
name = newName;
eNotify(new ENotificationImpl(this, Notification.SET, QnamePackage.MYTEST__NAME, oldName, name));
* @generated
public EList<QName> getNames() {
if (names == null) {
names = new EDataTypeEList<QName>(QName.class, this, QnamePackage.MYTEST__NAMES);
return names;
* @generated
public Object eGet(int featureID, boolean resolve, boolean coreType) {
switch (featureID) {
case QnamePackage.MYTEST__DESCRIPTION:
return getDescription();
case QnamePackage.MYTEST__NAME:
return getName();
case QnamePackage.MYTEST__NAMES:
return getNames();
return super.eGet(featureID, resolve, coreType);
* @generated
@SuppressWarnings("unchecked")
public void eSet(int featureID, Object newValue) {
setDescription((String)newValue);
return;
setName((QName)newValue);
return;
getNames().clear();
getNames().addAll((Collection<? extends QName>)newValue);
return;
super.eSet(featureID, newValue);
* @generated
public void eUnset(int featureID) {
setDescription(DESCRIPTION_EDEFAULT);
return;
setName(NAME_EDEFAULT);
return;
getNames().clear();
return;
super.eUnset(featureID);
* @generated
public boolean eIsSet(int featureID) {
return DESCRIPTION_EDEFAULT == null ? description != null : !DESCRIPTION_EDEFAULT.equals(description);
return NAME_EDEFAULT == null ? name != null : !NAME_EDEFAULT.equals(name);
return names != null && !names.isEmpty();
return super.eIsSet(featureID);
* @generated
public String toString() {
if (eIsProxy()) return super.toString();
StringBuffer result = new StringBuffer(super.toString());
result.append(" (description: ");
result.append(description);
result.append(", name: ");
result.append(name);
result.append(", names: ");
result.append(names);
result.append(')');
return result.toString();
} //MytestImpl
name="qname.ecore"
filename="qname.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="qname"
nsURI=" http://www.eclipse.org/emf/teneo/samples/emf/schemaconstruct s/qname" nsPrefix="qname">
<eAnnotations source="http://www.w3.org/XML/1998/namespace">
<details key="lang" value="en"/>
</eAnnotations>
<eClassifiers xsi:type="ecore:EClass" name="DocumentRoot">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value=""/>
<details key="kind" value="mixed"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="mixed" unique="false" upperBound="-1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
<details key="kind" value="elementWildcard"/>
