Home » Archived » BIRT » Reg: Unable to display chart using jsp page
Reg: Unable to display chart using jsp page [message #114018] Tue, 24 January 2006 07:08 Go to next message
Originally posted by: buday.metrikus.com
I've designed a report which has some charts in it along with data.
I'm accessing this report through jsp and able to see the report in jsp
But the problem is that i could not able to see image of the chart in that
jsp page.
Is there any workaround for this solution
Thank you
Re: Unable to display chart using jsp page [message #114943 is a reply to message #114018] Tue, 24 January 2006 19:18 Go to previous messageGo to next message
Which browser and OS you are using? Are use viewing the report in Webviewer
or in HTML. BIRT 2.0 introduces support of SVG chart, by default BIRT will
generate SVG chart. If your browser/platform doesn't support SVG, you can
disable SVG in the report design using the chart wizard UI.
Wenfeng
"boni.uday" <buday@metrikus.com> wrote in message
news:1ef8cbbd5a7aecab5f6f5188c88766b8$1@www.eclipse.org...
> jsp page.
> Thank you
Re: Unable to display chart using jsp page [message #115004 is a reply to message #114943] Tue, 24 January 2006 22:54 Go to previous message
I'm using IE 6.08 and My operating system is WIndows 2000 server
my BIRT Version is BIRT 1_0_1
could u pls help me in this aspect
Previous Topic:Viewer in Tomcat report/images directory
Next Topic:Cross tab or transposed table
Current Time: Tue Jul 22 08:58:53 EDT 2025
Powered by FUDForum. Page generated in 0.29851 seconds
