Home » Language IDEs » Java Development Tools (JDT) » Strange error "Problems encountered while copying resources."
Strange error "Problems encountered while copying resources." [message #114110] Wed, 05 November 2003 16:04 Go to next message
Originally posted by: w.richert.gmx.net
every now and then I get the following error when compiling a Java project:
The project was not built due to "Problems encountered while copying
resources.". Fix the problem, then try refreshing this project and
rebuilding it since it may be inconsistent.
It is not obvious what the reason for this strange error can be. After that
the old class file is lost and the project cannot be build.
Any similar experiences? Any help?
Eclipse 3.0.0
Build id: 200310101454
wr
Re: Strange error "Problems encountered while copying resources." [message #114149 is a reply to message #114110] Wed, 05 November 2003 18:45 Go to previous messageGo to next message
Originally posted by: neil.neil.swingler.name
"Willi Richert" <w.richert@gmx.net> wrote in message
news:bobp5q$348$1@eclipse.org...
project:
that
> Eclipse 3.0.0
Are you using clearcase?
Neil Swingler
Re: Strange error "Problems encountered while copying resources." [message #114473 is a reply to message #114110] Thu, 06 November 2003 13:51 Go to previous messageGo to next message
Originally posted by: Jed.Anderson.EN.aclickinthedark.com
Willi,
Have you looked in your .log file? Is there a stack trace there? If
you have a stack trace I suggest you enter a bug against jdt core.
Include the stack trace.
jkca
Willi Richert wrote:
> Eclipse 3.0.0
> wr
Re: Strange error "Problems encountered while copying resources." [message #126742 is a reply to message #114149] Fri, 12 December 2003 09:40 Go to previous messageGo to next message
Originally posted by: urbanscott.hotmail.com
I am having this same problem and I am using Clearcase (no plugin). I am
using a snapshot views in Clearcase. Does anyone know what I need to do.
> > Hi,
> project:
> that
> > Eclipse 3.0.0
> Neil Swingler
Re: Strange error "Problems encountered while copying resources." [message #126913 is a reply to message #126742] Fri, 12 December 2003 14:26 Go to previous message
I found my own answer. By right clicking the project root from the tree
view and selecting "Refresh" the problem was solved. It looks like
"Refresh" is also in the "file" menu.
> > > Hi,
> > project:
> > that
> > > Eclipse 3.0.0
> > Neil Swingler
Previous Topic:ANN: XMLBuddy and XMLBuddy Pro 2.0
Next Topic:Poor Eclipse Performance on Redhat 9
Current Time: Mon Jul 21 22:01:37 EDT 2025
Powered by FUDForum. Page generated in 0.08090 seconds