<details key="name" value=":mixed"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EReference" name="xMLNSPrefixMap" upperBound="-1"
eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EStringToStringMapEn try"
transient="true" containment="true" resolveProxies="false">
<details key="kind" value="attribute"/>
<details key="name" value="xmlns:prefix"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="xSISchemaLocation" upperBound="-1"
<details key="name" value="xsi:schemaLocation"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="atest" upperBound="-2"
eType="#//Mytest" volatile="true" transient="true" derived="true" containment="true"
<details key="kind" value="element"/>
<details key="name" value="atest"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Mytest">
<details key="name" value="mytest"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="description" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="name" value="description"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//QName">
<details key="name" value="name"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="names" unique="false" lowerBound="1"
upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//QName">
<details key="name" value="names"/>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
name="qname.genmodel"
filename="qname.genmodel"
<genmodel:GenModel xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel" modelDirectory="/org.eclipse.emf.teneo.samples/src"
modelPluginID="org.eclipse.emf.teneo.samples" modelName="Qname" importerID="org.eclipse.xsd.ecore.importer"
complianceLevel="5.0" copyrightFields="false">
<foreignModel>qname.xsd</foreignModel>
<genPackages prefix="Qname" basePackage="org.eclipse.emf.teneo.samples.emf.schemaconstructs "
resource="XML" disposableProviderFactory="true" ecorePackage="qname.ecore#/">
<genClasses ecoreClass="qname.ecore#//DocumentRoot">
<genFeatures property="None" notify="false" createChild="false" ecoreFeature="ecore:EAttribute qname.ecore#//DocumentRoot/mixed"/>
<genFeatures property="None" notify="false" createChild="false" ecoreFeature="ecore:EReference qname.ecore#//DocumentRoot/xMLNSPrefixMap"/>
<genFeatures property="None" notify="false" createChild="false" ecoreFeature="ecore:EReference qname.ecore#//DocumentRoot/xSISchemaLocation"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference qname.ecore#//DocumentRoot/atest"/>
