teneo: same name problem using jpox [message #114009] |
Thu, 06 March 2008 16:12  |
Hi Martin,
I have 2 schemas (A & B) that collide with same name for several of its
table creations. Currently using DB2 and jdk 1.4.
There appears the be several way that I can fix this problem
1) create a separate database schema for each so that the tables can exist
along side each other in the same database. But would I have to create a
separate jpoxdatastore (separate epackage & pmf) object for each schema?
2) use @Entity annotation. But I seem to recall that I will need jdk 1.5
for this. Upgrading will cause other problems.
3) Use QualifyingEntityNameStrategy extensions to add prefix. One of my
collegues tried this method but still had issues due to the complexities
of our schemas and DB2 column limitations.
What would be your best suggestion?
Julia
Re: teneo: same name problem using jpox [message #114021 is a reply to message #114009] |
Thu, 06 March 2008 16:52  |
Hi Julia,
See my answers inline.
gr. Martin
Julia wrote:
> Hi Martin,
> exist along side each other in the same database. But would I have to
> create a separate jpoxdatastore (separate epackage & pmf) object for
> each schema?
MT>> If you choose this solution then you would need to create a separate jpoxdatastore for each.
However if the epackages refer to eachother then this won't work.
MT>> The @Entity is also supported in Teneo 0.7.5. You can also use the @Table annotation.
MT>> Normally this should solve any name clashes (assuming that the epackage prefix is unique. Just
let me know what issues you encounter.
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo: same name problem using jpox [message #615619 is a reply to message #114009] |
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> each schema?
> Julia
The Netherlands
FUDForum. Page generated in 0.33051 seconds