</genClasses>
<genClasses ecoreClass="qname.ecore#//Mytest">
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute qname.ecore#//Mytest/description"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute qname.ecore#//Mytest/name"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute qname.ecore#//Mytest/names"/>
</genClasses>
</genPackages>
</genmodel:GenModel>
name="qname.xsd"
filename="qname.xsd"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPHhzOnNj aGVtYSBlbGVt
ZW50Rm9ybURlZmF1bHQ9InF1YWxpZmllZCIgYXR0cmlidXRlRm9ybURlZmF1 bHQ9InVucXVh
bGlmaWVkIiB2ZXJzaW9uPSJ4LngueC54IiB4bWw6bGFuZz0iZW4iCgl4bWxu czplY29yZT0i
aHR0cDovL3d3dy5lY2xpcHNlLm9yZy9lbWYvMjAwMi9FY29yZSIKCXRhcmdl dE5hbWVzcGFj
ZT0iaHR0cDovL3d3dy5lY2xpcHNlLm9yZy9lbWYvdGVuZW8vc2FtcGxlcy9l bWYvc2NoZW1h
Y29uc3RydWN0cy9xbmFtZSIKCXhtbG5zOnRoaXM9Imh0dHA6Ly93d3cuZWNs aXBzZS5vcmcv
ZW1mL3RlbmVvL3NhbXBsZXMvZW1mL3NjaGVtYWNvbnN0cnVjdHMvcW5hbWUi Cgl4bWxuczp4
cz0iaHR0cDovL3d3dy53My5vcmcvMjAwMS9YTUxTY2hlbWEiPgoKCTx4czpl bGVtZW50IG5h
bWU9ImF0ZXN0IiB0eXBlPSJ0aGlzOm15dGVzdCIgLz4KCTx4czpjb21wbGV4 VHlwZSBuYW1l
PSJteXRlc3QiPgoJCTx4czpzZXF1ZW5jZT4KCQkJPHhzOmVsZW1lbnQgbmFt ZT0iZGVzY3Jp
cHRpb24iIHR5cGU9InhzOnN0cmluZyIgLz4KCQkJPHhzOmVsZW1lbnQgbmFt ZT0ibmFtZSIg
dHlwZT0ieHM6UU5hbWUiIC8+CgkJCTx4czplbGVtZW50IG5hbWU9Im5hbWVz IiB0eXBlPSJ4
czpRTmFtZSIgbWF4T2NjdXJzPSJ1bmJvdW5kZWQiLz4KCQk8L3hzOnNlcXVl bmNlPgoJPC94
czpjb21wbGV4VHlwZT4KCjwveHM6c2NoZW1hPg==
name="QNameAction.java"
filename="QNameAction.java"
LyoqCiAqIDxjb3B5cmlnaHQ+CiAqCiAqIENvcHlyaWdodCAoYykgMjAwNSwg MjAwNiwgMjAw
NywgMjAwOCBTcHJpbmdzaXRlIEJWIChUaGUgTmV0aGVybGFuZHMpIGFuZCBv dGhlcnMKICog
QWxsIHJpZ2h0cyByZXNlcnZlZC4gVGhpcyBwcm9ncmFtIGFuZCB0aGUgYWNj b21wYW55aW5n
IG1hdGVyaWFscwogKiBhcmUgbWFkZSBhdmFpbGFibGUgdW5kZXIgdGhlIHRl cm1zIG9mIHRo
ZSBFY2xpcHNlIFB1YmxpYyBMaWNlbnNlIHYxLjAKICogd2hpY2ggYWNjb21w YW5pZXMgdGhp
cyBkaXN0cmlidXRpb24sIGFuZCBpcyBhdmFpbGFibGUgYXQKICogaHR0cDov L3d3dy5lY2xp
cHNlLm9yZy9sZWdhbC9lcGwtdjEwLmh0bWwKICoKICogQ29udHJpYnV0b3Jz OgogKiAgIE1h
cnRpbiBUYWFsCiAqIDwvY29weXJpZ2h0PgogKgogKiAkSWQ6IFFOYW1lQWN0 aW9uLmphdmEs
diAxLjMgMjAwOC8wMi8yOCAwNzowODoxNiBtdGFhbCBFeHAgJAogKi8KCnBh Y2thZ2Ugb3Jn
LmVjbGlwc2UuZW1mLnRlbmVvLnRlc3QuZW1mLnNjaGVtYWNvbnN0cnVjdHM7 CgppbXBvcnQg
amF2YXgueG1sLm5hbWVzcGFjZS5RTmFtZTsKCmltcG9ydCBvcmcuZWNsaXBz ZS5lbWYudGVu
ZW8uc2FtcGxlcy5lbWYuc2NoZW1hY29uc3RydWN0cy5xbmFtZS5NeXRlc3Q7 CmltcG9ydCBv
cmcuZWNsaXBzZS5lbWYudGVuZW8uc2FtcGxlcy5lbWYuc2NoZW1hY29uc3Ry dWN0cy5xbmFt
ZS5RbmFtZUZhY3Rvcnk7CmltcG9ydCBvcmcuZWNsaXBzZS5lbWYudGVuZW8u c2FtcGxlcy5l
bWYuc2NoZW1hY29uc3RydWN0cy5xbmFtZS5RbmFtZVBhY2thZ2U7CmltcG9y dCBvcmcuZWNs
aXBzZS5lbWYudGVuZW8udGVzdC5BYnN0cmFjdFRlc3RBY3Rpb247CmltcG9y dCBvcmcuZWNs
aXBzZS5lbWYudGVuZW8udGVzdC5zdG9yZXMuVGVzdFN0b3JlOwoKLyoqCiAq IFNpbXBsZSB0
ZXN0IGZvcjogcW5hbWUKICogCiAqIEBhdXRob3IgPGEgaHJlZj0ibWFpbHRv Om10YWFsQGVs
dmVyLm9yZyI+TWFydGluIFRhYWw8L2E+CiAqIEB2ZXJzaW9uICRSZXZpc2lv bjogMS4zICQK
ICovCnB1YmxpYyBjbGFzcyBRTmFtZUFjdGlvbiBleHRlbmRzIEFic3RyYWN0 VGVzdEFjdGlv
biB7CgoJLyoqIFRoZSBudW1iZXIgb2YgdGVzdCBvYmplY3RzIGNyZWF0ZWQg Ki8KCXByaXZh
dGUgc3RhdGljIGZpbmFsIGludCBOT19URVNUX09CSkVDVFMgPSA1OwoKCS8q KgoJICogQ29u
c3RydWN0b3IgZm9yIENsYXNzSGllcmFyY2h5UGFyc2luZy4KCSAqIAoJICog QHBhcmFtIGFy
ZzAKCSAqLwoJcHVibGljIFFOYW1lQWN0aW9uKCkgewoJCXN1cGVyKFFuYW1l UGFja2FnZS5l
SU5TVEFOQ0UpOwoJfQoKCS8qKiBDcmVhdGVzIHNpbXBsZSB0eXBlcyBhbmQg dGVzdHMgYWdh
aW5zdCAqLwoJQE92ZXJyaWRlCglwdWJsaWMgdm9pZCBkb0FjdGlvbihUZXN0 U3RvcmUgc3Rv
cmUpIHsKCQlmaW5hbCBRbmFtZUZhY3RvcnkgZmFjdG9yeSA9IFFuYW1lRmFj dG9yeS5lSU5T
VEFOQ0U7CgoJCS8vIHN0b3JlIGFuIGFsbCB0eXBlCgkJewoJCQlzdG9yZS5i ZWdpblRyYW5z
YWN0aW9uKCk7CgkJCU15dGVzdCBteXRlc3QgPSBmYWN0b3J5LmNyZWF0ZU15 dGVzdCgpOwoJ
CQlteXRlc3Quc2V0RGVzY3JpcHRpb24oInRlc3QiKTsKCQkJZm9yIChpbnQg aSA9IDA7IGkg
PCBOT19URVNUX09CSkVDVFM7IGkrKykgewoJCQkJUU5hbWUgcU5hbWUgPSBu ZXcgUU5hbWUo
Imh0dHA6Ly93d3cuZWx2ZXIub3JnLyIgKyBpLCAibG9jYWwiICsgaSwgInBy ZWZpeCIgKyBp
KTsKCQkJCW15dGVzdC5nZXROYW1lcygpLmFkZChxTmFtZSk7CgkJCX0KCQkJ bXl0ZXN0LnNl
dE5hbWUobmV3IFFOYW1lKCJodHRwOi8vd3d3LnNwcmluZ3NpdGUuY29tIiwg Im5hbWUiLCAi
ZSIpKTsKCQkJc3RvcmUuc3RvcmUobXl0ZXN0KTsKCQkJc3RvcmUuY29tbWl0 VHJhbnNhY3Rp
b24oKTsKCQl9CgoJCXsKCQkJc3RvcmUuYmVnaW5UcmFuc2FjdGlvbigpOwoJ CQlmaW5hbCBN
eXRlc3QgbXl0ZXN0ID0gc3RvcmUuZ2V0T2JqZWN0KE15dGVzdC5jbGFzcyk7 CgkJCWFzc2Vy
dEVxdWFscyhteXRlc3QuZ2V0TmFtZXMoKS5zaXplKCksIE5PX1RFU1RfT0JK RUNUUyk7CgkJ
CWZvciAoaW50IGkgPSAwOyBpIDwgTk9fVEVTVF9PQkpFQ1RTOyBpKyspIHsK CQkJCWZpbmFs
IFFOYW1lIHFOYW1lID0gbXl0ZXN0LmdldE5hbWVzKCkuZ2V0KGkpOwoJCQkJ YXNzZXJ0RXF1
YWxzKHFOYW1lLmdldE5hbWVzcGFjZVVSSSgpLCAiaHR0cDovL3d3dy5lbHZl ci5vcmcvIiAr
IGkpOwoJCQkJYXNzZXJ0RXF1YWxzKHFOYW1lLmdldExvY2FsUGFydCgpLCAi bG9jYWwiICsg
aSk7CgkJCQlhc3NlcnRFcXVhbHMocU5hbWUuZ2V0UHJlZml4KCksICJwcmVm aXgiICsgaSk7
CgkJCX0KCQkJYXNzZXJ0RXF1YWxzKG15dGVzdC5nZXROYW1lKCkuZ2V0TmFt ZXNwYWNlVVJJ
KCksICJodHRwOi8vd3d3LnNwcmluZ3NpdGUuY29tIik7CgkJCWFzc2VydEVx dWFscyhteXRl
c3QuZ2V0TmFtZSgpLmdldExvY2FsUGFydCgpLCAibmFtZSIpOwoJCQlhc3Nl cnRFcXVhbHMo
bXl0ZXN0LmdldE5hbWUoKS5nZXRQcmVmaXgoKSwgImUiKTsKCQkJc3RvcmUu Y29tbWl0VHJh
bnNhY3Rpb24oKTsKCQl9Cgl9Cn0=
name="QNameMapping.java"
filename="QNameMapping.java"
cnRpbiBUYWFsCiAqIDwvY29weXJpZ2h0PgogKgogKiAkSWQ6IFFOYW1lTWFw cGluZy5qYXZh
LHYgMS4yIDIwMDgvMDIvMjggMDc6MDk6MDMgbXRhYWwgRXhwICQKICovCgpw YWNrYWdlIG9y
Zy5lY2xpcHNlLmVtZi50ZW5lby5qcG94Lm1hcHBpbmc7CgppbXBvcnQgamF2 YXgueG1sLm5h
bWVzcGFjZS5RTmFtZTsKCmltcG9ydCBvcmcuZWNsaXBzZS5lbWYudGVuZW8u anBveC5KcG94
U3RvcmVFeGNlcHRpb247CmltcG9ydCBvcmcuanBveC5DbGFzc0xvYWRlclJl c29sdmVyOwpp
bXBvcnQgb3JnLmpwb3guc3RvcmUubWFwcGluZy5PYmplY3RBc1N0cmluZ01h cHBpbmc7Cgov
KioKICogSW1wbGVtZW50cyBjdXN0b20gbWFwcGluZyBmb3IgcW5hbWUuCiAq IAogKiBAYXV0
aG9yIDxhIGhyZWY9Im1haWx0bzptdGFhbEBlbHZlci5vcmciPk1hcnRpbiBU YWFsPC9hPgog
KiBAdmVyc2lvbiAkUmV2aXNpb246IDEuMiAkICREYXRlOiAyMDA4LzAyLzI4 IDA3OjA5OjAz
ICQKICovCgpwdWJsaWMgY2xhc3MgUU5hbWVNYXBwaW5nIGV4dGVuZHMgT2Jq ZWN0QXNTdHJp
bmdNYXBwaW5nIHsKCglwcml2YXRlIHN0YXRpYyBmaW5hbCBRTmFtZSBTQU1Q TEUgPSBuZXcg
UU5hbWUoImh0dHA6Ly93d3cuZWx2ZXIub3JnIiwgImVsdmVyIiwgImUiKTsK CglAT3ZlcnJp
ZGUKCXB1YmxpYyBPYmplY3QgZ2V0U2FtcGxlVmFsdWUoQ2xhc3NMb2FkZXJS ZXNvbHZlciBj
bHIpIHsKCQlyZXR1cm4gU0FNUExFOwoJfQoKCS8qCgkgKiAobm9uLUphdmFk b2MpCgkgKiAK
CSAqIEBzZWUgb3JnLmpwb3guc3RvcmUubWFwcGluZy5PYmplY3RBc1N0cmlu Z01hcHBpbmcj
Z2V0SmF2YVR5cGUoKQoJICovCglAT3ZlcnJpZGUKCXB1YmxpYyBDbGFzcyBn ZXRKYXZhVHlw
ZSgpIHsKCQlyZXR1cm4gUU5hbWUuY2xhc3M7Cgl9CgoJLyoKCSAqIChub24t SmF2YWRvYykK
CSAqIAoJICogQHNlZSBvcmcuanBveC5zdG9yZS5tYXBwaW5nLk9iamVjdEFz U3RyaW5nTWFw
cGluZyNvYmplY3RUb1N0cmluZyhqYXZhLmxhbmcuT2JqZWN0KQoJICovCglA T3ZlcnJpZGUK
CXByb3RlY3RlZCBTdHJpbmcgb2JqZWN0VG9TdHJpbmcoT2JqZWN0IG9iamVj dCkgewoJCWZp
bmFsIFFOYW1lIHFOYW1lID0gKFFOYW1lKSBvYmplY3Q7CgkJcmV0dXJuICJ7 IiArIHFOYW1l
LmdldE5hbWVzcGFjZVVSSSgpICsgIn0iICsgcU5hbWUuZ2V0UHJlZml4KCkg KyAiOiIgKyBx
TmFtZS5nZXRMb2NhbFBhcnQoKTsKCX0KCgkvKgoJICogKG5vbi1KYXZhZG9j KQoJICogCgkg
KiBAc2VlIG9yZy5qcG94LnN0b3JlLm1hcHBpbmcuT2JqZWN0QXNTdHJpbmdN YXBwaW5nI3N0
cmluZ1RvT2JqZWN0KGphdmEubGFuZy5TdHJpbmcpCgkgKi8KCUBPdmVycmlk ZQoJcHJvdGVj
dGVkIE9iamVjdCBzdHJpbmdUb09iamVjdChTdHJpbmcgc3RyKSB7CgkJaWYg KHN0ci5pbmRl
eE9mKCJ7IikgPT0gLTEpIHsKCQkJdGhyb3cgbmV3IEpwb3hTdG9yZUV4Y2Vw dGlvbigiU3Ry
aW5nICIgKyBzdHIgKyAiIGNhbiBub3QgYmUgY29udmVydGVkIHRvIGEgUU5h bWUsIG1pc3Np
bmcgc3RhcnRpbmcgeyIpOwoJCX0KCQlmaW5hbCBpbnQgZW5kSW5kZXhOUyA9 IHN0ci5pbmRl
eE9mKCJ9Iik7CgkJaWYgKGVuZEluZGV4TlMgPT0gLTEpIHsKCQkJdGhyb3cg bmV3IEpwb3hT
dG9yZUV4Y2VwdGlvbigiU3RyaW5nICIgKyBzdHIgKwoJCQkJCSIgY2FuIG5v dCBiZSBjb252
ZXJ0ZWQgdG8gYSBRTmFtZSwgbWlzc2luZyBlbmQgbnMgZGVsaW1pdGVyIH0g Iik7CgkJfQoJ
CWZpbmFsIGludCBwcmVmaXhJbmRleCA9IHN0ci5pbmRleE9mKCI6IiwgZW5k SW5kZXhOUyk7
CgkJaWYgKHByZWZpeEluZGV4ID09IC0xKSB7CgkJCXRocm93IG5ldyBKcG94 U3RvcmVFeGNl
cHRpb24oIlN0cmluZyAiICsgc3RyICsKCQkJCQkiIGNhbiBub3QgYmUgY29u dmVydGVkIHRv
IGEgUU5hbWUsIG1pc3NpbmcgcHJlZml4IGRlbGltaXRlciA6Iik7CgkJfQoJ CWZpbmFsIFN0
cmluZyBucyA9IHN0ci5zdWJzdHJpbmcoMSwgZW5kSW5kZXhOUyk7CgkJZmlu YWwgU3RyaW5n
IHByZWZpeCA9IHN0ci5zdWJzdHJpbmcoZW5kSW5kZXhOUyArIDEsIHByZWZp eEluZGV4KTsK
CQlmaW5hbCBTdHJpbmcgbG9jYWxQYXJ0ID0gc3RyLnN1YnN0cmluZyhwcmVm aXhJbmRleCAr
IDEpOwoJCXJldHVybiBuZXcgUU5hbWUobnMsIGxvY2FsUGFydCwgcHJlZml4 KTsKCX0KCn0=
--------------050009040503020503020503--
Re: teneo:support for QName [message #615635 is a reply to message #114123] Fri, 07 March 2008 18:05 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> (interface/Object
> [java] at
> supported by teneo?
> Julia
The Netherlands
name="Mytest.java"
* <copyright>
* </copyright>
* <p>
* <ul>
* </ul>
* </p>
* @generated
* <p>
* </p>
* @generated
* @generated
* <p>
* </p>
* @generated
QName getName();
* @see #getName()
* @generated
* <p>
* </p>
* @generated
} // Mytest
* <copyright>
* </copyright>
* <p>
* <ul>
* </ul>
* </p>
* @generated
* @generated
* @ordered
* @generated
* @ordered
* @see #getName()
* @generated
* @ordered
* @see #getName()
* @generated
* @ordered
* @see #getNames()
* @generated
* @ordered
* @generated
super();
* @generated
* @generated
return description;
* @generated
* @generated
return name;
* @generated
name = newName;
* @generated
return names;
* @generated
return getName();
return getNames();
* @generated
return;
return;
getNames().clear();
return;
* @generated
return;
return;
getNames().clear();
return;
* @generated
* @generated
result.append(')');
} //MytestImpl
name="qname.ecore"
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
</genClasses>
</genClasses>
</genPackages>
name="qname.xsd"
Previous Topic:teneo:support for QName
Next Topic:[Teneo] Hibernate Library Editor Turorial - can't load URI
Current Time: Thu Jul 17 19:09:40 EDT 2025
Powered by FUDForum. Page generated in 0.31158 seconds
